Array of fields
Old   July 26, 2005, 11:32
Default Hi, How can I create an arra
Radu Mustata
r2d2 is on a distinguished road
How can I create an array of volScalFields in one CreatFields.H, say of oodles? Say field[i], i = 0,10...Is there an example somewhere?
Cheers,
Radu
r2d2 is offline   Reply With Quote
Old   July 26, 2005, 11:38
Default Try creating a ptrList of them
henry is on a distinguished road
Try creating a ptrList of them.
henry is offline   Reply With Quote
Old   July 26, 2005, 12:17
Default Thanks for the message, Henry.
Radu Mustata
I thought of something like this in CreateFields.H.
const int nVarmax = 10;
for (int i =0; i<nVarmax; i++)
word fieldName = "name_of_field"[i]
volScalarField field[i]
IOobject
fieldName,
runTime.timeName(),
mesh,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
mesh
Still have to sort out the "name_of_field"[i] and field[i] bits...
Cheers,
Radu
Old   July 26, 2005, 15:08
Default Try something like ptrList<
Mattijs Janssens
mattijs is on a distinguished road
Try something like
ptrList<volscalarfield> fields(10);
for (i=0 ...)
word fieldName = "field_" + Foam::name(i);
fields.hook(new volScalarField(IOobject(...))
See e.g foamToVTK.C, call to readFields (though is templated)
mattijs is offline   Reply With Quote
Old   July 27, 2005, 09:52
Default OK, thanks. I did the followin
Radu Mustata
OK, thanks. I did the following:
for (int i =0; i<10; i++)
Info<< "Reading field " << fieldName<< endl;
fields.hook(
volScalarField
IOobject
fieldName,
runTime.timeName(),
mesh,
mesh
So now if I want to solve an, say, convection diffusion eq + source term with one such field (actually all of them) what do I refer to in the ddt, div and laplacian operators? This is kind of what I want:
solve
fvm::ddt(fields(i))
+ fvm::div(phi,fields(i))
- fvm::laplacian(sgsModel->nuEff(),fields(i))
Many thanks,
Radu
Old   July 27, 2005, 09:58
Default you should loop over the field
you should loop over the fields and use fields[i] rather than fields(i).
Old   September 12, 2005, 08:48
Default Hi again, I´m back with my lit
Radu Mustata
Hi again, I´m back with my little problems.
Having done what I was taught to do above, and the things work fine with no source term I would like now to add some source for each field and then to calculate at run time a "mean field" (mean wrt the number of fields) and write it out.
Thought of doing in the body of oodles.C:
volScalarField meanFields;
for (int i =0; i<10; i++){
meanFields +=fields[i];
meanFields /=10;
...but doesn´t seem to work. Should I do something like in createAverages.H and calculateAverages.H?
Thanks,
Radu
Old   September 12, 2005, 14:47
Default doesn't it compile? Where? Fai
Mattijs Janssens
doesn't it compile? Where? Fail during running? Where?
You will need to define your volScalarField properly (so with an IOobject and mesh etc.).
Old   January 31, 2007, 17:50
Default Hi everybody, is it possibl
diego n.
diegon is on a distinguished road
Hi everybody,
is it possible to use PtrList with Matrix<scalar>?
Thanks in advance
Diego
diegon is offline   Reply With Quote
Old   January 29, 2008, 15:28
Default Sorry for the stupid question,
C.E.M.
evan is on a distinguished road
Sorry for the stupid question, but I am trying to use a ptrlist (parameter list?) in createfields.H. I have:
PtrList<volscalarfield> nu(Y);
for (int i=0, i<Y.size(); i++)
word nui = "nu_" + Foam::name(i);
Info << "Reading Field << nui << endl;
nu.set
volScalarField
IOobject
nui,
runTime.timeName(),
mesh,
mesh
And when I compile I get:
error: no matching function for call to "Foam::PtrList< ... etc ..."
Would somebody mind explaining to me what I'm doing wrong here?
Evan
evan is offline   Reply With Quote
Old   January 29, 2008, 15:46
Default Eeeeasy! http://www.cfd-online
  #11
Hrvoje Jasak
Eeeeasy! Do:
nu.set
i,
new volScalarField
See it - you need and index and a new in front of volScalarField.
Enjoy,
Hrv
Hrvoje Jasak
Old   January 30, 2008, 13:40
Default Neat. Thanks Hrv! I hope you
  #12
C.E.M.
Neat. Thanks Hrv! I hope you can forgive my programming ignorance ... you should have seen me a year ago ! Seems I spend a lot of time enjoying your text, most recently Numerical Solution Algorithms ..., and am excited to take a closer look at this new coupledFvScalarMatrix class!
I posted the below question yesterday in "Running / Solving / CFD: Pollutant dispersion in the environment" too, though it seems related to this thread, and maybe this is a more appropriate venue for the question, so let me copy it here, and sorry for double posting.
Hi all,
So to revisit the question raised by Alberto, does anyone know (or be
willing to discuss) how to make an indexed list of constants that is
read from a dictionary. So, the diffusivity example Alberto brought up
would work great. That is, say you have n diffusion constants listed
in your constants dictionary as:
dimensionedScalar D1 (dictionary.lookup("D1")); . . . dimensionedScalar Dn (dictionary.lookup("DY"));
but you want to index them in your solver (along with other indexed
fields) as:
for(label i=0; i<n; i++)
volScalarField& Yi = Y[i];
// call D[i] list here
solve
fvm::ddt(Yi)
+ fvm::D[i]*fvm::laplacian(Yi)
etc.
Or is there a better way about going about this? Mattijs' suggestion
from before is currently over my head .
Best,
Evan
array in UDF Kamal FLUENT 1 November 7, 2013 02:15
can we initialize an array in UDF? blueberry Fluent UDF and Scheme Programming 2 April 14, 2009 13:00
CFD for photovoltaic array Achmadi Main CFD Forum 1 May 21, 2007 05:42
??cfx5.6 array name?? Erica CFX 0 December 28, 2004 08:28
array initialization Ossi Siemens 1 February 20, 2004 12:07
