SonicFoam and SIMPLE
Old   January 15, 2008, 14:01
Default Does anyone know how to go abo
Laurence Griffiths
lgriffiths is on a distinguished road
Does anyone know how to go about adding a steady time stepping algorithm to the sonicFoam solver, or if its at all possible?
Is it possible to just replace PISO with SIMPLE algorithm, or is it not quite that easy?
lgriffiths is offline   Reply With Quote
Old   March 8, 2008, 11:28
Default A small help. Hi everybody,
N S Prasad
nsp82 is on a distinguished road
A small help.
Hi everybody,
I have been writing a finite Difference code for flow through a divergent section. The geometry is simple.
The lower boundary (wall) is a horizontal line 2mm long. The left boundary is a vertical line (extrapolated outlet) of length 0.4 mm. the right boundary (supersonic inlet) is a vetical line 0.3 mm long. the top boundary is an inclined line (wall) connecting left and right. The inlet is at 1000 m/s, 101325 pa and 298 K. fluid is ideal air.
Domain is split 200 times along x axis, evenly, and 100 times along y axis , evenly.
the pressure contour from sonicFoam is given below. and so is the output from my code.
http://enginesei.blogspot.com/2008/0...-contours.html
can you give your comments about which one is more correct ??
Thanks,
Prasad.
nsp82 is offline   Reply With Quote
SonicFoam stvtiegh OpenFOAM Running, Solving & CFD 1 June 26, 2008 10:30
SonicFoam error 21kalee OpenFOAM Running, Solving & CFD 6 January 2, 2008 15:00
SonicFoam 141dev changes what do they mean mike_jaworski OpenFOAM Running, Solving & CFD 0 December 30, 2007 16:55
New solver from sonicFoam dimi OpenFOAM Running, Solving & CFD 2 December 5, 2007 19:08
Help me with sonicFoam marcelo OpenFOAM Running, Solving & CFD 6 December 10, 2005 03:57
