April 28, 2005, 06:36 |
Well, thanks Tommaso, but now
#21 |
Ervin Adorean
Rep Power: 17 |
Well, thanks Tommaso, but now I'm confused.
> 'maxDeltaT in an engine simulation is the MAXIMUM CRANK ANGLE (and not the TIME STEP) and it should be kept around 0.1' What MAXIMUM CRANK ANGLE is maxDeltaT? In dieselEngineFoam and engineFoam time=CAD, right? Can you please explain it in more detail? Ervin |
May 2, 2005, 05:27 |
I would very much ap
#22 |
Ervin Adorean
Rep Power: 17 |
I would very much appreciate some guidelines for using 'dieselEngineFoam'. Is it OK to define the piston, liner and cylinderhead temp. b.c. as fixedValue? And how is that light speed-like value of "Average Velocity for injector 0: 5.63034e+06 m/s, injection pressure = 1200 bar" calculated? Does this need to be calculated, even if injection doesn't exist at that time? For a calculation starting at -180 CAD and ending at -10 CAD, the injection beginning at -4.4 CAD I always get divergence sooner or later, because of a high Courant number. Which is the best way of keeping the Courant number low? Thanks! Ervin |
May 2, 2005, 12:27 |
Now even with a low Courant nu
#23 |
Ervin Adorean
Rep Power: 17 |
Now even with a low Courant number, I've got this error message:
Max Courant Number = 0.0900482 deltaT = 2.57864e-14 Crank angle = -178.087 CA-deg deltaZ = 6.93889e-15 void fvMesh::makePhi() : creating zero flux field tmp<scalarfield> polyMesh::movePoints(const pointField&) : Moving points for time -0.0197875 index 183 bool primitiveMesh::checkMeshMotion(const pointField& newPoints, const bool report) const: checking mesh motion Min volume = 4.03647e-11. Total volume = 0.000243926. Cell volumes OK. Min area = 3.42112e-08. Face areas OK. Pyramid volumes OK. Non-orthogonality check OK. Mesh motion check OK. void fvMesh::makeCf() : assembling face centres void fvMesh::makeC() : assembling cell centres void fvMesh::makeSf() : assembling face areas void fvMesh::makeMagSf() : assembling mag face areas clearance: 0.155971 Piston speed = 0.269091 m/s volume continuity errors : sum local = 1.63264e-15, global = 8.5799e-19 Solving chemistry BICCG: Solving for Ux, Initial residual = 0.604385, Final residual = 2.0787e-07, No Iterations 17 BICCG: Solving for Uy, Initial residual = 0.351684, Final residual = 7.86904e-07, No Iterations 18 BICCG: Solving for Uz, Initial residual = 0.999143, Final residual = 5.99763e-07, No Iterations 36 BICCG: Solving for h, Initial residual = 1, Final residual = 5.14966e-07, No Iterations 39 --> FOAM FATAL ERROR : attempt to use janafThermo<equationofstate> out of temperature range 200 -> 5000; T = 61502.9 Function: janafThermo<equationofstate>::checkT(const scalar T) const in file: /home/ervin/OpenFOAM/OpenFOAM-1.1/src/thermophysicalModels/specie/lnInclude/jana fThermoI.H at line: 73. FOAM aborting Anybody has a hint? What is wrong in my case setup? |
July 10, 2007, 01:41 |
I'm new to C++.
In
#24 |
I'm new to C++. In dieselEngineFoam, What is the relationship between "adjustTimeStep" and "maxDeltaT"? Please teach me. thank you. Atsushi |
July 10, 2007, 02:31 |
These parameters are in
#25 |
Masato Otsuki
Rep Power: 17 |
These parameters are input at: $FOAM_SRC/src/finiteVolume/lnInclude/readTimeControls.H And used at: $FOAM_SRC/finiteVolume/lnInclude/setDeltaT.H Masato |
July 10, 2007, 02:34 |
sorry,
#26 |
Masato Otsuki
Rep Power: 17 |
sorry,
$FOAM_SRC/src/finiteVolume/lnInclude/readTimeControls.H --> $FOAM_SRC/finiteVolume/lnInclude/readTimeControls.H Masato |
July 10, 2007, 03:16 |
Thanks, Masato.
Atsushi
#27 |
Thanks, Masato.
Atsushi |
September 14, 2007, 02:30 |
What is the unit of "dQ
#28 |
What is the unit of "dQ"? [J/θ]? [J/s}? I want to calculate ROHR per clank angle. thanks. Atsu |
September 14, 2007, 04:56 |
hi,
look in the createfield
#29 |
Stephan Gerber
Rep Power: 17 |
hi,
look in the createfields.h-file- this file creates dQ with unit dimensionSet(1,-3,-1,0,0,0,0). regards stephan |
October 8, 2007, 03:18 |
hi, Stephan
I checked dQ di
#30 |
hi, Stephan
I checked dQ dimensionSet(1,-3,-1,0,0,0,0)in the createfields.h-file-. It's not heat release rate. dQ unit is "density per second"...?? If the unit is so, dQ has no relation to heat release rate. I misunderstand that "dQ = heat release rate". Am I right? Thanks, Atsu |
October 8, 2007, 03:26 |
check hEqn.H,
the term is a
#31 |
Niklas Nordin
Rep Power: 29 |
check hEqn.H,
the term is a bit misleading since its divided by cp. |
October 9, 2007, 22:27 |
hi,Niklas
I checked hEqn.H.
#32 |
hi,Niklas
I checked hEqn.H. It seems that "[dQ]=[h][RR]/[Cp]" If, [h]=J/kg [RR]=kg/m3/s [Cp]=J/kg/K then, the unit of dQ is shown by [dQ]= kg.K/m3/s =[1 -3 -1 1 0 0 0] ...What is this unit?? I'm new to C++,and my explanation may wrong. Please teach me the meaning of dQ unit. Thanks, Atsu |
November 19, 2007, 09:07 |
I was solving a case usin
#33 |
N S Prasad
Rep Power: 17 |
I was solving a case using engine foam. the case solved till CA -27.6 Degs and then gave the following error. Courant Number mean: 0.00327122 max: 0.200576 deltaT = 5.94218e-06 Crank angle = -27.6924 CA-deg deltaZ = 6.52008e-05 clearance: 0.0190537 Piston speed = 10.9725 m/s diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 #0 Foam::error::printStack(Foam:stream&) #1 Foam::sigFpe::sigFpeHandler(int) #2 Uninterpreted: [0xfb1420] #3 void Foam::fvc::surfaceIntegrate<foam::vector<double> >(Foam::Field<foam::vector<double> >&, Foam::GeometricField<foam::vector<double>, Foam::fvPatchField, Foam::surfaceMesh> const&) #4 Foam::tmp<foam::geometricfield<foam::vector<double >, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::surfaceIntegrate<foam::vector<double> >(Foam::GeometricField<foam::vector<double>, Foam::fvPatchField, Foam::surfaceMesh> const&) #5 Foam::tmp<foam::geometricfield<foam::vector<double >, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::surfaceIntegrate<foam::vector<double> >(Foam::tmp<foam::geometricfield<foam::vector<doub le>, Foam::fvPatchField, Foam::surfaceMesh> > const&) #6 Foam::fv::gaussDivScheme<foam::tensor<double> >::fvcDiv(Foam::GeometricField<foam::tensor<double >, Foam::fvPatchField, Foam::volMesh> const&) #7 Foam::tmp<foam::geometricfield<foam::innerproduct< foam::vector<double>, Foam::Tensor<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::div<foam::tensor<double> >(Foam::GeometricField<foam::tensor<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&) #8 Foam::tmp<foam::geometricfield<foam::innerproduct< foam::vector<double>, Foam::Tensor<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::div<foam::tensor<double> >(Foam::GeometricField<foam::tensor<double>, Foam::fvPatchField, Foam::volMesh> const&) #9 Foam::tmp<foam::geometricfield<foam::innerproduct< foam::vector<double>, Foam::Tensor<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::div<foam::tensor<double> >(Foam::tmp<foam::geometricfield<foam::tensor<doub le>, Foam::fvPatchField, Foam::volMesh> > const&) #10 Foam::compressible::turbulenceModels::kEpsilon::di vRhoR(Foam::GeometricField<foa m::vector<double>, Foam::fvPatchField, Foam::volMesh>&) const #11 main #12 __libc_start_main #13 __gxx_personality_v0 at ../sysdeps/i386/elf/start.S:122 Floating point exception Can any one point out how i can resolve the same? Regards, |
November 20, 2007, 00:27 |
Ok. I was using a hybrid mesh
#34 |
N S Prasad
Rep Power: 17 |
Ok. I was using a hybrid mesh tet + hex. i put in a little more effort and changed the entire mesh to hex. and the problem has been solved. i would like to put the sim video here. but dont have a clue as to how ..
(yes u can use tet mesh for engine mesh:-) urs, prasad. |
DieselEngineFoam | stefanke | OpenFOAM Pre-Processing | 42 | December 3, 2008 23:53 |
Strange pressure with dieselEngineFoam | tsencic | OpenFOAM Bugs | 1 | December 12, 2007 05:39 |
Start with DieselEngineFoam | tsencic | OpenFOAM Running, Solving & CFD | 20 | June 28, 2007 22:07 |
needing a udf for d(rho*h)/dt*dv??please help!! | Asghari | FLUENT | 0 | October 30, 2006 23:06 |
NEEDING SOME GOOD ARTICLE ABOUT CFD AND ITS APP.. | mahdi heidari | Main CFD Forum | 0 | October 9, 2001 06:13 |
