February 27, 2008, 06:30 |
Hi Christian,
thank you for
#21 |
Francesco Boschetto
Rep Power: 17 |
Hi Christian,
thank you for your test, I'm cleaning my BC and soon I'll send you it through mail, I'm sorry but I'm not able to attach files in the forum. I'm having other tests too, so please be patient and don't worry, I'll send you the mail ;) Regards Francesco |
March 20, 2008, 14:31 |
Hi All,
I'm trying to injec
#22 |
Abel Vargas
Hi All,
I'm trying to inject air through a jet into an incomig flow using the VOF solver (interFoam). I filled my domain with gamma=1. How do I specify gamma=0 at the jet inlet, |
March 21, 2008, 08:56 |
The boundary condition
#23 |
Billy
Rep Power: 17 |
The boundary condition should switch gradually between wall and permeable wall. I think if you just jump from a permeable wall to a non-permeable wall at gamma = 0.5 you will have numerical problems. One way could be to multiply the flux out that wall by (1-gamma) but the correct adjustments have to be made to assure mass conservation. |
May 22, 2009, 06:42 |
#24 |
Jitao Liu
Rep Power: 17 |
Dear Francesco,
Good job. I am a new Foamer and very interested in this kind of boundary condition. I tried to create "filter" from "outletInlet" under your guidance in : http://www.cfd-online.com/Forums/ope...condition.html but failed and got following errors: In file included from filterFvPatchField.H:153, from filterFvPatchFields.H:30, from filterFvPatchFields.C:29: /usr/include/bits/mathcalls.h: In member function ‘virtual void Foam::filterFvPatchField<Type>::updateCoeffs()’: /usr/include/bits/mathcalls.h:265: error: too few arguments to function ‘double gamma(double)’ filterFvPatchField.C:135: error: at this point in file filterFvPatchField.C:135: error: expected primary-expression before ‘>’ token How did you implement this new boundary condition? Would you mind giving me some suggestions. Thanks in advance. Jitao Liu |
May 22, 2009, 19:50 |
#25 | |
Nugroho Adi
Rep Power: 17 |
just wondering how yo managed to display the geometry on the post processing as a transparent image /walls (like you shown above) ? you did by paraview? could you please tell us, step by step to display transparant walls? thanks |
May 24, 2009, 10:45 |
#26 |
Christian Winkler
Rep Power: 17 |
this is quite simple. I used paraview under windows. 1 run foamToVTK 2 load your wall data, load your field data 3 for your wall data set opacity to a value below 1.0 4 create a iso surface with value 0.5 for gamma for your field data actually thats it.... best regards Christian |
July 8, 2009, 04:14 |
#27 |
Jitao Liu
Rep Power: 17 |
Dear Francesco,
Thanks a lot for your filter BC. I have tested it for several weeks. I want to know what's the difference between if (gammap[id]<0.001) this->valueFraction()[id] = 0; or if (gammap[id]<0.5) this->valueFraction()[id] = 0; or sth. like this. Please do me a fever. Moreover, is it necessary to use the filterU BC for velocity and filterP BC for pressure at the same time, or , just use one of them ? Would you mind sending me a tutorial about how to use the filter BC ? My e-mail address is: liujitao@mail.sdu.edu.cn Thanks and regards Jitao |
February 3, 2012, 11:20 |
#28 |
Andrea Ferrari
Rep Power: 16 |
Dear Francesco,
I'm also interested is this kind of boundary condition. I'm working with multiphase flow and i'm facing many problem with outlet condition, maybe your BC could do the job i want. This thread is quite old, but can you share/send me the implementation of this boudary condition?. my email is andrea.ferrari@unil.ch Best Regards andrea |
fluid pressure in cavity | Nishan | CFX | 0 | November 2, 2008 18:51 |
lid driven cavity | sudha | Main CFD Forum | 5 | July 11, 2007 03:05 |
ANSYS problem in solving fluid fluid interaction | Fayyaz | CFX | 0 | July 24, 2006 09:03 |
Heat transfer for fluid-fluid interface | lentil | FLUENT | 0 | March 31, 2005 15:25 |
Help on cavity flow | Pendy | Main CFD Forum | 17 | July 17, 2001 23:34 |
