Using simpleFoam with water
Old   October 22, 2007, 15:04
Default Hello, Is there a way to se
nicolas
nico765 is on a distinguished road
Is there a way to setup the fluid density in simpleFoam?
I would like to use water, so far i have set up my cases to run at similar reynolds number using high velocities (~100m/s) in my cases. Not sure if this is the best way, since the cases are more unstable when running at higher velocities (same y+ values).
Nico
nico765 is offline   Reply With Quote
Old   October 22, 2007, 15:13
Default Fluid density is constant: tha
Hrvoje Jasak
Fluid density is constant: that is why we use the kinematic viscosity. Therefore, divide your dynamic viscosity (in Pascal seconds) bu fluid density and specify that in the constant/transportProperties. Be careful to put back the density if you need wall forces or similar from the pressure (for consistency, p is kinematic pressure).
Enjoy,
Hrv
Hrvoje Jasak
Old   October 23, 2007, 05:52
Default Dear Hrvoje Jasak! Please, ans
mkraposhin's Avatar
Matvey Kraposhin
mkraposhin is on a distinguished road
Dear Hrvoje Jasak! Please, answer a stupid qustion: how can i convert relative pressure from simpleFoam to normal (total Pressure (kg*m/s^2)??
Many thanks for advice!
mkraposhin is offline   Reply With Quote
Old   October 23, 2007, 06:02
Default Requires a Napoleonic answer h
Hrvoje Jasak
Multiply by the density
Jasak
Hrvoje Jasak
Old   October 23, 2007, 06:11
Default But it is negative!!! for exam
mkraposhin's Avatar
Matvey Kraposhin
But it is negative!!! for example, pressure in simpleFoam ranges from -1 to 1 - what does it means?
Old   October 23, 2007, 06:24
Default And, another question (i hope,
mkraposhin's Avatar
Matvey Kraposhin
And, another question (i hope, i'm not too importunate, and sorry for bad English!)
This question arises when i increase mesh density in cavity tutorial by 2 (both in x and y dimensions) - pressure range increases by 4...
i think, it arises from Bernoulli eqn
i mean, p/rho + w^2/2 + g*z = const...
specific volume (= 1/rho) decreases by 4, so pressure range increasses 4 to satisfy equation. isn't it?
Default As you know, in incompressible
Hrvoje Jasak
As you know, in incompressible flows, the pressure level does not matter: the flow is driven by the pressure gradient. Therefore, you can add any offset to the pressure field that you like - remember the pressure on the boundary being e.g. zero or the pressure in the reference point usually set to zero as well.
Therefore, if you know the absolute pressure in any point of the domain, just shift the complete pressure field for this number, maybe adding 101325 Pascal if it makes you feel better.
None of this actually matters when you are calculating the forces unless you've got vacuum outside.
Hrv
Hrvoje Jasak
Old   October 23, 2007, 06:39
Default Many Thanks, Hrvoje Jasak, for
mkraposhin's Avatar
Matvey Kraposhin
Many Thanks, Hrvoje Jasak, for Your advice!
Many Thanks!
I'll give it a try.
What is phi in simpleFoam ehsan_vaghefi OpenFOAM Running, Solving & CFD 9 October 5, 2024 08:49
SimpleFoam How to specify density sebastiank OpenFOAM Running, Solving & CFD 3 July 27, 2023 10:45
NACA0012 with simpleFOAM nuovodna OpenFOAM Running, Solving & CFD 7 May 19, 2010 05:58
Liquid water, gaseous water and another gas Andy FLUENT 1 May 22, 2006 09:51
shallow water VS deep water Paul Main CFD Forum 10 August 30, 2004 12:56
