Pressure outlet boundary condition
Like Tree18Likes
Old   February 2, 2013, 13:11
mohsen cheraghi
mohsen cheraghi is on a distinguished road
Hi
you should type what is at line 30-32, to see what is wrong with it.
mohsen cheraghi is offline   Reply With Quote
Old   February 2, 2013, 13:30
Default Reply
  #22
Anonymous
Industrial_CFD is on a distinguished road
OUTLET
type fixedMeanValue;
meanValue 0;
Seems like it can't find the new fixedMeanValue BC.
Industrial_CFD is offline   Reply With Quote
Old   February 2, 2013, 13:37
Lieven
Lieven will become famous soon enough
Don't forget to load the library in the system/controldict
If you did this already, check the terminal output for warnings. I don't recall the warning exactly but it's something like 'Warning: could not load library'...
Cheers,
L
Lieven is offline   Reply With Quote
Old   February 2, 2013, 17:35
Default Reply
  #24
Anonymous
Hi Lieven,
It wouldn't load. It said the library could not be found. I followed the directuions to the letter. Is there anything else I have to do?
Cheers: Adam
Old   February 2, 2013, 19:17
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
It looks like you're install is in /opt and that looks like the Ubuntu package install. If so, it may be worthwhile to move to the git version of OpenFOAM and compile the whole thing yourself. Some good instructions are here. I think the ubuntu package is great if you want to quickly run things and get a feel for OpenFOAM, but if you are going to do more complicated stuff....i would move on and recompile it yourself. Its not very difficult at all and the link I provided will get you through no problem. Plus its fun
chegdan is offline   Reply With Quote
Old   February 2, 2013, 19:30
Anonymous
Hi Dan,
I downloaded two .C files for fixedMeanValue and one header file. See attached.
When I run wmake libso finiteVolume I get the following errors....which file should be in my 'files' list....
Unfortunately I don't have time to recompile OpenFOAM.
I would really appreciate your advice though.
Cheers
Old   February 3, 2013, 13:51
Default Errors
  #27
Anonymous
Here are the errors I get after trying to compile:
SOURCE=fields/fvPatchFields/derived/fixedMeanValue/fixedMeanValueFvPatchFields.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam210/src/triSurface/lnInclude -I/opt/openfoam210/src/meshTools/lnInclude -I/opt/openfoam210/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam210/src/OpenFOAM/lnInclude -I/opt/openfoam210/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/fixedMeanValueFvPatchFields.o
In file included from fields/fvPatchFields/derived/fixedMeanValue/fixedMeanValueFvPatchFields.C:29:0:
fields/fvPatchFields/derived/fixedMeanValue/fixedMeanValueFvPatchFields.H:48:27: error: expected constructor, destructor, or type conversion before ‘(’ token
fields/fvPatchFields/derived/fixedMeanValue/fixedMeanValueFvPatchFields.C:40:1: error: ‘fixedMeanValueFvPatchScalarField’ has not been declared
fields/fvPatchFields/derived/fixedMeanValue/fixedMeanValueFvPatchFields.C:40:1: warning: unused variable ‘Foam::debug’ [-Wunused-variable]
fields/fvPatchFields/derived/fixedMeanValue/fixedMeanValueFvPatchFields.C:40:1: error: ‘fixedMeanValueFvPatchScalarField’ was not declared in this scope
fields/fvPatchFields/derived/fixedMeanValue/fixedMeanValueFvPatchFields.C:40:1: error: template argument 1 is invalid
fields/fvPatchFields/derived/fixedMeanValue/fixedMeanValueFvPatchFields.C:40:1: error: invalid type in declaration before ‘;’ token
fields/fvPatchFields/derived/fixedMeanValue/fixedMeanValueFvPatchFields.C:40:1: error: ‘fixedMeanValueFvPatchVectorField’ has not been declared
fields/fvPatchFields/derived/fixedMeanValue/fixedMeanValueFvPatchFields.C:40:1: error: ‘fixedMeanValueFvPatchVectorField’ was not declared in this scope
fields/fvPatchFields/derived/fixedMeanValue/fixedMeanValueFvPatchFields.C:40:1: error: ‘fixedMeanValueFvPatchSphericalTensorField’ has not been declared
fields/fvPatchFields/derived/fixedMeanValue/fixedMeanValueFvPatchFields.C:40:1: error: ‘fixedMeanValueFvPatchSphericalTensorField’ was not declared in this scope
fields/fvPatchFields/derived/fixedMeanValue/fixedMeanValueFvPatchFields.C:40:1: error: ‘fixedMeanValueFvPatchSymmTensorField’ has not been declared
fields/fvPatchFields/derived/fixedMeanValue/fixedMeanValueFvPatchFields.C:40:1: error: ‘fixedMeanValueFvPatchSymmTensorField’ was not declared in this scope
fields/fvPatchFields/derived/fixedMeanValue/fixedMeanValueFvPatchFields.C:40:1: error: ‘fixedMeanValueFvPatchTensorField’ has not been declared
fields/fvPatchFields/derived/fixedMeanValue/fixedMeanValueFvPatchFields.C:40:1: error: ‘fixedMeanValueFvPatchTensorField’ was not declared in this scope
make: *** [Make/linux64GccDPOpt/fixedMeanValueFvPatchFields.o] Error 1
Old   February 4, 2013, 03:42
Lieven
Ok,
seems to me you're missing two files. You can find them in the attachment.
Cheers,
Lieven
Old   February 4, 2013, 11:01
Anonymous
Thanks Lieven,
I put the files in the correct place, and I am recompiling now....hopefully it works.
I really appreciate all of your help on this one. This type of BC should be a standard BC in OpenFOAM, it's much more stable. There is a reason commercial solvers usually implement this; you need robustness when working on real problems.
Thanks again,
Cheers: Adam
Old   February 4, 2013, 11:49
Default Update
  #30
Anonymous
I tried to re-compile, but I get an error related to /platforms/linux64gcc/lib
It seems to have trouble compiling libFiniteVolume.so
/opt/openfoam210/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: file not recognized: File truncated
collect2: ld returned 1 exit status
make: *** [/opt/openfoam210/platforms/linux64GccDPOpt/lib/libfiniteVolume.so] Error 1
The rest of the compilation seemed to go well.
Man, this is a struggle.
Before you did an ./Allwmake, is there a clean command I need to use?
I was just using a wmake on the finiteVolume lib. (wmake libso finiteVolume/)
Cheers: Adam
Old   February 4, 2013, 12:27
Daniel P. Combest
Do you have all the required packages to compile OpenFOAM? My previous suggestion contains a link to a page with instructions (here are the instructions). There they provide the packages:
sudo apt-get install build-essential flex bison cmake zlib1g-dev qt4-dev-tools libqt4-dev gnuplot libreadline-dev libncurses-dev libxt-dev
If you have all of these then you might want to navigate to the finiteVolume folder and then do
wclean libso
then do a
wmake libso
these where the suggestions on the thread (http://www.cfd-online.com/Forums/ope...tallation.html)
Lastly, compiling really does not take any time at all. The instructions are really straightforward and If you do this while you are gone to lunch....if will be done by the time you get back. Over the last few years, OpenFOAM has really become much better at compiling with the set of provided instructions...extend and standard OpenFOAM alike. Good luck!
Old   February 4, 2013, 13:02
Default Reply
  #32
Anonymous
Hi Dan,
Followed the instructions and got the same error.
I can't figure out why the file would be truncated....it's like it got to large..
Cheers
Old   February 4, 2013, 13:12
Daniel P. Combest
on the thread I provided, the problem was solved with the ubuntu package binutils-dev.
I will install the ubuntu package and try to install this myself the way you are doing it.
Old   February 4, 2013, 17:04
Default Solved
  #34
Anonymous
I realized the other posts related to compiling the new BC in a local directory, whereas I compiled it in the /SRC directory. I simply removed the additional lines suggested by the OPs in the /files and /options dictionaries.
To recap:
1. Make sure you contain all 4 files needed for fixedMeanValue pressure BC.
2. follow directions suggested by chegdan in his first post.
Chegdan,
Thanks for all of your help. Sincerely appreciated.
Cheers
Old   February 4, 2013, 17:36
Daniel P. Combest
excellent...Good luck in your work!
Old   March 26, 2013, 11:07
Default Pressure and speed outlet unknown
  #36
gironidegirona is on a distinguished road
Hi all my name is Sergi and I'm trying to simulate a flow inside a tube with water (interFoam) and what I want to do is to check the difference between the outlet and inlet pressure to purge the system or not.
The thing is that I don't know which kind of boundary condition do I have to set on the outlet in order to allow the program calculate the pressure with respect the speed or whatever.
Any ideas?
Thanks!
gironidegirona is offline   Reply With Quote
Old   April 4, 2013, 06:30
Petr Vaněk
vanekp is on a distinguished road
Dear Foamers,
I'd like to add the BC fixedMeanValue into my OpenFOAM 2.1.x, but I can't put it into $FOAM_SRC/finiteVolume/fields/fvPatchFields and re-compile (as suggested above) since I'm working on a cluster and I don't have permission to write there. I'm not at all advanced in "all this compiling bussiness". So is there a way to go around it?
Thank you so much for a help!
vanekp is offline   Reply With Quote
Old   April 4, 2013, 07:34
immortality's Avatar
Ehsan
immortality is on a distinguished road
is it compilable in of 2.2.0?
immortality is offline   Reply With Quote
Old   April 4, 2013, 12:01
Ehsan
is fixedMeanValue applicable in groovyBC?
which files should be download for compiling in OF 2.2.0?
Old   April 4, 2013, 12:34
Daniel P. Combest
@immortality: Just to quadruple check if I was crazy or not, I went through the thread, made a new fixedMeanValue from the information on this thread, and it works for OF-2.2.x. It literally took longer to write this post than to actually find out if it was compatible .
@vanekp if you have the capability of compiling your own solvers/application in your user directory on your cluster, you can use this BC. Just take the attached code, unzip in your user foam directory, move into the directory and do a
wmake libso
where you need to place
libs ( "libfixedMeanValue.so");
in your caseName/system/controlDict file. To use the code, in your case you are using the BC like
    outlet
	meanValue		0;
        value           uniform 0;
This code has been confirmed to work with 2.1.x and 2.2.x.
But there is a fixedMean boundary condition in 2.2.x that may be what you want also.
sina_mech, immortality and Aaron_L like this.
Outlet pressure boundary condition adamsview OpenFOAM Running, Solving & CFD 2 November 7, 2011 14:07
pressure outlet boundary condition Sastry FLUENT 4 February 19, 2011 02:33
Pressure outlet boundary condition jubs FLUENT 0 February 8, 2007 01:27
Pressure outlet boundary condition Rizwan FLUENT 1 March 6, 2006 08:07
Pressure outlet condition? David FLUENT 3 March 19, 2004 05:40
