Interesting behavior when using LAM without ib rpi on an infiniband cluster OF 141
Old   October 2, 2007, 17:31
Default I am running a multphaseInterF
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
I am running a multphaseInterFoam case (approx 1.1 million hex cells) on an infiniband cluster. Thanks to Henry's help I have switched from quartic interfacecompression scheme to quadratic. This seems to keep the volume fractions stable. Anyways, when I tried to use the following procedure to start a parallel run with 8 processors, I get an error message similar to that reported in [1]:
lamboot -v $PBS_NODEFILE
mpirun -ssi rpi ib -np 8 multiphaseInterFoam . three_fluid_test_4 -parallel
I was just about to give up on getting the inifiniband to work, when I came across this webpage[2]. Following their procedure, I used the following commands to start the run:
lamboot -v -b -ssi boot rsh -ssi rsh_agent rsh $PBS_NODEFILE
mpirun -ssi rpi tcp -np 8 multiphaseInterFoam . three_fluid_test_4 -parallel
and the run started without problems. The lamboot initialization parameters suggest that I am not using the ib module? So I expected degraded performance. However, comparing the time after 7 time steps for a serial run with that of a parallel run, I get a speed up of 8.125818891 which is indeed impressive. I cannot explain why this seems to work. Any comments are appreciated.
PS: The cluster is a combination of 256 processors (i.e. 128 dual opteron boxes NOT dual-core) connected with infiniband.
[1] http://www.cfd-online.com/OpenFOAM_D...tml?1188946223
[2] http://tensor.tamu.edu/docs/lam.html
msrinath80 is offline   Reply With Quote
HPMPI Infiniband problem carsten OpenFOAM Bugs 2 January 25, 2009 16:36
Infiniband alexander_rudert OpenFOAM 20 January 14, 2009 09:01
OpenFOAM and infiniband mrangitschdowcom OpenFOAM Installation 5 October 30, 2008 08:47
infiniband interconnect help rjh FLUENT 0 February 4, 2008 12:41
OpenFOAM 141 parallel results infiniband vs gigabit vs SMP msrinath80 OpenFOAM Running, Solving & CFD 10 November 30, 2007 19:11
