%230 FoamerrorprintStackFoam%3cIMG SRC%3d%22httpopenfoamcfdonlinecomforumclipartproud gif%22 ALT%3d%22O%22 BORDER%3d0%3estreamamp |
October 25, 2007, 09:28 |
Hi all..
I am facing th fol
Nishant
Rep Power: 17 |
Hi all..
I am facing th following problem. I will appreciate if somebody can help me. #0 Foam::error::printStack(Foam:stream&) in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: [0x110420] #3 void Foam::fvc::surfaceIntegrate<foam::vector<double> >(Foam::Field<foam::vector<double> >&, Foam::GeometricField<foam::vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libfiniteVolume.so" #4 Foam::tmp<foam::geometricfield<foam::vector<double >, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::surfaceIntegrate<foam::vector<double> >(Foam::GeometricField<foam::vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libfiniteVolume.so" #5 Foam::tmp<foam::geometricfield<foam::vector<double >, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::surfaceIntegrate<foam::vector<double> >(Foam::tmp<foam::geometricfield<foam::vector<doub le>, Foam::fvsPatchField, Foam::surfaceMesh> > const&) in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libfiniteVolume.so" #6 Foam::fv::gaussDivScheme<foam::tensor<double> >::fvcDiv(Foam::GeometricField<foam::tensor<double >, Foam::fvPatchField, Foam::volMesh> const&) in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libfiniteVolume.so" #7 Foam::tmp<foam::geometricfield<foam::innerproduct< foam::vector<double>, Foam::Tensor<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::div<foam::tensor<double> >(Foam::GeometricField<foam::tensor<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&) in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libincompressibleTurbule nceModels.so" #8 Foam::tmp<foam::geometricfield<foam::innerproduct< foam::vector<double>, Foam::Tensor<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::div<foam::tensor<double> >(Foam::GeometricField<foam::tensor<double>, Foam::fvPatchField, Foam::volMesh> const&) in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libincompressibleTurbule nceModels.so" #9 Foam::tmp<foam::geometricfield<foam::innerproduct< foam::vector<double>, Foam::Tensor<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::div<foam::tensor<double> >(Foam::tmp<foam::geometricfield<foam::tensor<doub le>, Foam::fvPatchField, Foam::volMesh> > const&) in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libincompressibleTurbule nceModels.so" #10 Foam::turbulenceModels::kEpsilon::divR(Foam::Geome tricField<foam::vector<double> , Foam::fvPatchField, Foam::volMesh>&) const in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libincompressibleTurbule nceModels.so" #11 main in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/simpleFoam" #12 __libc_start_main in "/lib/libc.so.6" #13 Foam::regIOobject::readIfModified() in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/simpleFoam" Floating point exception
Thanks and regards, Nishant |
October 25, 2007, 09:33 |
I am working on icoFoam with c
Nishant
Rep Power: 17 |
I am working on icoFoam with cylindrical pipe flow geometry with water as fluid. I have applied b.c. as :
inlet- fixed value U, zerogradiect p outlet - zerogradient U, fixed value p kinetic viscosity = 0.9 I also tried this case with simple foam with similar modification, but that also didnt work out. Please suggest ..!! Nisahnt
October 25, 2007, 17:46 |
Just 2 things (because i think
Gabriel Barroso
Rep Power: 17 |
Just 2 things (because i think i had a similar mistake but may be not):
1. What are your wall boundary conditions, do you have fixedValue and then value (0 0 0) ? 2. Did you try with another mesh? Bests Gabriel |
October 25, 2007, 22:51 |
Thanks Gabriel..
first option
Nishant
Rep Power: 17 |
Thanks Gabriel..
first option is alrite. second option i can try. but will that make any difference, as mesh looks quite good on parafoam?. Also I tried with different meshing of 10x10x80, 20x20x400 etc. I took cylinder as a hexagon surrounded by curved edged hexagon. something like this........ ([]) plz suggest.
October 27, 2007, 11:31 |
I am also not been able to rec
Nishant
Rep Power: 17 |
I am also not been able to recompile the foam to run it in debug mode. I do not know what exactly is the problem. can any body tell me, is this because of gcc compiler or what?? i have two gcc compiler on my linux system. one default and one with the package. precompiled programs on my ststem is running quite ok. But so far I could not be able to run any own programm.
The error after recompiling using ./Allawake is :- /home/343880/OpenFOAM/linux/paraview-2.4.4/include/vtkDataObject.h: In member function 'virtual void vtkDataObject::ReleaseDataFlagOn()': /home/343880/OpenFOAM/linux/paraview-2.4.4/include/vtkDataObject.h:116: warning: use of old-style cast /home/343880/OpenFOAM/linux/paraview-2.4.4/include/vtkDataObject.h: In member function 'virtual void vtkDataObject::ReleaseDataFlagOff()': /home/343880/OpenFOAM/linux/paraview-2.4.4/include/vtkDataObject.h:116: warning: use of old-style cast /home/343880/OpenFOAM/linux/paraview-2.4.4/include/vtkDataObject.h: In member function 'virtual void vtkDataObject::RequestExactExtentOn()': /home/343880/OpenFOAM/linux/paraview-2.4.4/include/vtkDataObject.h:273: warning: use of old-style cast /home/343880/OpenFOAM/linux/paraview-2.4.4/include/vtkDataObject.h: In member function 'virtual void vtkDataObject::RequestExactExtentOff()': /home/343880/OpenFOAM/linux/paraview-2.4.4/include/vtkDataObject.h:273: warning: use of old-style cast `/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPDebug/libvtkFoam.so' is up to date. make[3]: Leaving directory `/home/343880/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing/grap hics/PVFoamReader/vtkFoam' + cd PVFoamReader + mkdir -p Make/linuxGccDPDebug + cd Make/linuxGccDPDebug + cmake ../.. ./Allwmake: line 6: cmake: command not found + make make[3]: Entering directory `/home/343880/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing/grap hics/PVFoamReader/PVFoamReader/Make/linuxGccDPDebug' make[3]: *** No targets specified and no makefile found. Stop. make[3]: Leaving directory `/home/343880/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing/grap hics/PVFoamReader/PVFoamReader/Make/linuxGccDPDebug' make[2]: *** [PVFoamReader] Error 2 make[2]: Leaving directory `/home/343880/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing/grap hics' make[1]: *** [graphics] Error 2 make[1]: Leaving directory `/home/343880/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing' make: *** [postProcessing] Error 2 + '[' 0 = 1 -a '' = doc ']'
October 27, 2007, 12:18 |
Hello Nishanth,
The error y
Philippose Rajan
Rep Power: 25 |
Hello Nishanth,
The error you get during compilation of OpenFOAM is because you do not have the cross platform make software called "cmake". If you notice... around mid way through your error messages.. you see "cmake: command not found". Since the PVFoamReader requires cmake to compile, you will have to install cmake on your linux distribution. Depending on the "flavour" of linux you are using... there might already be a suitable binary install (for example... if you are using Fedora, you can install cmake via yum). If not, you can download it from.... http://www.cmake.org/HTML/Index.html The other option, is to remove the "PVFoamReader" directory from the "applications/utilities/postProcessing/graphics" folder, so that "wmake" does not try to make that library during the compile process. In this case, you will not be able to use "paraFoam" for your postprocessing. However, doesnt the compilation continue on with the rest of the libraries, even though this error message comes up? Or does it abort at this stage? Have a nice weekend! Philippose |
October 28, 2007, 07:39 |
Thank you very much Philippose
Nishant
Rep Power: 17 |
Thank you very much Philippose. I have done yum update on my fedore system. Now I am compiling foam suing ./Allwmake. I gues this will take some time.
About the error.. the compilation aborted after the error. Thats the few last lines of the display screen. I wanted to know, if this compilation error has something to do with my new simulation in icoFoam. Please see my first two blogs in this thread. Looking forward to hearing form you soon. have a nice weekend to you also Cheers!! Nishant
October 28, 2007, 08:58 |
Hi Philippose..
I am still
Nishant
Rep Power: 17 |
Hi Philippose..
I am still having some error. I installed using yum and then also in linux directory of openfoam. but in both the cases the error is almost the same... make[3]: Entering directory `/home/343880/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing/data Conversion/foamToGMV' make[3]: `/home/343880/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPDebug/foamToGMV ' is up to date. make[3]: Leaving directory `/home/343880/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing/data Conversion/foamToGMV' make[2]: Leaving directory `/home/343880/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing/data Conversion' make[2]: Entering directory `/home/343880/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing/grap hics' + '[' /home/343880/OpenFOAM/linux/paraview-2.4.4/lib/paraview-2.4 -a -r /home/343880/OpenFOAM/linux/paraview-2.4.4/lib/paraview-2.4 ']' + wmake libso vtkFoam make[3]: Entering directory `/home/343880/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing/grap hics/PVFoamReader/vtkFoam' `/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPDebug/libvtkFoam.so' is up to date. make[3]: Leaving directory `/home/343880/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing/grap hics/PVFoamReader/vtkFoam' + cd PVFoamReader + mkdir -p Make/linuxGccDPDebug + cd Make/linuxGccDPDebug + cmake ../.. CMake Error: Error in cmake code at /home/343880/OpenFOAM/linux/paraview-2.4.4/lib/paraview-2.4/ParaViewConfig.cmake :29: INCLUDE Could not find include file: /home/dm2/henry/OpenFOAM/linuxSrc/paraview-2.4.4/platforms/linuxGcc4DPOpt/ParaVi ewLibraryDepends.cmake Current CMake stack: [2] /home/343880/OpenFOAM/linux/paraview-2.4.4/lib/paraview-2.4/ParaViewConfig.cmake [1] /home/343880/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing/graph ics/PVFoamReader/PVFoamReader/CMakeLists.txt CMake Error: Error in cmake code at /home/343880/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing/graph ics/PVFoamReader/PVFoamReader/CMakeLists.txt:38: INCLUDE Could not find include file: /home/dm2/henry/OpenFOAM/linuxSrc/paraview-2.4.4/ParaViewUse.cmake Current CMake stack: [1] /home/343880/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing/graph ics/PVFoamReader/PVFoamReader/CMakeLists.txt CMake Error: Error in cmake code at /home/343880/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing/graph ics/PVFoamReader/PVFoamReader/CMakeLists.txt:56: Unknown CMake command "VTK_WRAP_ClientServer". -- Configuring done + make make[3]: Entering directory `/home/343880/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing/grap hics/PVFoamReader/PVFoamReader/Make/linuxGccDPDebug' make[3]: *** No targets specified and no makefile found. Stop. make[3]: Leaving directory `/home/343880/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing/grap hics/PVFoamReader/PVFoamReader/Make/linuxGccDPDebug' make[2]: *** [PVFoamReader] Error 2 make[2]: Leaving directory `/home/343880/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing/grap hics' make[1]: *** [graphics] Error 2 make[1]: Leaving directory `/home/343880/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing' make: *** [postProcessing] Error 2 + '[' 0 = 1 -a '' = doc ']' Please suggest. Nishant
October 28, 2007, 18:02 |
This is the important error me
#9 |
Martin Beaudoin
Rep Power: 22 |
This is the important error message:
INCLUDE Could not find include file: /home/dm2/henry/OpenFOAM/linuxSrc/paraview-2.4.4/platforms/linuxGcc4DPOpt/ParaVi ewLibraryDepends.cmake The source code shipped by OpenCFD got a hard-coded path that you need to modify. Check this site for more information on how to recompile OpenFOAM and the paraView modules: http://openfoamwiki.net/index.php/Howto_compile_OpenFOAM#Compiling_and_installin g_ParaView http://openfoamwiki.net/index.php/Howto_compile_OpenFOAM#Modifications_for_the_c ompilation_of_PVFoamReader Martin |
October 29, 2007, 05:59 |
Hi Martin ..
Thank you for
#10 |
Nishant
Rep Power: 17 |
Hi Martin ..
Thank you for your reply. My paraview was working fine before. After doing the re-compilation it is not working now. But the major issue with me at this point is that I am simulating a cylindrical pipe flow geometry with water as fluid in icoFoam. I wanted to know whether the compilation problem has anything to do with the error I am facing in simulation. the error in icofoam cylinder geometry is:- #0 Foam::error::printStack(Foam::-Ostream&) in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: [0x110420] #3 void Foam::fvc::surfaceIntegrate<foam::vector<double> >(Foam::Field<foam::vector<double> >&, Foam::GeometricField<foam::vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libfiniteVolume.so" #4 Foam::tmp<foam::geometricfield<foam::vector<double >, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::surfaceIntegrate<foam::vector<double> >(Foam::GeometricField<foam::vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libfiniteVolume.so" #5 Foam::tmp<foam::geometricfield<foam::vector<double >, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::surfaceIntegrate<foam::vector<double> >(Foam::tmp<foam::geometricfield<foam::vector<doub le>, Foam::fvsPatchField, Foam::surfaceMesh> > const&) in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libfiniteVolume.so" #6 Foam::fv::gaussDivScheme<foam::tensor<double> >::fvcDiv(Foam::GeometricField<foam::tensor<double >, Foam::fvPatchField, Foam::volMesh> const&) in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libfiniteVolume.so" #7 Foam::tmp<foam::geometricfield<foam::innerproduct< foam::vector<double>, Foam::Tensor<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::div<foam::tensor<double> >(Foam::GeometricField<foam::tensor<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&) in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libincompressibleTurbule nceModels.so" #8 Foam::tmp<foam::geometricfield<foam::innerproduct< foam::vector<double>, Foam::Tensor<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::div<foam::tensor<double> >(Foam::GeometricField<foam::tensor<double>, Foam::fvPatchField, Foam::volMesh> const&) in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libincompressibleTurbule nceModels.so" #9 Foam::tmp<foam::geometricfield<foam::innerproduct< foam::vector<double>, Foam::Tensor<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::div<foam::tensor<double> >(Foam::tmp<foam::geometricfield<foam::tensor<doub le>, Foam::fvPatchField, Foam::volMesh> > const&) in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libincompressibleTurbule nceModels.so" #10 Foam::turbulenceModels::kEpsilon::divR(Foam::Geome tricField<foam::vector<double> , Foam::fvPatchField, Foam::volMesh>&) const in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libincompressibleTurbule nceModels.so" #11 main in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/simpleFoam" #12 __libc_start_main in "/lib/libc.so.6" #13 Foam::regIOobject::readIfModified() in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/simpleFoam" Floating point exception
October 29, 2007, 06:03 |
Hi Martin ..
Thank you for
#11 |
Nishant
Rep Power: 17 |
Hi Martin ..
October 29, 2007, 14:45 |
Hi Martin..
I find this p
#12 |
Nishant
Rep Power: 17 |
Hi Martin..
I find this part to be useful for my purpose. But can you tellme where I need to modify the file: $HOME/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing/graphics/PVF oamReader/PVFoamReader/CMakeLists.txt? My file looks like this:- 1 2 # Must be defined before ADD_LIBRARY for cmake version 2.3.4-20060317 3 LINK_DIRECTORIES($ENV{FOAM_LIBBIN}) 4 LINK_DIRECTORIES($ENV{FOAM_USER_LIBBIN}) 5 6 # Create vtk client/server wrappers for the classes. 7 VTK_WRAP_ClientServer(${PROJECT_NAME} PVFoamReaderCS_SRCS "${PVFoamReader_SRCS}") 8 9 # Build the package as a plugin for ParaView. 10 ADD_LIBRARY(${PROJECT_NAME} MODULE ${PVFoamReader_SRCS} ${PVFoamReaderCS_SRCS}) 11 LINK_DIRECTORIES($ENV{ParaView_INST_DIR}/lib) 12 TARGET_LINK_LIBRARIES(${PROJECT_NAME} vtkClientServer) 13 FOREACH(c ${PVFoamReader_LIBS}) 14 TARGET_LINK_LIBRARIES(${PROJECT_NAME} ${c}CS) 15 ENDFOREACH(c) 16 17 # Place the package configuration file into the build tree. 18 CONFIGURE_FILE(${PROJECT_SOURCE_DIR}/PVFoamReader.xml.in 19 ${PROJECT_BINARY_DIR}/../${PROJECT_NAME}.xml @ONLY IMMEDIATE) 20 21 # Place the package configuration file into the build tree. 22 CONFIGURE_FILE(${PROJECT_SOURCE_DIR}/PVFoamReader.pvsm.in 23 ${PROJECT_BINARY_DIR}/../${PROJECT_NAME}.pvsm @ONLY IMMEDIATE) 24 25 TARGET_LINK_LIBRARIES(${PROJECT_NAME} OpenFOAM finiteVolume vtkFoam) 26 ~ Please suggest the possible modification. Nishant
October 29, 2007, 14:50 |
Hello Nishant,
Reading from
#13 |
Martin Beaudoin
Rep Power: 22 |
Hello Nishant,
Reading from your other posts, I don't think you need to recompile OpenFOAM unless you want to run your simulation in a debugger. Your pre-compiled version is doing fine with the tutorials, so basically your setup is fine to go without recompilation. The problem you are seeing is caused by a floating point exception (division by zero, overflow, etc.) The floating point exception is in the call to Foam::fvc::surfaceIntegrate(). Check out your simulation parameters, verify your mesh geometry. Maybe you could try your simulation with a simpler geometry just to see where the problem really comes from? Martin |
October 30, 2007, 05:45 |
Thanks Martin.. http://www.cfd
#14 |
Nishant
Rep Power: 17 |
Thanks Martin..
I will try with simpler geomery today. But after I re-compile the foam ( with error message), my blockMesh command is not working properly on terminal. Also Parafoam could not be able to read the mesh. What could be the reason for this? please suggest. Nishant
October 30, 2007, 06:24 |
should I clean the re-compilat
#15 |
Nishant
Rep Power: 17 |
should I clean the re-compilation by:
wcleanAll ?? Or will it then delete some of my important files files? as i can see here .. http://www.cfd-online.com/OpenFOAM_D...tml?1184624858 let me know.
October 30, 2007, 08:02 |
Reinstalling a pre-compiled ve
#16 |
Martin Beaudoin
Rep Power: 22 |
Reinstalling a pre-compiled version might be a good option here.
Martin |
October 30, 2007, 10:52 |
Hi Martin
Thank you very muc
#17 |
Nishant
Rep Power: 17 |
Hi Martin
Thank you very much. your suggestions were valueable. I could be able to run my case with square-faced pipe. So definitely the error is with my previous geometry. My cylinder is like a hexagon surrounded by 4-curved edge hexagons. something like ([]) BlockmEsh file:- vertices ( (0.3 0 0) (0 0.3 0) (-0.3 0 0) (0 -0.3 0) (1 0 0) (0 1 0) (-1 0 0) (0 -1 0) (0.3 0 40) (0 0.3 40) (-0.3 0 40) (0 -0.3 40) (1 0 40) (0 1 40) (-1 0 40) (0 -1 40) ); blocks ( hex (0 1 2 3 8 9 10 11) (4 4 6) simpleGrading (1 1 1) hex (0 1 5 4 8 9 13 12) (4 4 6) simpleGrading (1 1 1) hex (1 2 6 5 9 10 14 13) (4 4 6) simpleGrading (1 1 1) hex (2 3 7 6 10 11 15 14) (4 4 6) simpleGrading (1 1 1) hex (3 0 4 7 11 8 12 15) (4 4 6) simpleGrading (1 1 1) ); edges ( arc 4 5 (0.866 0.5 0) arc 5 6 (-0.866 0.5 0) arc 6 7 (-0.866 -0.5 0) arc 7 4 (0.866 -0.5 0) arc 12 13 (0.866 0.5 40) arc 13 14 (-0.866 0.5 40) arc 14 15 (-0.866 -0.5 40) arc 15 12 (0.866 -0.5 40) ); patches ( wall fixedWalls ( (4 5 13 12) (5 6 14 13) (6 7 15 14) (7 4 12 15) ) patch inlet ( (0 3 2 1) (0 4 7 3) (0 1 5 4) (1 2 6 5) (2 3 7 6) ) patch outlet ( (8 9 10 11) (8 11 15 12) (9 8 12 13) (10 9 13 14) (10 14 15 11) ) ); mergePatchPairs ( ); Could there be a better geometry for this? I tried it on CFX and the results are good. Plz suggest. Nishant
Again I re-installed openfoam
#18 |
Nishant
Rep Power: 17 |
Again I re-installed openfoam now .. everything is working fine... except FoamX. Error reported is :
[343880@w191-210 ~]$ FoamX Starting NameServer with inet:w191-210:1234 ... Starting FoamX Host Browser with inet:w191-210:1234 ... FoamXHostBrowser: error while loading shared libraries: /home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libFoamX.so: cannot restore segment prot after reloc: Permission denied runFoamXHB : cleanup runFoamXHB: Name server is not running. Please suggest. Nishant
October 30, 2007, 13:52 |
FoamX is now working fine. htt
#19 |
Nishant
Rep Power: 17 |
