How to specify BCs to solve a Poiseuille flow |
February 11, 2008, 15:01 |
I was trying to solv
Kārlis Repsons
Rep Power: 17 |
I was trying to solve a parabolic flow in 2D square-like domain. * In blockMeshDict and boundary file I specified just "patch" for inlet and outlet, * In /0/U I set zeroGradient on in/out, (0 0 0) on walls + empty * In /0/p I set fixedValue on in/out, zeroGradient on walls + empty. But.... solution obviously diverge. Aren't those BCs sufficent to describe a problem? I think, I don't understand how to set BCs in OpenFOAM, for example - why should I use physicalType? Maybe you can advice something useful at least for that poiseuille flow? |
February 11, 2008, 15:55 |
Oh, I see a parabolic velocity
Kārlis Repsons
Rep Power: 17 |
Oh, I see a parabolic velocity distribution now and it feels so good! The problem was - I forgot to take into account a fact, that for icoFoam pressure must be divided by density. So I tried to solve for 1000 times greater pressure!
Maybe I'll see somewhere else why physicalType should be specified... |
February 11, 2008, 17:14 |
I checked solution more carefu
Kārlis Repsons
Rep Power: 17 |
I checked solution more carefully and .. trouble doesn't stop - I have almost exactly 2x greater U values comparing with analytical!
So in SI: nu = 1e-4, geometry: dx=0.01, dy=0.1, dz=0.001, flow is in y direction, delta p = 0.016 (divided by ro) According to wikipedia, Umax = 0.01. But solution gives 0.02!! How come? |
February 11, 2008, 18:12 |
Hi Karlis
The Poiseuille-fl
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Karlis
The Poiseuille-flow I could find on wiki (please add link in the future), was for a circular pipe flow. Your setup is for a 2D case, i.e. Poiseuille flow between two flat plates. The ratio between u_max in these two cases is exactly a factor of 2. / Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
February 12, 2008, 04:07 |
Thank you, Niels!
I was think
Kārlis Repsons
Rep Power: 17 |
Thank you, Niels!
I was thinking in a quick way - take a plane of cylinder and calculate for it.. Actually different problem is solved in such way. |
Incompressible laminar poiseuille flow | samarth | OpenFOAM Running, Solving & CFD | 20 | July 13, 2010 04:38 |
Basic Poiseuille flow simulation question | Ashish | Main CFD Forum | 0 | October 2, 2007 14:05 |
Poiseuille flow | Kirikou | Main CFD Forum | 0 | November 23, 2006 14:32 |
Simple Poiseuille flow | Maggie | CFX | 0 | May 27, 2004 11:58 |
Poiseuille flow problem | Rosie | FLUENT | 1 | December 6, 2002 17:52 |
