Problems calculating field gh with interFoam
Old   December 10, 2007, 08:17
Default I have cloned the dambreak cas
Christofer Ivarsson
cricke is on a distinguished road
I have cloned the dambreak case to fit my rotary kiln where a liquid floats from one end to the other in the reverse direction of the flame(cold flow). When executing the case it sotps just when about to calculate the field g.h(what is g.h?) this is what happends:
a403518@ENEPCST75:~/mesaBreak/0$ interFoam $HOME mesaBreak
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.4.1 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : interFoam /home/a403518 mesaBreak
Date : Dec 10 2007
Time : 12:49:43
Host : ENEPCST75
PID : 6894
Root : /home/a403518
Case : mesaBreak
Nprocs : 1
Create time
Create mesh for time = 0
Reading environmentalProperties
Reading field pd
Reading field gamma
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
--> FOAM FATAL ERROR : Not implemented#0 Foam::error::printStack(Foam:stream&) in "/home/a403518/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/a403518/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Foam::defaultFvPatchField<double>::defaultFvPatchF ield(Foam::fvPatch const&, Foam::DimensionedField<double,> const&) in "/home/a403518/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libfiniteVolume.so"
#3 Foam::fvPatchField<double>::addpatchConstructorToT able<foam::defaultfvpatchfield <double> >::New(Foam::fvPatch const&, Foam::DimensionedField<double,> const&) in "/home/a403518/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libfiniteVolume.so"
#4 Foam::fvPatchField<double>::New(Foam::word const&, Foam::fvPatch const&, Foam::DimensionedField<double,> const&) in "/home/a403518/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/interFoam"
#5 Foam::GeometricField<double,>::GeometricBoundaryFi eld::GeometricBoundaryField(Fo am::fvBoundaryMesh const&, Foam::DimensionedField<double,> const&, Foam::List<foam::word> const&) in "/home/a403518/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/interFoam"
#6 Foam::GeometricField<double,>::GeometricField(Foam ::IOobject const&, Foam::GeometricField<double,> const&, Foam::List<foam::word> const&) in "/home/a403518/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/interFoam"
#7 main in "/home/a403518/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/interFoam"
#8 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
#9 Foam::regIOobject::readIfModified() in "/home/a403518/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/interFoam"
From function defaultFvPatchField<type>::defaultFvPatchField(con st fvPatch& p, const DimensionedField<type,>& iF)
in file fields/fvPatchFields/basic/default/defaultFvPatchField.C at line 50.
FOAM aborting
Avbruten (SIGABRT) (core dumped)
What is wrong here?
BR
Christofer Ivarsson
cricke is offline   Reply With Quote
Getting a concentration field around a bubble in InterFoam azman OpenFOAM Running, Solving & CFD 3 June 7, 2022 05:21
Calculating Interface Area with InterFoam gopala OpenFOAM Running, Solving & CFD 28 December 23, 2021 03:51
How to modify interFoam to keep a constant velocity field thibault_pringuey OpenFOAM 0 January 9, 2009 06:59
Problem with the pressure field using interFoam zoune OpenFOAM Running, Solving & CFD 20 February 4, 2008 19:42
Problems with foamLog and interFoam OF 14 sinusmontis OpenFOAM Bugs 2 June 1, 2007 09:57
