kalaiselvan
Rep Power: 17 ![]() |
Hi Foamers,
I have used the XiFOAM tutorial for a combustion problem. The problem is that combustion is initiated at the closed end of the tube. Tube is filled with premixed fuel - air mixture at a temperature which is just 100 degrees below the auto-ignition temperature. So, what I thought is, once the combustion gets started, it will reach a temperature above the auto ignition temperature starting a new combustion wave front..... To my surprise it didn't happen... the flow was being solved, without the start of detonation... Help me sorting out this!!! |
Run pitzdaily with xifoam | tavasoly | OpenFOAM Running, Solving & CFD | 0 | July 8, 2008 04:25 |
XiFoam janafthermo error AT | tavasoly | OpenFOAM Running, Solving & CFD | 1 | July 1, 2008 11:15 |
XiFoam question | burningman | OpenFOAM Running, Solving & CFD | 0 | November 15, 2005 06:04 |
Question about XiFoam | pratap | OpenFOAM Running, Solving & CFD | 1 | April 22, 2004 04:39 |
XiFoam tutorial case | pratap | OpenFOAM Running, Solving & CFD | 1 | March 1, 2004 05:25 |
