SimpleFoam as Newtonian laminar flow solver
Old   March 5, 2008, 12:37
Default Hi guys, I am using icoFoam
Antonio Martins
titio is on a distinguished road
Send a message via MSN to titio Send a message via Skype™ to titio
Hi guys,
I am using icoFoam to solve the laminar nwetonian flow in a contraction, to benchmark foam and to learn how to use it. Is it possible to use simpleFoam, a steady state solver, to do it, and if so, what should I do?
titio is offline   Reply With Quote
Old   March 5, 2008, 12:49
Default Yes, set the turbulence model
Hrvoje Jasak
Yes, set the turbulence model to laminar and choose appropriate transport model.
Enjoy,
Hrv
Hrvoje Jasak
Old   March 8, 2013, 05:44
Sita Drost
sita is on a distinguished road
Originally Posted by titio View Post
Hi guys,
Hi Titio,
Long, long time ago, you posted this message about you using icoFoam to solve Newtonian flow in a contraction.
I'm trying to do the same, but it just won't work; I keep getting strong oscillations just upstream of the contraction and then the calculation blows up. I already tried using an upwind scheme instead of a linear one, finer mesh, coarser mesh, smaller time step, etc. My Reynolds number is something far smaller than 1, so that shouldn't be the problem. Also, potentialFoam seems to work alright, although the streamlines seem a bit messy, but even using this solution as an initial condition doesn't help.
The same flow in viscoelasticFluidFoam runs without any trouble, so I tried using the same settings for fvSchemes and fvSolution in icoFoam, but without any result.
So, I was wondering, do you still remember how you solved your Newtonian contraction flow with icoFoam? Did you run into any problems?
Thanks in advance for your reply!
Regards,
Sita
sita is offline   Reply With Quote
Steady incompressible laminar flow using simpleFoam yongshenglian OpenFOAM Running, Solving & CFD 0 October 29, 2008 16:28
SimpleFoam as laminar solver anja OpenFOAM Pre-Processing 3 April 5, 2007 10:28
Newtonian fluid SimpleFoam nico OpenFOAM Running, Solving & CFD 4 January 10, 2006 05:27
SimpleFoam for laminar flow hsing OpenFOAM Running, Solving & CFD 3 April 14, 2005 15:39
Which solver for non-newtonian flow joel Siemens 2 June 28, 2002 13:25
