Problem with InterFoam
Old   October 25, 2007, 21:41
Default I have created a 2D channel wi
Harris
in_flu_ence is on a distinguished road
I have created a 2D channel with the respective inlet (waterin and oilin) and outlet(outlet). I believe I have set up the mesh right and also having the initial fields done. However, there is some error about printstack when I run the interFoam function.
I have uploaded the case at
http://www.udsn.net/MC50.zip
Advice please.
in_flu_ence is offline   Reply With Quote
Old   October 26, 2007, 06:59
Default Hi Harris, At least your bloc
Takuya OSHIMA
7islands is on a distinguished road
Hi Harris,
At least your blockMeshDict is incorrect, as you can see by running checkMesh. The lines that should be corrected are:
<pre>blocks
// hex (0 1 4 3 6 7 10 9) (100 15 1) simpleGrading (1 1 1)
hex (0 3 4 1 6 9 10 7) (100 15 1) simpleGrading (1 1 1)
// hex (1 2 5 4 7 8 11 10) (100 15 1) simpleGrading (1 1 1)
hex (1 4 5 2 7 10 11 8) (100 15 1) simpleGrading (1 1 1)
patch waterin
// (0 1 7 6)
(6 7 1 0)
patch oilin
// (1 2 8 7)
(7 8 2 1)
wall pipewall
// (2 5 11 8)
(8 11 5 2)
(0 3 9 6)
</pre>Takuya
7islands is offline   Reply With Quote
Old   October 26, 2007, 08:30
Default To extend to your answer, is t
Harris
To extend to your answer, is there a certain way of putting the points into the matrix? Clockwise, anti-clockwise, etc?
Thanks
Old   October 26, 2007, 09:18
Default Well, there's always one thing
Takuya OSHIMA
Well, there's always one thing you can do by yourself: "RTM."
Old   October 26, 2007, 09:39
Default Thanks. I realise I didn't do
Harris
Thanks. I realise I didn't do a blockMesh after correction. I think it works now with checkMesh.
Wmake problem interFoam solver feijooos OpenFOAM Running, Solving & CFD 4 December 8, 2008 12:01
InterFoam floooo OpenFOAM Running, Solving & CFD 0 November 3, 2008 12:00
Problem with the pressure field using interFoam zoune OpenFOAM Running, Solving & CFD 20 February 4, 2008 19:42
InterFoam problem running parallel vatant OpenFOAM Running, Solving & CFD 0 April 28, 2006 20:22
InterFoam problem Xiaofeng Liu (Liu) OpenFOAM Running, Solving & CFD 8 October 26, 2005 22:38
