February 20, 2008, 20:46 |
Hi everyone,
running icoFoa
Patrick Bourdin
Rep Power: 17 |
Hi everyone,
running icoFoam on a 2D, corrugated, airfoil-like geometry, I obtained the following history for the vertical force: Freestream Re is 10^4. linearUpwind cellLimited leastSquares 1 was used for U, Laplacian schemes are linear corrected (mean non-Orthogonality of the mesh is 5 deg), Euler was used as temporal discretization. Max Co was always around 0.6-ish. Plotting the contours of p or U at different times does not highlight any noticeable unsteadiness. So, what do I observe, a truly unsteady signal or simply numerical noise (the oscillation is about 3% of the mean value). It's still there whether I reduce or increase the time step by one order of magnitude. I ran simpleFoam, starting from the latest time computed by icoFoam (t=100s), I still observe those oscillations but the magnitude of the mean force is 7% higher than with icoFoam. I used the laminarForceAndTorque library from Hrv to compute the forces. |
February 21, 2008, 05:07 |
Hi Patrick
For a circular c
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Patrick
For a circular cylinder exposed to a uniform flow, the r.m.s. value of the lift coefficient is different from zero and a function of Re, [1]. This might be the same thing you are observing. Try replacing your geometry with a cylinder and see if you get an value in the order of magnitude of 0.4 in the r.m.s value of the lift coefficient for Re_D=1e4. Best regards, Niels [1] Hydrodynamics Around Cylindrical Structures, B. Mutlu Sumer and Jørgen Fredsøe, Advanced Series on Coastal Enginnering, World Scientific, 1999
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
DPM unsteady particles history | Yasmail AKARIOUH | FLUENT | 4 | June 10, 2017 23:23 |
BASSET HISTORY FORCE | rana | FLUENT | 0 | February 15, 2008 05:18 |
Monitor Force in Unsteady Flow | Sham | FLUENT | 1 | August 4, 2007 06:39 |
Monitoring Force (Unsteady) | Emmanuel | FLUENT | 0 | July 9, 2007 19:42 |
Boussinesq/basset history force | Ritesh Chhabra | FLUENT | 0 | September 14, 2004 00:37 |
