February 5, 2008, 22:31 |
I'm using a structur
Alberto Passalacqua
Rep Power: 36 |
I'm using a structured (orthogonal squared cells) grid, and I need to implement an algorithm which requires the values of a variable in the "above"/"below", "left"/"right", "front"/"back" cells. Is there a quick way to identify these cells?
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
February 6, 2008, 04:01 |
short answer: hmmm, sort of.
Niklas Nordin
Rep Power: 29 |
The fastest way as I see it is to access all the faces, check their face-normals and depending on their direction determine if they are left or right, et c. from that create a mapping of left -> face i, right -> face j, et c. (which of course require some mesh class hacking) you probably only need to do this once for a static mesh and after this it should be fast. |
February 6, 2008, 13:28 |
Hmmm. Thanks for your reply Ni
Alberto Passalacqua
Rep Power: 36 |
Hmmm. Thanks for your reply Niklas.
I have a doubt on how the boundary cells are managed. I mean, I have 4 neighbours for the "internal" cells, but only 2 or 3 for the boundary cells, which are exceptions because they have one or more lacking "directions". How that procedure can identify them? Regards, Alberto
elliptic grid generation (orthogonal) | vasu | Main CFD Forum | 8 | October 28, 2015 16:20 |
[Other] 3D curvlinear orthogonal bodyfitted grid | maka | OpenFOAM Meshing & Mesh Conversion | 1 | February 13, 2014 13:17 |
orthogonal grid generation | Bounecer | Main CFD Forum | 2 | July 9, 2007 01:06 |
Poisson solver - orthogonal grid | Fuka | Main CFD Forum | 0 | May 11, 2006 12:19 |
2-D orthogonal grid generation | Jenny Rhong | Main CFD Forum | 3 | February 10, 2004 20:51 |
