April 28, 2008, 10:50 |
Hi everybody,
I'm strugglin
Leonardo Nettis
Rep Power: 17 |
Hi everybody,
I'm struggling with a rae profile analysed for Ma=0.25 (aoa=0 degree). Although the boundary conditions seem to be correct (indeed potentialfoam did not have any problem with the same BC) this is the message I get: ------------------------------------ Time = 0.066 DILUPBiCG: Solving for Ux, Initial residual = 0.439752, Final residual = 4.10432e-06, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 0.453736, Final residual = 5.53212e-07, No Iterations 2 DICPCG: Solving for p, Initial residual = 0.987358, Final residual = 0.000979867, No Iterations 192 time step continuity errors : sum local = 2.13623e+86, global = -6.30715e+72, cumulative = -5.9625e+72 DILUPBiCG: Solving for epsilon, Initial residual = 0.0513206, Final residual = 8.37324e-05, No Iterations 1 DILUPBiCG: Solving for k, Initial residual = 2.87352e-09, Final residual = 2.87352e-09, No Iterations 0 ExecutionTime = 39.91 s ClockTime = 41 s Time = 0.067 DILUPBiCG: Solving for Ux, Initial residual = 0.373545, Final residual = 9.78289e-05, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 0.435162, Final residual = 1.79789e-05, No Iterations 2 DICPCG: Solving for p, Initial residual = 0.98127, Final residual = 0.000992254, No Iterations 197 time step continuity errors : sum local = 5.44038e+87, global = 1.91227e+74, cumulative = 1.85265e+74 DILUPBiCG: Solving for epsilon, Initial residual = 0.303376, Final residual = 3.81456e-05, No Iterations 1 DILUPBiCG: Solving for k, Initial residual = 3.13267e-08, Final residual = 3.13267e-08, No Iterations 0 ExecutionTime = 40.49 s ClockTime = 42 s Time = 0.068 DILUPBiCG: Solving for Ux, Initial residual = 0.434953, Final residual = 3.85775e-06, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 0.45262, Final residual = 7.94863e-07, No Iterations 2 DICPCG: Solving for p, Initial residual = 0.987109, Final residual = 0.000802516, No Iterations 208 time step continuity errors : sum local = 1.21666e+89, global = -2.62405e+75, cumulative = -2.43879e+75 #0 Foam::error::printStack(Foam:stream&) in "/home/nettis/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/nettis/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #2 ?? in "/lib64/libc.so.6" #3 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/nettis/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #4 Foam::fvMatrix<double>::solve(Foam::Istream&) in "/home/nettis/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libfiniteVolume.so" #5 Foam::lduMatrix::solverPerformance Foam::solve<double>(Foam::tmp<foam::fvmatrix<doubl e> > const&) in "/home/nettis/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libincompressibleTurbu lenceModels.so" #6 Foam::turbulenceModels::LaunderSharmaKE::correct() in "/home/nettis/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libincompressibleTurbu lenceModels.so" #7 main in "/home/nettis/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/simpleFoa m" #8 __libc_start_main in "/lib64/libc.so.6" #9 Foam::regIOobject::readIfModified() in "/home/nettis/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/simpleFoa m" Errore di virgola mobile ----------------------------------- I'm using a Low Re model (LaunderSharmaKE) with very low starting value of k,e and nutilda (1e-10) in the whole domain. Anyway I don't think these value could influence the problem since I get approximately the same message with turbulence off. Finally I do not think it is due to the solver since it is a classic case of incompressible steady-state flow. Therefore I hope somebody can give me an advice. thanks in advance. dino |
SimpleFoam Error with librdmacm amp libibverbs | dnomdec | OpenFOAM Running, Solving & CFD | 1 | May 21, 2010 09:02 |
SimpleFoam error | sven82 | OpenFOAM Running, Solving & CFD | 0 | October 16, 2008 05:13 |
Error running simpleFoam in parallel | skabilan | OpenFOAM Running, Solving & CFD | 2 | August 29, 2008 10:42 |
Error message using simpleFoam | plmauk | OpenFOAM Running, Solving & CFD | 0 | January 22, 2008 08:46 |
SimpleFoam error message | braennstroem | OpenFOAM Running, Solving & CFD | 1 | October 15, 2007 13:33 |
