2mesh interantion
Old   September 27, 2007, 16:24
Default Hi foamers I have a though
O R
arkangel is on a distinguished road
Hi foamers
I have a though question:
i want to use 2 meshes
in one i want to simulate combustion with rans or les , after one time step i will have pressure field on this mesh and i want to use this pressure field as a source on other bigger field . In this field i will calculate the wave eq.
The second field is surrounding the biggest one. So they share a common boundary ... there are interactions not only from the 1. Mesh to 2. mesh(big) but also back ,
2 meshes can interact like this ?
arkangel is offline   Reply With Quote
Old   September 27, 2007, 16:26
Default a typo : The second fiel
O R
a typo :
The second field is surrounding the smaller one. So they share a common boundary ... there are interactions not only from the 1. Mesh to 2. mesh(big) but also back ,
Old   September 27, 2007, 18:48
Default Hi OR! Not easily. Look on
Assistant Moderator
Bernhard Gschaider
Hi OR!
Not easily. Look on the message-board for conjugateFoam or on the Wiki for icoStructFoam for examples on the coupling of different solvers on meshes that share a boundary.
Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Run in parallel a 2mesh case cosimobianchini OpenFOAM Running, Solving & CFD 2 January 11, 2007 07:33
