Problem with openmpi
Old   November 7, 2007, 09:42
Default Ok, I have configured the .ssh
  #21
Christofer Ivarsson
cricke is on a distinguished road
Ok, I have configured the .ssh with a 'authorization_keys' file and I may now ssh into the server node without password. Though, not in the reverse direction for some reason. When I ssh into the server all the OpenFOAM env-variables is set automatically via the .bashrc so seem to work properly. Still, the mpirun never starts after executing
$OPENMPI_ARCH_PATH/bin/mpirun --hostfile machines -np 4 simpleFOAM $HOME VAFAB_multi -paralell
nothing happends
The /bin/true exists but
bash: bin/true: can not find file
Still I believe some environment files are missing...
/C
cricke is offline   Reply With Quote
Old   November 7, 2007, 10:38
Default The /bin/true exists but
  #22
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
When I issue 'bin/true' I also get a similar message
-bash: bin/true: No such file or directory
With '/bin/true' however, it works fine.
Okay, but have you made sure that all the subcomponents are really working?
Check that it works on the same machine:
$OPENMPI_ARCH_PATH/bin/mpirun -np 4 /bin/hostname
Add '--debug-daemons' and see what you find.
It might be time to find someone closer to your location (eg sysadmin) and have them take a look.
olesen is offline   Reply With Quote
Old   November 7, 2007, 11:52
Default Sysadmins whitin Linux only ex
  #23
Christofer Ivarsson
Sysadmins whitin Linux only exists i heaven, WINDOWS have bewitched em all...but thanks for all your support!
/Christofer
Old   March 11, 2008, 12:24
Default Hi! I have an execution para
  #24
mer
merrouche djemai
mer is on a distinguished road
Hi!
I have an execution parallel problem with openmpi. I run an interfoam case using two Pcs under FEDORA 7 and I get some errors during execution, both Pcs have the case and I search in openmpi forum and the recommandations doesn't work for my case.
Here are the details:*
- For the eth0 in PC1
/sbin/ifconfig
eth0 Link encap:Ethernet HWaddr 00:1D:92:09:A9:BE
inet addr:192.168.0.2 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: fe80::21d:92ff:fe09:a9be/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:378 errors:0 dropped:0 overruns:0 frame:0
TX packets:92 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:63038 (61.5 KiB) TX bytes:18064 (17.6 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:14355 errors:0 dropped:0 overruns:0 frame:0
TX packets:14355 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:90409124 (86.2 MiB) TX bytes:90409124 (86.2 MiB)
virbr0 Link encap:Ethernet HWaddr 00:00:00:00:00:00
inet addr:192.168.122.1 Bcast:192.168.122.255 Mask:255.255.255.0
inet6 addr: fe80::200:ff:fe00:0/64 Scope:Link
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:40 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 b) TX bytes:8700 (8.4 KiB)
- For the eth0 in PC2
/sbin/ifconfig
eth0 Link encap:Ethernet HWaddr 00:00:21:0B:C6:2B
inet addr:192.168.0.3 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: fe80::200:21ff:fe0b:c62b/64 Scope:Link
RX packets:113 errors:0 dropped:0 overruns:0 frame:0
TX packets:105 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:17546 (17.1 KiB) TX bytes:19208 (18.7 KiB)
Interrupt:5 Base address:0x4000
RX packets:19960 errors:0 dropped:0 overruns:0 frame:0
TX packets:19960 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:142422400 (135.8 MiB) TX bytes:142422400 (135.8 MiB)
TX packets:35 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 b) TX bytes:8390 (8.1 KiB)
- for the execution:
(1)
[mer@merrouche2 ~]$ mpirun --mca pls_rsh_agent "ssh : rsh" --hostfile /home/mer/machinefile -np 2 interFoam /home/mer/OpenFOAM/mer-1.4.1/run/tutorials/interFoam case_2 -parallel
MPI Pstream initialized with:
floatTransfer : 1
nProcsSimpleSum : 0
scheduledTransfer : 0
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.4.1 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : interFoam /home/mer/OpenFOAM/mer-1.4.1/run/tutorials/interFoam case_2 -parallel
[0] Date : Mar 11 2008
[0] Time : 15:17:23
[0] Host : merrouche2
[0] PID : 4576
[1] Date : Mar 11 2008
[0] Root : /home/mer/OpenFOAM/mer-1.4.1/run/tutorials/interFoam
[0] Case : case_2
[0] Nprocs : 2
[0] Slaves :
[0] 1
[0] (
[0] merrouche3.3216
[0] )
[0]
Create time
[1] Time : 15:20:19
[1] Host : merrouche3
[1] PID : 3216
[1] Root : /home/mer/OpenFOAM/mer-1.4.1/run/tutorials/interFoam
[1] Case : case_2
[1] Nprocs : 2
[merrouche2][0,1,0][btl_tcp_endpoint.c:572:mca_btl_tcp_endpoint_comple te_connect ] connect() failed with errno=111
[merrouche3][0,1,1][btl_tcp_endpoint.c:572:mca_btl_tcp_endpoint_comple te_connect ] connect() failed with errno=111
(2)
[mer@merrouche2 ~]$ mpirun --mca pls_rsh_agent "rsh : ssh" --hostfile /home/mer/machinefile -np 2 interFoam /home/mer/OpenFOAM/mer-1.4.1/run/tutorials/interFoam case_2 -parallel
merrouche3: Connection refused
[merrouche2:05257] [0,0,0] ORTE_ERROR_LOG: Timeout in file base/pls_base_orted_cmds.c at line 275
[merrouche2:05257] [0,0,0] ORTE_ERROR_LOG: Timeout in file pls_rsh_module.c at line 1164
[merrouche2:05257] [0,0,0] ORTE_ERROR_LOG: Timeout in file errmgr_hnp.c at line 90
[merrouche2:05257] ERROR: A daemon on node merrouche3 failed to start as expected.
[merrouche2:05257] ERROR: There may be more information available from
[merrouche2:05257] ERROR: the remote shell (see above).
[merrouche2:05257] ERROR: The daemon exited unexpectedly with status 1.
[merrouche2:05257] [0,0,0] ORTE_ERROR_LOG: Timeout in file base/pls_base_orted_cmds.c at line 188
[merrouche2:05257] [0,0,0] ORTE_ERROR_LOG: Timeout in file pls_rsh_module.c at line 1196
mpirun was unable to cleanly terminate the daemons for this job. Returned value Timeout instead of ORTE_SUCCESS.
Please help me
mer is offline   Reply With Quote
Old   March 11, 2008, 14:06
Default Merrouche, Do you have any
  #25
Michael Jaworski
mike_jaworski is on a distinguished road
Merrouche,
Do you have any firewalls running on either machine? My understanding of openMPI is that it doesn't make use of a specific range of ports so it's not possible to configure a firewall to use it. Or if there is, no one seems to know how. I'd suggest testing this by disabling your firewalls and trying mpirun again.
Good Luck,
Mike J.
mike_jaworski is offline   Reply With Quote
Old   March 11, 2008, 15:51
Default Hi Mike! Thanks for your quic
  #26
mer
merrouche djemai
Hi Mike!
Thanks for your quick response.
The firewalls are desabled and I can ssh to machines. Also, my case works on each machine alone using mpirun.
Another informations:
- if I type ompi_info : the mca pls_rsh_agent is rsh and I can't rsh to machines, for this reason there is the second case : "merrouche3: Connection refused"
- but I can ssh to machines and I ask if my expression: --mca pls_rsh_agent "ssh : rsh" is correct and force openmpi to use ssh.
ThankS
Old   March 15, 2008, 08:30
Default Hi! Is there any one who can
  #27
mer
merrouche djemai
Hi!
Is there any one who can help me to resolve my problem. Until now, I can't run my execution using mpirun under OF1.4.1. The errors are the same as mentionned in my previous posts.
I try the hint posted in the forum without any success. I create a new user and install a new OF-1.4.1 version, but the problem remains.
Is there any relation with LAM/MPI and OpenMPI? I ask this question because I installed a lam-7.1.3 version on my pcs before installing OF -1.4.1.
I really NEED your helps.
THANKS
Old   April 20, 2009, 16:55
Default OpenMPI on thin client
  #28
Dominic Spreitz
DSpreitz is on a distinguished road
Hi forum,
Since I have a problem with my OpenMPI and OF 1.5 .... I read lots of posts in this forum and sorted out a lot of problems on the way (thanks to all the helpful advices already posted in this forum) , but now I am really stuck.
As a little background, I'll give you the big picture of my intentions:
Over night & weekend I want to use the CAD workstations in office to run OF in parallel. Since I can't install anything locally on these workstations, I have to use them as thin-clients and boot them over the GBIT-network (pxe, dhcp, atftp, nfs, ...). On the server, that supplies the boot image (derived from pelicanHPC) to the clients I run Ubuntu and installed OF 1.5 with Jure's script.
At this point I can successfully boot one client over network and then mount the server's home directory, where OF resides using NFS. When I connect to the client using ssh and the passwordless login, I can run icoFoam and the cavity case on the client. I can run the same case on the server too.
To check the openMPI installation, I ran the 'hello world' example that Mark suggested in my home directory (which is also mounted on the client) on the server by typing:
wget http://icl.cs.utk.edu/open-mpi/paper...p-2006/hello.c
mpicc hello.c -o hello
mpirun -np 4 ./hello
which resulted in:
Hello, World. I am 0 of 4
Hello, World. I am 1 of 4
Hello, World. I am 2 of 4
Hello, World. I am 3 of 4
To check if I can run the hello world example on server and client I tried:
mpirun -np 4 -host 10.11.12.1 -host 10.11.12.2 ./hello
and got the same result as posted above. I verified, that the example actually ran on both machines by specifying the -d option in the above command.
So far so good. OF seems to work, networking between the machines is working, mpi is running.
However, if I go and try:
mpirun -np 2 -hostfile machines icoFoam /home/user/OpenFOAM/user-1.5/run/tutorials/icoFoam/cavity -parallel > log_mpi_icoFOAM 2>&1
I get:
cat log_mpi_icoFOAM
Failed to find the following executable:
Host: debian
Executable: icoFoam
Cannot continue.
mpirun noticed that job rank 0 with PID 8624 on node 10.11.12.1 exited on signal 15 (Terminated).
From the debug output of the above command (see attachment) I conclude, that all my environment variables are set correctly and also exported over mpi.
Yet, parallel execution on the client fails, although I can run the same case on the client directly. Very strange to me.
Did anybody experience a similar problem or can at least give me a hint or an idea where to start digging for a solution? Any help would be much appreciated.
P.S.:
I don't know if it has anything to do with my problem, but I attached the output of my ldd -v icoFoam, that I ran on the client and server. The libraries are different, but as I said before, icoFoam seems to run on the client if I launch it directly through ssh.
DSpreitz is offline   Reply With Quote
Old   April 20, 2009, 17:45
Dominic Spreitz
Ok, I have to reply to myself:
My .bashrc file contained:
[ -z "$PS1" ] && return
which means it did not load any OF related environment variables at non-interactive (openMPI & SSH) login.
By replacing this line with:
if [ -z "$PS1" ]; then
source /home/user/OpenFOAM/OpenFOAM-1.5/etc/bashrc
fi
I changed that behaviour. Now the necessary OF environment variables are loaded at non-interactive login and my mpi runs are executed correctly.
Maybe this helps somebody else.
Dominic
Old   May 14, 2009, 03:39
michel elsner
holzmichel is on a distinguished road
Send a message via Skype™ to holzmichel
I try to run OF-1.5-dev in parallel without any success. I changed my bashrc like DSpreitz describes, I created the OF on all pc's, I installed NFS and so on ...
When I try to run, for example icoFoam, the following message is in my terminal:
michel@Linux-K:~/OpenFOAM/michel-1.5-dev/run/tutorials/icoFoam/cavity$ /home/michel/OpenFOAM/OpenFOAM-1.5-dev/applications/bin/linuxGccDPOpt/icoFoam: error while loading shared libraries: libfiniteVolume.so: cannot open shared object file: No such file or directory
This error will every time come when I use the command:
mpirun --hostfile <machines> -np 2 /home/michel/OpenFOAM/OpenFOAM-1.5-dev/applications/bin/linuxGccDPOpt/icoFoam $FOAM_RUN/tutorials/icoFoam cavity -parallel > log &
but when i use this command:
mpirun --hostfile <machines> -np 2 icoFoam $FOAM_RUN/tutorials/icoFoam cavity -parallel > log &
the following error will appear
mpirun --hostfile /home/michel/machines -np 2 icoFoam /home/michel/OpenFOAM/michel-1.5-dev/run/tutorials/icoFoam cavity -parallel > log--------------------------------------------------------------------------
Host: ubuntu
Executable: interFoam
Cannot continue.
mpirun noticed that job rank 0 with PID 14312 on node 192.168.1.82 exited on signal 15 (Terminated)
thats really strange because OF as I said is on the other pc too. However, I tried this command with the full path of mpirun
/home/michel/OpenFOAM/ThirdParty/openmpi-1.2.6/platforms/linuxGccDPOpt/bin/mpirun --hostfile ... and so on and no error will appear but my pc do nothing???
Has anybody some suggestions for me. I need the parallel mode because computing of my cases will need more and more time.
Thanks
Best regards
Michel
holzmichel is offline   Reply With Quote
Old   May 14, 2009, 04:57
Default well
  #31
michel elsner
I tried the following command:
/home/michel/OpenFOAM/OpenFOAM-1.5-dev/bin/foamExec -v 1.5-dev /home/michel/OpenFOAM/ThirdParty/openmpi-1.2.6/platforms/linuxGccDPOpt/bin/mpirun --hostfile /home/michel/machines -np 2 icoFoam /home/michel/OpenFOAM/michel-1.5-dev/run/tutorials/icoFoam cavity -parallel > log
with the foamExec and this error appears
[: 106: ==: unexpected operator
[: 153: ==: unexpected operator
[: 257: ==: unexpected operator
[: 259: ==: unexpected operator
[: 56: ==: unexpected operator
[: 74: ==: unexpected operator
and nothing will happens.
which file will cause this error? and what can i do to solve it?
Thank you again
Michel
Old   May 14, 2009, 14:46
Dominic Spreitz
Michael,
I don't know if it really changes great things, but the mpirun command that I use contains a -case statement.
Here is the command:
mpirun --hostfile ~/machines_pil -np 12 /home/user/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/icoFoam -case /home/user/OpenFOAM/user-1.5/run/tutorials/icoFoam/cavity -parallel
everything in one line, obviously.
Dominic
Old   May 15, 2009, 04:02
michel elsner
Thanks Dominic for your reply,
i tried it with -case but the same error appears
I think openmpi do not know the paths to all libraries. I tried to export them in the bashrc but it doesn't worked. maybe i do something wrong by adding the paths but i do not know.
Thanks
Michel
Old   May 15, 2009, 10:29
michel elsner
I checked my $PATH and $LD_LIBRARY_PATH on every machine. both looks like this
$PATH
/home/michel/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/bin:/home/michel/OpenFOAM/ThirdParty/cmake-2.4.6/platforms/linux/bin:/home/michel/OpenFOAM/ThirdParty/openmpi-1.2.6/platforms/linuxGccDPOpt/bin:/home/michel/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin:/home/michel/OpenFOAM/michel-1.5-dev/applications/bin/linuxGccDPOpt:/home/michel/OpenFOAM/OpenFOAM-1.5-dev/applications/bin/linuxGccDPOpt:/home/michel/OpenFOAM/OpenFOAM-1.5-dev/wmake:/home/michel/OpenFOAM/OpenFOAM-1.5-dev/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games
$LD_LIBRARY_PATH
/home/michel/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/bin:/home/michel/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/openmpi-1.2.6:/home/michel/OpenFOAM/ThirdParty/openmpi-1.2.6/platforms/linuxGccDPOpt/lib:/home/michel/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/lib:/home/michel/OpenFOAM/michel-1.5-dev/lib/linuxGccDPOpt:/home/michel/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt
I think that everything is ok but mpirun is still not working.
Is the PATH and the LD_LIBRARY_PATH ok or do I have to add something in the bashrc?
regards
Michel
Old   May 20, 2009, 07:01
michel elsner
I am still not able to run in parallel
Has nobody some ideas for me?
Michel
Old   May 20, 2009, 09:36
Mark Olesen
Okay, but did you also try what is suggested in the foamExec description?
With foamExec being called by mpirun, instead of vice-versa:
#     Can also be used for parallel runs e.g.
#     mpirun -np <nProcs> \
#         foamExec -v <foamVersion> <foamCommand> ... -parallel
Old   May 20, 2009, 09:42
Mark Olesen
Are you certain that the PATH and LD_LIBRARY_PATH are set for non-interactive shells? You can try, for example, the following (the single-quotes are needed to avoid shell expansion):
ssh $HOST 'echo $PATH; echo; echo $LD_LIBRARY_PATH'
Are you using something like ksh that doesn't have a resource file for non-interactive shells (although I believe this problem was fixed long ago in openmpi).
Old   May 26, 2009, 04:57
michel elsner
Hello Mark,
your way solved my problem.
Thank you for your help.
Best regards
Old   August 1, 2009, 16:49
Tomislav Maric
tomislav_maric is on a distinguished road
Hello everyone, I'm glad I've found this thread, since I have the same problem holzmichel has ran into. searching on the net I've found the instructions that I should comment out the if command that returns from the bash if it's ran in non interactive mode.
actually, I'm running OpenFOAM from SLAX live DVD and I'm trying to figure out how to use this live DVD for simulations on a LAN.
the folowwing code suggested by olesen
has showed me that LD_LIBRARY_PATH and PATH are not set at all when bash runs in non interactive mode. how exactly can I solve this?
Thank you in advance,
Tomislav
tomislav_maric is offline   Reply With Quote
Old   August 2, 2009, 17:06
Tomislav Maric
I'm having the same problem: error loading shared libraries (libFiniteVolume.so..), so I have tried the command above, but mpirun complains that I'm running multiple commands with unspecified -np number.
my command goes like this:
/path/name/of/mpirun -np 2 -H mario foamExex -v 1.5-dev interFoam -parallel
and it works fine on my dual core laptop.
What am I doing wrong?
Problems with Fedora 9 and OpenMPI harly OpenFOAM Running, Solving & CFD 11 May 3, 2009 05:18
[snappyHexMesh] SnappyHexMesh in parallel openmpi wikstrom OpenFOAM Meshing & Mesh Conversion 7 November 24, 2008 10:52
Problems using local openmpi stephan OpenFOAM Installation 1 December 5, 2007 19:01
OpenMPI performance vega OpenFOAM Running, Solving & CFD 13 November 27, 2007 02:28
OpenFOAM 14 with OpenMPI 12 fhy OpenFOAM Installation 0 July 12, 2007 19:12
