Axisymmetric bodies wedgetype BCbs
Like Tree3Likes
Old   February 16, 2007, 04:32
Default Have you had a look at those f
  #21
Mattijs Janssens
mattijs is on a distinguished road
Have you had a look at those faces with zero area? (using e.g. foamToVTK) Are they at the axis?
Have a look at the collapseEdges utility. I think it will remove your 0 area face at the axis. (if they are quads)
mattijs is offline   Reply With Quote
Old   March 6, 2007, 15:18
Default Hello Mattijs: What is the
  #22
vatant is on a distinguished road
Hello Mattijs:
What is the fundamental difference betweeen an wedge type and cyclic type? If I consider an axi-symmetric grid (one cell thick) and impose wedge type condition, does OF compute in the rotational direction? For the same case, why doesnt a cyclic condition work?
Regards,
Vatant
vatant is offline   Reply With Quote
Old   March 16, 2007, 15:54
Default Hi all, I am new to OF so m
  #23
gianfilippo coppola
gfcoppola is on a distinguished road
Hi all,
I am new to OF so my question may be stupid, anyway, I am trying to simulate an axisymmetric opposed jet configuration, where each jet has a circular flange flat with the exit section. I am using icoFoam from FoamX and blockMesh to generate the mesh. Below is the blockMeshDict file:
arguments "/home/gcoppola/OpenFOAM/gcoppola-1.3/run/tutorials/icoFoam/counterflow" off;
convertToMeters 0.001;
vertices
(-14.5852 0 0)
(-0.297656 0 0)
(-0.297656 1.19063 -0.051984)
(-14.5852 1.19063 -0.051984)
(0.297656 0 0)
(0.297656 1.19063 -0.051984)
(14.5852 0 0)
(14.5852 1.19063 -0.051984)
(0.297656 100 -4.366094)
(-0.297656 100 -4.366094)
(-0.297656 1.19063 0.051984)
(-14.5852 1.19063 0.051984)
(0.297656 1.19063 0.051984)
(14.5852 1.19063 0.051984)
(0.297656 100 4.366094)
(-0.297656 100 4.366094)
blocks
hex (0 1 2 3 0 1 10 11) (39 20 1) simpleGrading (0.04 0.3 1)
hex (1 4 5 2 1 4 12 10) (10 20 1) simpleGrading (1 0.3 1)
hex (4 6 7 5 4 6 13 12) (39 20 1) simpleGrading (25 0.3 1)
hex (2 5 8 9 10 12 14 15) (10 395 1) simpleGrading (1 25 1)
edges
patches
empty axis
(0 1 1 0)
(1 4 4 1)
(4 6 6 4)
wedge back
(0 1 2 3)
(0 1 10 11)
(1 4 5 2)
(1 4 12 10)
wedge front
(4 6 7 5)
(4 6 13 12)
(2 5 8 9)
(10 12 14 15)
patch lx_inlet
(0 0 11 3)
patch rx_inlet
(6 6 7 13)
wall top_flange
(2 3 11 10)
(9 2 10 15)
wall btm_flange
(7 5 12 13)
(5 8 14 12)
patch outlet
(8 9 15 14)
mergePatchPairs
The axis of symmetry is along X, the radius along Y and the one cell thickness along Z. The mesh is quite corse and I do get the 'Severe skewness' warning.
When I run the simulation, the result seem to be much like the flow between 2D flanged jets, as the velocity between the flanges seem to be constant along the radius.
I also used another file, which gives the same result, but the FRONT and BACK (wedge) palnes are parallel for the flanges and at an angle for the jets.
I am very likely doing some very stupid mistake, and would appreciate if you could help.
Regards,
Gianfilippo
gfcoppola is offline   Reply With Quote
Old   December 28, 2007, 12:14
Default In my setup, the mesh is cylin
  #24
sek
Sung-Eun Kim
sek is on a distinguished road
In my setup, the mesh is cylindrical, covering the 180 deg sector in the azimuthal direction. As a result, I have wedge elements touching the axis of symmetry at r = 0. The axis is not a boundary in my setup. The solutions seems to converge fine. But the solutions near the axis are not quite what I expected, showing high velocity in the body wake where I expect typical wake velocity profiles. I used starToFoam to convert the mesh generated using GridGen. Has anyone had similar experience?
sek is offline   Reply With Quote
Old   January 7, 2008, 07:42
Default Sung-Eun, Did you solve you
  #25
egp
egp's Avatar
Eric Paterson
egp is on a distinguished road
Sung-Eun,
Did you solve your problem? If your domain is 180 deg, I don't think the wedge BC is appropriate. I would use the cyclic condition instead.
Eric
egp is offline   Reply With Quote
Old   January 7, 2008, 09:13
Default I haven;t reolved the problem
  #26
sek
Sung-Eun Kim
I haven;t reolved the problem yet. The solution converges and looks fine in the boundary layer. The velocity field in the wake at and near the axis looks wrong.
I'm using symmetry boundary for 0 and 180 deg plane. My question was about the treatments at r = 0. Apparently, the axis (r=0) is not a boundary in cell-centered unstructured FV . Yet, the solution behavior at and near the axis made me suspicious of whether it has anything to do with the treatments of the wedge-shaped cells touching the axis.
Old   October 22, 2010, 06:55
Default 5° wedge
  #27
T.D. is on a distinguished road
Hi guys,
Anyone has ideas about how to setup flow between two parallel disks, as an axi-symmetric flow problem.
i tried 5° wedge geometry, and applied a rotatingWallVelocity for Upper disk and zero fixedValue for lower and for the Outer side i applied a zero Gradient.
For pressure i applied all zeroGradient except for Outer i put fixedValue 0.
for the empty axis i put in U, p a zeroGradient also.
when i run with icoFoam, i got extraordinary nonlogic results. it didn't work!
Any Ideas?
help please
thanks a lot
T.D. is offline   Reply With Quote
Old   February 8, 2013, 00:35
Default Errorneous velocity while using wedge type BC for axisymmetric flow
  #28
Anant Diwakar
diwakaranant is on a distinguished road
Hi
I am solving axisymmetric flow problem of flow between two rotating cylinders using rhoCentralFoam. I generated the mesh in GMSH and converted it into openFoam using gmshToFoam utility.
But when I am running the simulation, I am getting non-zero radial velocity
near the outer rotating cylinder, which ideally should be zero.
The Uy and the velocity vector plots near the outer rotating wall
are attached.
The rotation is about X axis. Hence Uy is the radial velocity component.
Can some one tell why is this happening ?
Thanks
Anant
diwakaranant is offline   Reply With Quote
Old   February 8, 2013, 00:48
  #29
Anant Diwakar
Hi
are attached.
Thanks
Anant
Old   September 13, 2013, 05:20
anshul bansal
anshul bansal is on a distinguished road
anyone please tell me how i put my wedge patch for back and front face in 0/p,0/T,0/U files.
means i put like this
back
type wedge;
front
type wedge;
is it correct.?
actually i find this error when i run my c-d nozzle with rhoCentralFoam solver
--> FOAM FATAL IO ERROR:
patch type 'genericPatch' not constraint type 'wedge'
for patch back of field p in file "/home/anshu/OpenFOAM/anshu-2.2.1/run/tutorials/compressible/rhoCentralFoam/with_axis/0/p"
file: /home/anshu/OpenFOAM/anshu-2.2.1/run/tutorials/compressible/rhoCentralFoam/with_axis/0/p.boundaryField.back from line 41 to line 41.
From function wedgeFvPatchField<Type>::wedgeFvPatchField
const fvPatch& p,
const Field<Type>& field,
dictionary& dict
in file fields/fvPatchFields/constraint/wedge/wedgeFvPatchField.C at line 99.
FOAM exiting
anshul bansal is offline   Reply With Quote
Old   September 13, 2013, 05:28
This should help you:
http://openfoamwiki.net/index.php/Ma...s/AxiSymmetric
Regards,
T.D.
Old   September 16, 2013, 07:59
anshul bansal
thanx for ur reply.
first i have problem in checkMesh of my geometry.
i got this problem-
***Number of edges not aligned with or perpendicular to non-empty directions: 48277
<<Writing 20200 points on non-aligned edges to set nonAlignedEdges
what should i do?
i can send u my geometry file in your email .
*(i made my geometry in gambit and import in openfoam)
Old   September 23, 2013, 06:51
anshul bansal
Can anybody help me to put my boundary condition and patch field in c-d nozzle problem.
my boundary file is-
top
type wall;
nFaces 1000;
startFace 49825;
inlet
type patch;
nFaces 175;
startFace 50825;
outlet
type patch;
nFaces 175;
startFace 51000;
front
type wedge;
nFaces 2000;
startFace 51175;
back
type wedge;
nFaces 2000;
startFace 53175;
and intial (0 file) for pressure is --
internalField uniform 101325;
boundaryField
inlet
type fixedValue;
value uniform 235000;
outlet
type zeroGradient;
top
type zeroGradient;
back
type wedge;
front
type wedge;
File Type: gz U.tar.gz (489 Bytes, 1 views)
File Type: gz T.tar.gz (490 Bytes, 1 views)
Old   January 13, 2015, 07:25
Rok
Rokerda is on a distinguished road
Originally Posted by hjasak View Post
Please make sure that the front and back of the wedge are in two separate patches.
Enjoy,
Hrv
Thank you very much for this information. I have been struggling with my code for a few days now
Rokerda is offline   Reply With Quote
Old   July 4, 2016, 05:55
openfoammaofnepo is on a distinguished road
Hi All,
For the boundary condition "wedge" in OpenFOAM, how is it treated when the numerical fluxes are computed? Are they actually assumed that there are no any fluxes (i.e. convection, molecular and turbulent diffusions) across the wedge face?
I checked the source file as follows, but did not find any information in it about how the numerical flues on them.
https://github.com/OpenFOAM/OpenFOAM...FvPatchField.C
Do you kow where I can find the relevant information in the source files? Thank you.
OFFO
openfoammaofnepo is offline   Reply With Quote
Old   August 22, 2016, 08:20
dzordz is on a distinguished road
Originally Posted by anshul bansal View Post
thanx for ur reply.
i got this problem-
what should i do?
Hi Anshul,
what I found out is that when I create a geometry with snappyHexMesh (don't know if it is the same with Gambit) the front and back are not identical! So I get the same error when using extrude wedge. So what I do first is a linear extrude in one direction, so the both front and back patches are identical. Then you do wedge extrude and this should no longer be a problem.
Cheers.
dzordz is offline   Reply With Quote
Old   October 11, 2016, 20:39
Dear Eric,
Have you got the idea about the wedge boundary conditions implemented in OpenFOAM? I mean the governing equation in Cartersian coordinate system is solver, but the transformation for the BC is applied and then this small wedge can be used to represent the axisymmetric problem. Could you please comment the transformation implemented in OF? Thank you so much.
Originally Posted by egp View Post
OF community,
I've recently begun experimenting with OF, and am posting my first question to the message board.
When simulating flow over an axisymmetric body, the User Manual (U-145, U-146) specifies that the wedge-type cells must be 5 degrees, and must straddle one of the coordinate planes.
What is the reason for this restriction?
So that I can understand the implementation, where would I look in the source?
Thank you,
Eric Paterson
Penn State Univ
State College, PA USA
Old   March 14, 2023, 03:40
Jie
jiejie is on a distinguished road
Originally Posted by openfoammaofnepo View Post
Dear Eric,
Interested to know the how the governing equation in Cartesian is handled for the wedge boundary conditions?
jiejie is offline   Reply With Quote
[Gmsh] Gmsh problem with cyclic bcbs sripplinger OpenFOAM Meshing & Mesh Conversion 1 September 28, 2010 10:29
Implementing new bcbs srinath OpenFOAM 3 September 3, 2008 06:11
Basics of setting up BCbs question shawn OpenFOAM Running, Solving & CFD 0 December 15, 2006 14:23
BCbs for high Renumbers gjesing OpenFOAM Running, Solving & CFD 10 May 7, 2006 10:51
CFD code about axisymmetric bodies at hypersonic speeds Afshin Azari Main CFD Forum 5 October 26, 1998 18:09
