February 5, 2008, 10:52 |
Hi to all!
I have a problem
Michele Vascellari
Rep Power: 17 |
Hi to all!
I have a problem running a simple problem of mixed natural and forced convection in a square cavity, where the flow enters at the top of the cavity, and exits at the bottom of the opposite side (Blay cavity). The simulation runs without problem using upwind scheme for convective therms, but If I turn to second order scheme (limitedLinear) I obtain the following error: Create mesh for time = 2000 Reading environmentalProperties Reading thermophysical properties Selecting thermodynamics package hThermo<puremixture<consttransport<speciethermo<hc onstthermo<perfectgas>>>>> Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting turbulence model kEpsilon Calculating field g.h Creating field pd Starting time loop Time = 2001 DILUPBiCG: Solving for Ux, Initial residual = 0.0401578, Final residual = 2.36105e-06, No Iterations 4 DILUPBiCG: Solving for Uy, Initial residual = 0.891016, Final residual = 8.7564e-07, No Iterations 6 DILUPBiCG: Solving for h, Initial residual = 0.00604865, Final residual = 7.18185e-06, No Iterations 3 DICPCG: Solving for pd, Initial residual = 0.911804, Final residual = 7.97762e-09, No Iterations 86 time step continuity errors : sum local = 7.71829e-07, global = 1.66559e-09, cumulative = 1.66559e-09 rho max/min : 1.22225 1.14107 #0 Foam::error::printStack(Foam:stream&) in "/home/michele/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/michele/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #2 ?? in "/lib/libc.so.6" #3 Foam::DILUPreconditioner::calcReciprocalD(Foam::Fi eld<double>&, Foam::lduMatrix const&) in "/home/michele/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #4 Foam::DILUPreconditioner::DILUPreconditioner(Foam: :lduMatrix::solver const&, Foam::Istream&) in "/home/michele/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #5 Foam::lduMatrix::preconditioner::addasymMatrixCons tructorToTable<foam::dilupreco nditioner>::New(Foam::lduMatrix::solver const&, Foam::Istream&) in "/home/michele/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #6 Foam::lduMatrix::preconditioner::New(Foam::lduMatr ix::solver const&, Foam::Istream&) in "/home/michele/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #7 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/michele/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #8 Foam::fvMatrix<double>::solve(Foam::Istream&) in "/home/michele/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libfiniteVolume.so" #9 Foam::lduMatrix::solverPerformance Foam::solve<double>(Foam::tmp<foam::fvmatrix<doubl e> > const&) in "/home/michele/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libfiniteVolume.so" #10 Foam::compressible::turbulenceModels::kEpsilon::co rrect() in "/home/michele/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libcompressibleTurbul enceModels.so" #11 main in "/home/michele/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/buoyantS impleFoam" #12 __libc_start_main in "/lib/libc.so.6" #13 Foam::regIOobject::readIfModified() in "/home/michele/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/buoyantS impleFoam" Errore di virgola mobile Reducing under-relaxation coefficients the error still remain the same. The scheme used for the convective terms are the following: divSchemes { default none; div(phi,U) Gauss limitedLinear 1; div(phi,h) Gauss limitedLinear 1; div(phi,k) Gauss limitedLinear 1; div(phi,epsilon) Gauss limitedLinear 1; div(phi,R) Gauss linear; /* div(phi,U) Gauss upwind; div(phi,h) Gauss upwind; div(phi,k) Gauss upwind; div(phi,epsilon) Gauss upwind; div(phi,R) Gauss upwind;*/ div(R) Gauss linear; div((muEff*dev2(grad(U).T()))) Gauss linear; } Many thanks Michele |
February 6, 2008, 06:37 |
Solving the same problem with
Michele Vascellari
Rep Power: 17 |
Solving the same problem with buoyantFoam (PISO instead of SIMPLE) the second order discretization schemes works correctly.
Any ideas? Michele |
September 26, 2012, 11:28 |
Mixed Convection
n/a
Rep Power: 17 |
Good day Michele. Are you still working on mixed convection boundary layer flow? I ask such a question because it pertains to my research. I am having problems specifying boundary conditions for a vertically oriented flat plate with a incoming freestream velocity from the bottom.
Need help with 1st order FV scheme | Andrei Chernousov | Main CFD Forum | 1 | March 14, 2013 04:37 |
2nd Order Scheme for SimpleFoam | bastil | OpenFOAM Running, Solving & CFD | 0 | February 22, 2009 17:20 |
High order FVM scheme .... | cfd_newbie | Main CFD Forum | 2 | February 6, 2008 07:46 |
High order FVM scheme .... | cfd_newbie | FLUENT | 0 | February 4, 2008 14:43 |
FVM-higher order scheme | K S Chang | Main CFD Forum | 6 | December 9, 2003 11:26 |
