February 11, 2008, 12:48 |
I was trying to make
Kārlis Repsons
Rep Power: 17 |
I was trying to make some test mpirun as described in UserGuide, but ran into problems. Before I try to make that work, I want to ask, if it is enough to 1. copy OF, 2. make successful foamInstallationTest on both PCs and then use mpirun as described in UserGuide? This far I couldn't make second PC's ssh work for some reason and got "bash: orted: command not found" on first. Kārlis |
February 11, 2008, 13:49 |
Karlis,
I'd suggest the fo
Michael Jaworski
Rep Power: 17 |
Karlis,
I'd suggest the following steps: 1. Make sure you can ssh in and out of both computers. 2. Make sure the openFOAM bashrc is sourced as part of your home .bashrc file (as indicated in the directions for install of OF) 3. Visit the openMPI website and make sure you set up ssh with a secure key so you don't have to enter a password. 4. Use the openMPI website's "hello world" test program to make sure openMPI can communicate and interconnect. 5. Make sure your root file structures are properly listed when you test mpirun with an OpenFOAM solver. Best of luck, Mike |
February 11, 2008, 14:40 |
Mike,
what you mean by "root
Kārlis Repsons
Rep Power: 17 |
Mike,
what you mean by "root file structures" listing? |
February 11, 2008, 14:53 |
Karlis,
When you pass a co
Michael Jaworski
Rep Power: 17 |
Karlis,
When you pass a command using mpirun, you have the possibility that your local executable and the remote one are in different locations. You need to tell your remote machine where to find the executable for it to work. In OF, when you distribute the files you do this in the decomposeParDict file and by sourcing the bashrc automatically on login, this adds OF to the path on the machine. I suppose it would have been more accurate to say that you should make sure you have all your PATH variables set correctly. Hope that helps. -Mike J. |
Solving Consecutive-Parallel reaction | vicky | Main CFD Forum | 1 | February 25, 2009 03:39 |
Why solving | kar | OpenFOAM Running, Solving & CFD | 2 | April 30, 2008 16:15 |
P U T field solving in solid and liquid two meshes In parallel | kar | OpenFOAM Running, Solving & CFD | 2 | February 20, 2008 06:18 |
Multiple Region and Parallel Solving | panara | OpenFOAM Running, Solving & CFD | 2 | October 6, 2006 04:06 |
parallel solving | Ivan | CFX | 2 | November 1, 2005 02:27 |
