LES turbulent pipe flow
Like Tree19Likes
Old   August 5, 2011, 22:33
Post laminar to turbulent transitonal pipe flow
  #41
hasan
hasanduz is on a distinguished road
I am studying transitional pipe flow in numerical. This is my doctorate thesis. My aim is to simulate pressure fluctuation on the entire pipe flow or I want to simulate the existance of transition through the pipe flow.
*How can I carried out this one by using LES model in FLUENT.
My package program is ANSYS 12.
* how can I impose the perturbations into the pipe flow for transition.
is there any tutorial about this or any notes
I will be pleased with your helpings
hasanduz is offline   Reply With Quote
Old   March 29, 2012, 07:53
senpatras
sen.1986 is on a distinguished road
To all, and specially Cedric,
I was trying to emulate the exact case that Cedric had discussed. For starters, I would like to know, as to how long approximately, one has to wait, for the flow to depict Turbulence? I have already completed around 70 time cycles, but I see no turbulence yet
I am using inlet/outlet boundary condition, for inlet and outlet respectively, and 'wall' for my walls. I initialize my flow field using the perturbU code by Eugene.
Any help, is most welcome.
sen.1986 is offline   Reply With Quote
Old   March 29, 2012, 08:11
Florian Krause
florian_krause is on a distinguished road
I would say, if after 70 flow cycles your perturbed laminar flow field is not becoming turbulent there is something going wrong... did you check how your perturbations (the imposed low-speed streaks at the wall) are evolving over time? just make a cut through your pipe and look at the velocity contours for different times
What is your y+ at the wall and what schemes are you using?
Are you setting your case up as a short periodic pipe with dimensions as approx. length = 5 diameter?
Best,
Florian
florian_krause is offline   Reply With Quote
Old   March 29, 2012, 08:35
senpatras
Best,
Florian
Yes, I did check the imposed low speed streaks, as they evolve with time, or rather don't evolve significantly with time.
My y+ at the wall is 70,
Here is a copy of my fvschemes file,
ddtSchemes
default backward;
gradSchemes
default Gauss linear;
grad(p) Gauss linear;
grad(U) Gauss linear;
divSchemes
default none;
div(phi,U) Gauss limitedLinear 1;
div(phi,k) Gauss limitedLinear 1;
div(phi,B) Gauss limitedLinear 1;
div(B) Gauss linear;
div(phi,nuTilda) Gauss limitedLinear 1;
div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
default none;
laplacian(nuEff,U) Gauss linear corrected;
laplacian((1|A(U)),p) Gauss linear corrected;
laplacian(DkEff,k) Gauss linear corrected;
laplacian(DBEff,B) Gauss linear corrected;
laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
interpolationSchemes
default linear;
interpolate(U) linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p ;
This is exactly as it is, in the ChannelFoam case, I merely changed the divergence scheme of U from Gauss Linear to Gauss Limitedlinear.
In my case Length of pipe= 5.7 * D
Will this help?
Old   March 29, 2012, 09:09
Florian Krause
Well, if y+=70 at the wall is not a typo, then for a LES it is far too large.
You have to resolve the flow near the wall, so you should have at least 3 cells within the viscous sublayer (y+ approx. 5) and the smallest y+ should be approx. 0.3-0.5. Using that, I generally obtain acceptable results.
Hope that helps!
Florian
Old   March 29, 2012, 09:25
senpatras
Hope that helps!
Florian
Thank you for the prompt reply. Ok I see now, what you are saying. Yes I misreported the value of y+. At the boundary, the closest cell has a y+ value of 16. I understand that it there should be 3 cells approximately, within the viscous sub layer. Let me try this out, and I shall get back to you.
Old   March 30, 2012, 08:53
Cedric DUPRAT
cedric_duprat is on a distinguished road
Senpatras,
As already mention by Florian, for a LES simulation, y+ should be less than 1 and 3 cells within the viscous layer is really the minimum.
If your mesh is too coarse, you will dissipate the perturbation created by perturbU.
If I remember correcly, in perturbU, you can change few parameters such as the amplitude of the noise added. This might be the easiest way.
let us know if it's working or not.
I my case, I was interesting in swirling flow that's why I've used an other method which is to add a bodyforce in the orthoradial direction to let the flow become unsteady (rotating flow is more unstable than pure axial flow). After few time cycle, you can remove this bodyforce and let the flow converge to an non-rotating flow. Then you can start the averaging of your fields. Of course you will need to modified the solver with this method.
I hope this will help you,
Cedric
mgg likes this.
cedric_duprat is offline   Reply With Quote
Old   March 30, 2012, 09:41
senpatras
Originally Posted by cedric_duprat View Post
Senpatras,
Cedric
Thank you. I am working on it now Will get back real soon.
Old   April 2, 2012, 09:00
senpatras
@Cedric and Florian
Now, I need some help with refining the mesh, I can't make proper headway because of this. Firstly, I would like to ask you, is there a proper tutorial for topoSet and refineMesh application of OpenFoam, I am really confused with the two as of now. I am presently trying to mesh near the wall, as suggested by you guys, i.e to have 4 cells within y+ = 5.
For doing that, I am presently using the following refinemeshdict and toposetdict files, but I do not see refinement after I run toposet and refineMesh at the terminal, though they do not report any error. My geometry is a circular pipe with x [0 0.12], y[-0.01 0.01] and z[-0.01 0.01].
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object refineMeshDict;
set c0;
coordinateSystem local;
globalCoeffs
normal ( 1 0 0 );
tan1 ( 0 1 0 );
tan2 ( 0 0 1 );
patchLocalCoeffs
patch wall;
tan1 ( 0 1 0 );
directions ( tan2 );
useHexTopology no;
geometricCut yes;
writeMesh no;
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object topoSetDict;
actions
name c0;
type cellSet;
action new;
source boxToCell;
sourceInfo
box (0 9.97e-03 -0.01) (0.12 0.01 0.01);
Regards.
Old   April 4, 2012, 04:37
Florian Krause
I have never used these utilities, so I cannot help you with that. I created my pipe grids in a different grid generator calculating the thickness of the viscous sublayer as
y_{visc. sublayer} = y^+(=5)*d_{pipe} / Re_{tau}
Did you search the forum for the utilities? There is also a sub-forum Meshing & Mesh Conversion, I guess your question is better placed there.
Regards,
Florian
Old   April 5, 2012, 03:06
Cedric DUPRAT
I don't know how you've generate your mesh but, there is somewhere in the forum a blockMesh file to do simple pipe configuration (butterfly mesh).
In this case it is really easy to modify the distribution close to the wall and not too much time consuming.
I've never used these utilities either.
Regards,
Cédric
Old   April 12, 2012, 09:13
senpatras
So after a bit of a struggle, I need more help. This is what I did in the meanwhile, I couldn't grasp how one could remesh specifically near the wall using blockmesh (meshing uniformly and stayisfying the condition of having 3 elements inside y+=5 seemed to expensive. So I decided to mesh with icemcfd. The mesh looks, as is shown in the attachment.
After I did this, I exported the mesh and then using Fluent3dtoFoam converted it. When I tried running perturbU initially, an annoying face ordering problem was reported, with 1.98%. This has something to do with the periodic/cyclic boundary conditions. After rechecking my association of edges and curves again, the only way to work around it was to increase the matchTolerance to 2, from the preset value of 1d-4.
After that perturbU ran just fine, and then when I run my case, the Courant Number goes fine for about 70 iterations, and then suddenly the residuals shoot up, and my simulation blows off. My calculated deltaT for a Courant no. of 0.5 is 7.5d-5, hence I am using a time step of 1d-5.
Any ideas, how one could go about it next?
Old   April 13, 2012, 06:43
senpatras
Also, this is where the simulation blows up. I am using a time step of 1d-5. From the 76th time step to 77th time step, something suddenly goes wrong with Uy, which causes the residuals to Uy to go very high, eventually causing the simulation to diverge. I am attaching the two plots of Uy at time 0.00076 and 0.00077.
Kindly give it a look, and let me know if you have any idea.
Old   April 13, 2012, 07:15
Timo K.
timo_IHS is on a distinguished road
which solver do you use? What is your Courant number? which sgs-model? What is your inlet BC?
Which case do you run?
Best
timo_IHS is offline   Reply With Quote
Old   April 13, 2012, 08:59
Cedric DUPRAT
Hi Senpatras,
Are you sure there is no influence fixing the matchTolerance to 2, from the preset value of 1e-4 (4 orders magnitudes are quite a lot ....) ?
In an other word, is your periodic BC really cyclic ?
To avoid this problem, you could create a simple blockMeshDict file. Maybe you can have a look at the turbomachinery SIG: http://openfoamwiki.net/index.php/Si...nical_diffuser
This test case includes parametrizations of an axisymetric geometry using O-grid, you will find the blockMeshDict.m4 file to create both geometry and mesh.
It straithforward to get a periodic pipe mesh in the native blockMesh format.
Cedric
Old   June 29, 2013, 06:40
Default Source term in the momentum equation
  #56
Antonio de O Samel Moraes
antonio.samel is on a distinguished road
Send a message via Skype™ to antonio.samel
Originally Posted by panara View Post
Hi Fabian,
I am using cylcic boundary condition at the inlet and outlet of the pipe plus a source term in the momentum equation to sustain the flow.
I have used this configuration already with another code and in a channel configuration initializing the flowfield with white noise.
It worked for the channel, but I am having problems with openFoam and the pipe configuration (I just started to try.. )
I saw that in OpenFoam exists also a turbulent inlet... but I didn't try it..
Anyway could anybody give some reference on the compressible LES turbulence models implemented in OpenFoam?
Thanks
Hello Mr. Panara.
Could you explain how to implement the referenced momentum source term? You implement a constant force or something like a pressure gradient?
Thanks,
Antonio
antonio.samel is offline   Reply With Quote
Old   December 20, 2013, 06:38
pante is on a distinguished road
Hi guys,
I am trying to simulate a turbulent pipe flow, Re=5300 (based on bulk velocity and diameter of cylinder pipe). My problem is in the initialization of turbulent field. I saw the existence of perturbU utility for this purpose, but when I download the .tgz file am not able to open it as its changes to .unk (unknown) type.
Any suggestions?
Thanks!
pante is offline   Reply With Quote
Old   March 4, 2014, 04:32
Huang Xianbei
huangxianbei is on a distinguished road
Originally Posted by eugene View Post
Try this
perturbCylinder.tgz
You have to edit the code and set the cylinder diameter and Re_tau. It only works for flow in the x direction. It will set up wavy sinusoidal precursor perturbations that should develop into fully blown turbulence after a few dozen flow-through times.
Hi, Eugene
I'm looking for your Phd thesis for a long time in order to study the channel flow using openfoam with LES and DNS. But I can't find it for my net can't connect to some website. So can you be so kind to send me a copy of your thesis? My email is znhuang@163.com
Best regards
huangxianbei is offline   Reply With Quote
Old   January 24, 2018, 14:05
Default postChannel
  #59
gu1
Guilherme
gu1 is on a distinguished road
Now, I plan to postprocess the result and I'd like to know if there is a "postChannel" for periodic LES pipe ? or if a postChannel with one periodic direction will be enough ?
If some one has experience of this topic, I'm interesting to that.
Cedric
Did you find out anything about this?
gu1 is offline   Reply With Quote
Old   September 16, 2019, 10:58
George Sof
lastjedivol is on a distinguished road
Hello, still interested about postprocessing turbulent pipe flows. I need to average spatially U.z over a homogeneous direction z of a pipe. Result of the averaging should be a surface field U.z(x,y). Is it possible? Is there any progress regarding pipe postprocessing that you can share?
Thank you very much!
lastjedivol is offline   Reply With Quote
MapFields turbulent pipe flow anita OpenFOAM Pre-Processing 5 July 4, 2008 00:29
pipe turbulent flow Hao FLUENT 4 April 29, 2008 23:30
turbulent pipe flow John FLUENT 2 August 2, 2005 14:00
fully developed turbulent flow in a pipe Dipak Phoenics 3 July 20, 2000 06:53
Measurements on turbulent pipe flow Bo B. B. Jensen Main CFD Forum 4 June 30, 1999 06:34
