How to write a solver beginner
Old   January 31, 2008, 11:56
Default Hi Manuel. Thanks for your
  #21
Hyunchang Lee
asteria is on a distinguished road
Hi Manuel.
Thanks for your reply.
You're right! I'm solving coupled equations.
I'll contact alberto.
Good luck to your work!!!
kind regards,
Hyunchang
asteria is offline   Reply With Quote
Old   January 31, 2008, 15:00
Default Hi again Dragos! I probe wi
  #22
Antonieta Silva
antopnieta is on a distinguished road
Hi again Dragos!
I probe with laplacianFoam solver, and my program run, but when I see the results in paraview, nothing change... the temperature behavior is always the same, don't change with time...
I review all, and I don't know what's wrong...
If you have an idea of which can be my mistake, i will be grateful.
Antonieta
antopnieta is offline   Reply With Quote
Old   January 31, 2008, 16:05
Default If you start from a constant t
  #23
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
If you start from a constant temperature field and the same value for the boundaries, then nothing should change, but this is just a guess since I don't know your settings.
What is your initial field and what are the values at the boundaries?
Dragos
dmoroian is offline   Reply With Quote
Old   January 31, 2008, 16:17
Default The inside of the sphere is a
  #24
Antonieta Silva
The inside of the sphere is a 1000 and the surface a 100. With this values, the sphere should be colder... but nothing happen.... Ah! my DT=1.477E-5.
Antonieta
i am beginner for cfd robbin CFX 1 December 31, 2005 12:54
Beginner question OddEven Decoupling in SIMPLE Solver brooksmoses OpenFOAM Running, Solving & CFD 2 November 9, 2005 20:38
beginner tzari Phoenics 0 December 2, 2003 04:39
Beginner Subash Main CFD Forum 1 September 16, 2003 01:35
UDF Beginner M. A. Rakib FLUENT 1 June 6, 2000 12:23
