Boundary conditions for external flows
Old   May 19, 2008, 00:33
Default Hi, Im running 3D airfoils
Ryan Middleton
ryan_m is on a distinguished road
Im running 3D airfoils (NACA 0016 @ 0 degrees) using an incompressible solver (simpleFoam). The results Im getting aren't making much sense: non-symmetrical pressure distribution, the velocity at the inlet seems to be different to what I specified. I think my boundary conditions are at fault. Could someone please have a look at the following boundary conditions to see if there are any errors:
Pressure: fixedValue outlet, zeroGradient elsewhere
Velocity: fixedValue inlet, zeroGradient outlet, movingWallVelocity on boundaries and 0 at the airfoil walls
k, epsilon, nuTilda: fixedValue inlet, zeroGradient elesewhere
Any help will be much appreciated.
Ryan
ryan_m is offline   Reply With Quote
Old   May 19, 2008, 08:41
Default Hi Ryan The movingWallVeloc
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Ryan
The movingWallVelocity, is that on the side walls parallel to the longitudinal direction of the channel? I would put a symmetry condition on those walls, see e.g. User Guide sec 6.2.1.
The other boundary conditions look reasonable.
- Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   May 19, 2008, 09:18
Default Hi Niels, I do have a symme
Ryan Middleton
Hi Niels,
I do have a symmetry plane in the mesh which I defined as a symmetryPlane (forgot to mention that in original post!). The movingWallVelocity is for the top, bottom and side of my domain. I am currently running the case now, Ill post another comment if my results dont work out.
Thanks for your comments.
Ryan
Old   May 19, 2008, 10:49
Default Hi Ryan, movingWallVelocity
pbo
Patrick Bourdin
pbo is on a distinguished road
Hi Ryan,
movingWallVelocity is for moving/deforming boundaries;
for a static mesh, used fixedValue for the Velocity at the top, bottom and side boundaries if what you want is to prescribe the velocity on these patches.
However, you will be better off using the slip condition on those.
Patrick
pbo is offline   Reply With Quote
Inlet turbulent boundary condition: external flows ROOZBEH FLUENT 3 August 28, 2015 16:34
Fan Boundary conditions with external analysis Rob FloEFD, FloWorks & FloTHERM 1 February 10, 2009 01:04
Inlet turbulent boundary condition, external flows ROOZBEH Main CFD Forum 1 February 6, 2009 13:37
Boundary Conditions for External Flow raytracer OpenFOAM Running, Solving & CFD 4 July 14, 2008 13:18
boundary conditions for external automotive aero Andrew Berner FLUENT 4 November 2, 2006 12:17
