Error message using simpleFoam
Old   January 22, 2008, 08:46
Default Dear OpenFOAMers ! I have to
Paul Mauk
plmauk is on a distinguished road
Dear OpenFOAMers !
I have to solve following 3D case:
An oil-separator (cylindric) with an inlet and an outlet. In the middle of the cylinder, orthogonal to inlet and outlet, is a wall with three holes.
The case is steady-state end incompessible.
I've imported the mesh using fluent3DToFoam.
After setting of boundaries and fields I've tried to solve the case, but after 5th step I've got this error message:
DILUPBiCG: Solving for Uz, Initial residual = 0.763052, Final residual = 0.0167024, No Iterations 1
DICPCG: Solving for p, Initial residual = 0.999999, Final residual = 0.00708348, No Iterations 6
time step continuity errors : sum local = 4.39313e+18, global = 1.0218e+09, cumulative = 1.03986e+09
DILUPBiCG: Solving for epsilon, Initial residual = 0.301803, Final residual = 0.0169611, No Iterations 1
bounding epsilon, min: -4.798e+38 max: 9.64908e+39 average: 2.0208e+35
DILUPBiCG: Solving for k, Initial residual = 0.999984, Final residual = 0.0765404, No Iterations 1
bounding k, min: -8.59358e+23 max: 1.8615e+36 average: 6.48023e+30
ExecutionTime = 391.6 s ClockTime = 400 s
Time = 6
DILUPBiCG: Solving for Ux, Initial residual = 0.00270419, Final residual = 7.71289e-05, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.000217164, Final residual = 6.79371e-06, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 0.0647357, Final residual = 0.0015476, No Iterations 1
#0 Foam::error::printStack(Foam:stream&) in "/home/cfduser/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/cfduser/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted: [0x110420]
#3 Foam::DICPreconditioner::calcReciprocalD(Foam::Fie ld<double>&, Foam::lduMatrix const&) in "/home/cfduser/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#4 Foam::DICPreconditioner::DICPreconditioner(Foam::l duMatrix::solver const&, Foam::Istream&) in "/home/cfduser/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#5 Foam::lduMatrix::preconditioner::addsymMatrixConst ructorToTable<foam::dicprecond itioner>::New(Foam::lduMatrix::solver const&, Foam::Istream&) in "/home/cfduser/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#6 Foam::lduMatrix::preconditioner::New(Foam::lduMatr ix::solver const&, Foam::Istream&) in "/home/cfduser/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#7 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/cfduser/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#8 Foam::fvMatrix<double>::solve(Foam::Istream&) in "/home/cfduser/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libfiniteVolume.so"
#9 main in "/home/cfduser/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/simpleFoam "
#10 __libc_start_main in "/lib/libc.so.6"
#11 Foam::regIOobject::readIfModified() in "/home/cfduser/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/simpleFoam "
what's wrong?
plmauk is offline   Reply With Quote
SimpleFoam Error with librdmacm amp libibverbs dnomdec OpenFOAM Running, Solving & CFD 1 May 21, 2010 09:02
SimpleFoam error sven82 OpenFOAM Running, Solving & CFD 0 October 16, 2008 05:13
Error running simpleFoam in parallel skabilan OpenFOAM Running, Solving & CFD 2 August 29, 2008 10:42
SIMPLEFOAM ERROR ON A RAE2822 dinonettis OpenFOAM Running, Solving & CFD 0 April 28, 2008 10:50
SimpleFoam error message braennstroem OpenFOAM Running, Solving & CFD 1 October 15, 2007 13:33
