October 13, 2007, 13:58 |
having some problems w
Jon Tegner
Rep Power: 17 |
having some problems with outlet-conditions in a BuoyantFoam simulation. Case is basically the same as the hotRoom tutorial case, BUT with an inlet and an outlet with given pressure both at inlet and outlet (and hence producing a "chimney" effect). On the inlet pressureInlet is used, and on the outlet pressureOutlet. The last means that a fixed value is used for the pressure at the outlet, but for all other variables zeroGradient is used. This seems to work fine in most cases, but in some situations a very small "backflow" develops at the outlet, and as soon as this happens the solution becomes unstable (starting with the temperature). Are there other, "better suited", boundary conditions I can use in this situation? |
October 15, 2007, 04:27 |
Check out the inletOutlet-clas
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Check out the inletOutlet-class of boundary conditions (fixedValue for inflow, zeroGradient for outflow) in the table 6.4 of the UserGuide. Use that for the temperature.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
October 15, 2007, 07:55 |
Thanks!
Thought they were o
Jon Tegner
Rep Power: 17 |
Thanks!
Thought they were only applicable to pressure, but seems to be running... /jon |
Re: Pressure Outlet Conditions | Andrew | FLUENT | 1 | December 20, 2006 13:36 |
outlet Boundary conditions | sivasamy | Main CFD Forum | 2 | December 19, 2005 01:01 |
Defining Outlet conditions | Luis | CFX | 0 | April 4, 2005 20:36 |
outlet conditions | tzapelina | Phoenics | 3 | January 16, 2004 04:07 |
Outlet boundary conditions | hicham FATNASSI | Main CFD Forum | 8 | February 9, 2000 02:58 |
