Compile error undefined reference to
Old   February 29, 2008, 11:46
Default Hi I am using the OpenFOAM
Andreas Mehrle
braveandi is on a distinguished road
Hi
I am using the OpenFOAM standard solvers for some now and did also modify them slightly and recompile. In order to understand the capabilities of OpenFOAM a little better I am about to build my own solver including lagrangian particles. But when I include some code used in "dieselSpray" or Bernhard Gschaider's "icoLagrangianFoam" I get the error message:
Make/linuxGccDPOpt/lagrangianFoam.o: In function `Foam::IOPtrList<foam::particleinjector>::type() const':
lagrangianFoam.C.text._ZNK4Foam9IOPtrListINS_16particleInjectorEE4 typeEv[Foam::IOPtrList<foam::p articleinjector>::type() const]+0x11): undefined reference to `Foam::IOPtrList<foam::particleinjector>::typeName '
when using a IOPtrList.
I did #include "IOPtrList.H" in the header file and my options file looks like
EXE_INC = \
-I$(LIB_SRC)/cfdTools/incompressible \
-I$(LIB_SRC)/cfdTools/general/lnInclude \
-I$(LIB_SRC)/OpenFOAM/lnInclude \
-I$(LIB_SRC)/finiteVolume/lnInclude \
-I$(LIB_SRC)/lagrangian/basic/lnInclude
EXE_LIBS = \
-lfiniteVolume \
-llagrangian
what is going wrong?
Andreas
braveandi is offline   Reply With Quote
Old   March 1, 2008, 10:04
Default hi, i am not sure but as fa
Stephan Gerber
stephan is on a distinguished road
hi,
i am not sure but as far as i remember the injector is part of the lagrangian/dieselspray and not of lagrangian/basic. that would explain the undef. ref. .
br
stephan
stephan is offline   Reply With Quote
Old   March 1, 2008, 12:08
Default Hi Andreas, As far as I can t
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Hi Andreas,
As far as I can tell, there is a class in your code, called "particleinjector" for which I could not find any reference in OpenFOAM. Is this class developed by you?
If it is, you need to include the object particleinjector.o in your options file.
Dragos
dmoroian is offline   Reply With Quote
Old   March 3, 2008, 04:49
Default Thx As Dragos suspected "pa
Andreas Mehrle
Thx
As Dragos suspected "particleInjector" is a self defined class so no need to include "lagrangian/dieselspray". So I will try to include the objectfile.
Andreas
Undefined reference mateusz_slowikowski OpenFOAM Running, Solving & CFD 7 February 27, 2015 15:35
Undefined reference to %60mainb seang OpenFOAM Installation 8 February 1, 2014 14:48
Undefined reference to %60yyFlexLexeryywrapb zhoubinwx OpenFOAM Bugs 1 May 28, 2008 06:57
Undefined reference mateusz_slowikowski OpenFOAM Running, Solving & CFD 3 March 11, 2008 13:19
MPICH : undefined reference to.. Vincent Siemens 3 March 24, 2005 13:30
