October 15, 2007, 04:07 |
I am having some troub
Fabian Braennstroem
Rep Power: 19 |
I am having some trouble to run an optimization loop using simpleFoam. For this I created a base setup, which ran to convergence, and cloned the mesh/setup by 'cp -a base_case new_case'. Afterwards I imported a slightly different mesh from FLUENT. Everything seems fine, but when starting the run on the new case I get: Selecting turbulence model RNGkEpsilon Starting time loop Time = 1 #0 Foam::error::printStack(Foam:stream&) in "/home/gcae504/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/gcae504/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #2 __restore_rt in "/lib64/tls/libc.so.6" #3 void Foam::fvc::surfaceIntegrate<foam::vector<double> >(Foam::Field<foam::vector<double> >&, Foam::GeometricField<foam::vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/home/gcae504/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libfiniteVolume.so" #4 Foam::tmp<foam::geometricfield<foam::vector<double >, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::surfaceIntegrate<foam::vector<double> >(Foam::GeometricField<foam::vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/home/gcae504/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libfiniteVolume.so" #5 Foam::tmp<foam::geometricfield<foam::vector<double >, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::surfaceIntegrate<foam::vector<double> >(Foam::tmp<foam::geometricfield<foam::vector<doub le>, Foam::fvsPatchField, Foam::surfaceMesh> > const&) in "/home/gcae504/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libfiniteVolume.so" #6 Foam::fv::gaussDivScheme<foam::tensor<double> >::fvcDiv(Foam::GeometricField<foam::tensor<double >, Foam::fvPatchField, Foam::volMesh> const&) in "/home/gcae504/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libfiniteVolume.so" #7 Foam::tmp<foam::geometricfield<foam::innerproduct< foam::vector<double>, Foam::Tensor<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::div<foam::tensor<double> >(Foam::GeometricField<foam::tensor<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&) in "/home/gcae504/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libincompressibleTurb ulenceModels.so" #8 Foam::tmp<foam::geometricfield<foam::innerproduct< foam::vector<double>, Foam::Tensor<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::div<foam::tensor<double> >(Foam::GeometricField<foam::tensor<double>, Foam::fvPatchField, Foam::volMesh> const&) in "/home/gcae504/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libincompressibleTurb ulenceModels.so" #9 Foam::tmp<foam::geometricfield<foam::innerproduct< foam::vector<double>, Foam::Tensor<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::div<foam::tensor<double> >(Foam::tmp<foam::geometricfield<foam::tensor<doub le>, Foam::fvPatchField, Foam::volMesh> > const&) in "/home/gcae504/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libincompressibleTurb ulenceModels.so" #10 Foam::turbulenceModels::RNGkEpsilon::divR(Foam::Ge ometricField<foam::vector<doub le>, Foam::fvPatchField, Foam::volMesh>&) const in "/home/gcae504/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libincompressibleTurb ulenceModels.so" #11 main in "/home/gcae504/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/simpleFo am" #12 __libc_start_main in "/lib64/tls/libc.so.6" #13 Foam::regIOobject::readIfModified() in "/home/gcae504/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/simpleFo am" Floating exception (core dumped) Like I mentioned just, just the mesh was changed by morphing, so no differences in any boundary condition or scheme. The imported mesh seems to be ok, at least an export back to FLUENT works well. Does anyone have an idea? Fabian |
October 15, 2007, 12:33 |
it seems that I had some
Fabian Braennstroem
Rep Power: 19 |
it seems that I had some penetrations in the morphed mesh, sorry bothering you. Fabian |
SimpleFoam Error with librdmacm amp libibverbs | dnomdec | OpenFOAM Running, Solving & CFD | 1 | May 21, 2010 08:02 |
SimpleFoam error | sven82 | OpenFOAM Running, Solving & CFD | 0 | October 16, 2008 04:13 |
Error running simpleFoam in parallel | skabilan | OpenFOAM Running, Solving & CFD | 2 | August 29, 2008 09:42 |
SIMPLEFOAM ERROR ON A RAE2822 | dinonettis | OpenFOAM Running, Solving & CFD | 0 | April 28, 2008 09:50 |
Error message using simpleFoam | plmauk | OpenFOAM Running, Solving & CFD | 0 | January 22, 2008 07:46 |
