Problems with parallel
Old   April 14, 2008, 05:36
Default I work on cluster (x86_64) wit
Vladimir Cheredov
wolfgray is on a distinguished road
I work on cluster (x86_64) with more than 3000 processors.
OS - Linux 2.6.18.
The compiler - Intel 10.1.
MPI - HP-MPI.
OpenFOAM 1.4.1.
I started icoFoam with the task "cavity". At sequent. run has received result of calculations. At parallel run the problem does not give out errors, but does not give out also result. (Decomposition of area of calculations on 8 processors, since on one node - 8 processors). If at parallel run not to specify in a command of start an option "-parallel" the task leaves on a node, it is carried out on one processor, calculates results and message, that MPI_Init () it was not caused.
In what there can be a problem?
wolfgray is offline   Reply With Quote
Parallel Run Problems Jason Siemens 1 November 24, 2008 13:32
STAR-CD v4.02 parallel problems on Win XP 64 bit Kasper Siemens 3 September 24, 2007 07:06
Problems on running cfx in parallel Nan CFX 1 March 29, 2006 05:10
PVM parallel problems stex_CFD CFX 3 June 29, 2005 10:16
CFX - Parallel Problems CFX User CFX 0 November 1, 2004 19:12
