Convective Schemes how are they implemented
Old   February 28, 2008, 11:44
Default Dear OF users and developers,
nicasch
nicasch is on a distinguished road
I would be very grateful if anyone could please provide some insight into the following divSchemes:
- Gauss limitedLinearV
- Gauss interfaceCompression.
I suppose that they do some kind of blending based on the blending factor (limiter) calculated according to the scheme used. Is this blending between linear UD and CD or something else?
I found a post containing the following:
Φf =ΦC +(xf – xC) *ψ(rf) * (dΦ/ dx)f
Or
Φf =ΦC +(xf – xC) / (xD– xC) *ψ(rf) * (ΦD-ΦC)
f ,the face
C,central node
D downwind node
ψ(rf) the flux limiter
rf is based on the following formula
rf=(ΦC-ΦU)/( ΦD-ΦC) = 2*grad(ΦC)*(xD-xC) /( ΦD-ΦC) -1
I get bit confused while trying to read the code, is there any written text about these two schemes, or can someone please explain how they work?
In limitedLinearV, I suppose that it is a kind of limited CD, but how is the scheme limited? Where is the limiter for this scheme used? Is the limiter function phi(r) used in calculation of the face value using adjacent cell-center values (like normal CD), or is it a blending between linear upwind and CD?
For the interfaceCompression scheme I suppose that it is some blending based on the blending factor calculated according to the either quartic or quadratic formula. Where is the limiter for this scheme used?
Many thanks in advance, best regards.
nicasch is offline   Reply With Quote
Old   November 4, 2010, 09:47
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Nicasch, have you finally found an explanation for interfaceCompression scheme? I'm struggling with the same question.
Regards
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Where is gSum implemented cosimobianchini OpenFOAM Running, Solving & CFD 2 June 7, 2022 15:27
GammaContactAngle not implemented coastal593 OpenFOAM Running, Solving & CFD 5 November 9, 2010 06:21
Convective schemes for vector fields edoardo OpenFOAM Running, Solving & CFD 6 February 16, 2009 12:05
Help for fourth order accurate convective schemes Z.C.Wang Main CFD Forum 0 January 15, 2009 07:53
Approximation Schemes for convective term Michail CFD-Wiki 10 July 31, 2006 15:33
