Dimension problem
Old   November 24, 2006, 21:25
Default I am getting the following err
Faroque Hossain
faroque is on a distinguished road
I am getting the following error.
--> FOAM FATAL ERROR : incompatible dimensions for operation
[U[0 1 -1 0 0 0 0] ] - [U[0 -1 0 0 0 0 0] ]
From function checkMethod(const fvMatrix<type>&, const fvMatrix<type>&)
in file /home/faroque/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude/fvMatrix.C at line 1024.
FOAM aborting
Foam::error::printStack(Foam:stream&)
Foam::error::abort()
./newApp [0x80525e5]
./newApp [0x8061e31]
./newApp [0x804f354]
__libc_start_main
__gxx_personality_v0
0Aborted
It seem to me problem in the dimension defition for my volScalarField variable. I defined variable dimension like follwoing:
dimension [0 0 0 1 0 0 0]
Could someone help me?
faroque is offline   Reply With Quote
Old   November 24, 2006, 21:29
Default Your error says the simulation
Hrvoje Jasak
Your error says the simulation has failed in the momentum equation - one of the terms you've added has got wrong dimensions.
Hrv
Hrvoje Jasak
Old   November 24, 2006, 21:56
Default Thanks for the reply. I have
Faroque Hossain
I have set the equation in following way..
solve
fvm::ddt(T) == fvm::laplacian(T)
where T is a volScalarField. Did I make any mistake here?
Faroque
Old   November 25, 2006, 10:20
Default Hi, there should be a trans
Stephan Gerber
stephan is on a distinguished road
there should be a transportcoefficient for temperatur in this kind of equation?!
sth like: a*ddt(T)=laplaceian(T),where a is sth like
rho*c/lambda.
otherwise your dimensions are K/s on the left side and K/m^2 on the right side.
for the value of the transport coefficient you should look i a textbook to find something for your material...
stephan
stephan is offline   Reply With Quote
Old   November 26, 2006, 07:39
Default hi, if u want to use the e
Adrian Magda
amagda is on a distinguished road
hi,
if u want to use the equation like that the code should looke like:
solve
fvm::ddt(T) - fvm::laplacian(
dimensionedScalar
"scal", dimensionSet(0, 2, -1, 0, 0), 1),
T)
Actually u just multiply with a scalar with unit value 1[m2/s]
Adrian
amagda is offline   Reply With Quote
Old   February 19, 2008, 09:56
Default Isn't there a way to tell the
John Deas
johndeas is on a distinguished road
Isn't there a way to tell the solver that space and time variables used for the derivation are dimensionless ?
johndeas is offline   Reply With Quote
Dimension problem with operation scale booz OpenFOAM Pre-Processing 0 October 10, 2008 04:57
Dimension problem with dyn LES models fabian_korn OpenFOAM Running, Solving & CFD 0 February 4, 2008 06:35
Is one dimension problem possible for Fluent alpha FLUENT 1 April 7, 2005 06:37
problem with grid dimension nisheet goyal Phoenics 1 June 18, 2001 10:28
