ReactingFoam error in parallel
Old   October 26, 2007, 18:44
Default Hi OF community I simulated
victor
torvic is on a distinguished road
Hi OF community
I simulated a flame with reactingfoam in serial and had no problems in a 5 second5 simulation . But when running the same in parallel it quits at 0.08 and displays the following error message.
I must say that is the first run in parallel i try, so i ask for patience
any comment is strongly appreciated.
thanks
V
Solving chemistry
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for Ux, Initial residual = 0.0150312, Final residual = 4.31222e-07, No Iterations 6
[0] #0 [1] Foam::error::printStack(Foam:stream&)#0 Foam::error::printStack(Foam:stream&)
[0] #1 Foam::sigFpe::sigFpeHandler(int)
[1] #1 Foam::sigFpe::sigFpeHandler(int)
[0] #2
[1] #2 ????
[1] #3 void Foam::processorLduInterface::compressedSend<double >(Foam::UList<double> const&, bool) const
[0] #3 void Foam::processorLduInterface::compressedSend<double >(Foam::UList<double> const&, bool) const
[1] #4 Foam::processorFvPatchField<foam::vector<double> >::initInterfaceMatrixUpdate(Foam::Field<double> const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, unsigned char, bool) const
[0] #4 Foam::processorFvPatchField<foam::vector<double> >::initInterfaceMatrixUpdate(Foam::Field<double> const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, unsigned char, bool) const
[1] #5 Foam::lduMatrix::initMatrixInterfaces(Foam::FieldF ield<foam::field,> const&, Foam::UPtrList<foam::lduinterfacefield> const&, Foam::Field<double> const&, Foam::Field<double>&, unsigned char) const
[1] #6 Foam::lduMatrix::Amul(Foam::Field<double>&, Foam::tmp<foam::field<double> > const&, Foam::FieldField<foam::field,> const&, Foam::UPtrList<foam::lduinterfacefield> const&, unsigned char) const
[0] #5 Foam::lduMatrix::initMatrixInterfaces(Foam::FieldF ield<foam::field,> const&, Foam::UPtrList<foam::lduinterfacefield> const&, Foam::Field<double> const&, Foam::Field<double>&, unsigned char) const
[0] #6
[1] #7 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const
[0] #7 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const
[1] #8
[0] #8 Foam::fvMatrix<foam::vector<double> >::solve(Foam::Istream&)Foam::fvMatrix<foam::vecto r<double> >::solve(Foam::Istream&)
[0] #9
[1] #9 Foam::lduMatrix::solverPerformance Foam::solve<foam::vector<double> >(Foam::tmp<foam::fvmatrix<foam::vector<double> > > const&)Foam::lduMatrix::solverPerformance Foam::solve<foam::vector<double> >(Foam::tmp<foam::fvmatrix<foam::vector<double> > > const&)
[0] #10
[1] #10 main
[0] #11 __libc_start_mainmain
[0] #12 __gxx_personality_v0
[1] #11 __libc_start_main at ../sysdeps/x86_64/elf/start.S:116
[1] #12 __gxx_personality_v0 at ../sysdeps/x86_64/elf/start.S:116
One of the processes started by mpirun has exited with a nonzero exit
code. This typically indicates that the process finished in error.
If your process did not finish in error, be sure to include a "return
0" or "exit(0)" in your C code before exiting the application.
PID 11602 failed on node n0 (192.168.148.178) due to signal 8.
torvic is offline   Reply With Quote
Old   October 30, 2007, 16:17
Default Hello OF community Do you h
victor
Hello OF community
Do you have any comment to this error message ?
I'm using OF 1.4
thanks in advance
V
Old   October 30, 2007, 20:03
Default Check here: http://www.cfd-
Martin Beaudoin
mbeaudoin will become famous soon enough
Check here:
http://www.cfd-online.com/OpenFOAM_D...es/1/5660.html
Martin
mbeaudoin is offline   Reply With Quote
Old   October 30, 2007, 21:07
Default Hi Martin, thanks for the h
victor
Hi Martin,
thanks for the hint. i'll check it and comment
best and thanks again
V
mvConvection in reactingFoam smehdi609 OpenFOAM Running, Solving & CFD 7 April 16, 2019 11:22
ReactingFoam vassilis OpenFOAM Running, Solving & CFD 75 September 11, 2013 16:22
ReactingFoam solver muthukaalai OpenFOAM Running, Solving & CFD 1 June 16, 2008 14:36
ReactingFoam without reactions lasb OpenFOAM Running, Solving & CFD 5 June 10, 2008 09:50
ReactingFoam error prashant24983 OpenFOAM Running, Solving & CFD 3 October 4, 2007 05:54
