February 13, 2010, 12:50 |
#41 | |
Rep Power: 17 |
February 13, 2010, 18:41 |
#42 |
Tomislav Maric
Rep Power: 21 |
@PattiMichelle
Hi. There is a record of this historical battle here: http://www.slax.org/forum.php?action...98#postid44098 I have printed out the environmental settings (env) to .ssh/environment and copied that file on the other computers on the LAN manually with ssh, worked like a charm. I guess you could write a script of some sort for a larger number of comps. Of course, since it's liveCD the env is the same, otherwise, you would have to have identical instalations. Godspeed, Tomislav |
July 18, 2012, 15:26 |
#43 |
Ehsan
Rep Power: 17 |
Dear All
I like to ask a question on running OF in parallel systems, we try it and put IP number and name of each machine in /etc/hosts to make systems connected, and additionally, we created a file named machines in each system in it we put the name of each desired to connect machines, but the "connection refused" error, indicating that machines could not be connected, is given by the system. The system could ping to each other w.o error. Regards |
Problems with Fedora 9 and OpenMPI | harly | OpenFOAM Running, Solving & CFD | 11 | May 3, 2009 05:18 |
[snappyHexMesh] SnappyHexMesh in parallel openmpi | wikstrom | OpenFOAM Meshing & Mesh Conversion | 7 | November 24, 2008 10:52 |
Problems using local openmpi | stephan | OpenFOAM Installation | 1 | December 5, 2007 19:01 |
OpenMPI performance | vega | OpenFOAM Running, Solving & CFD | 13 | November 27, 2007 02:28 |
OpenFOAM 14 with OpenMPI 12 | fhy | OpenFOAM Installation | 0 | July 12, 2007 19:12 |
