March 16, 2007, 06:43 |
Hi hope someone can help me
O R
Rep Power: 17 |
I have created a simple case to test combustion and LES, the domain is a rectangular area , in the first third and in the middle(vertically) there is a cylinder (the usual case), and top and bottom I set wall, the cyl is also wall. The left is a velocity inlet and the right is inletOutlet type , I am using the Xoodles solver and the case is similar in all aspects to pitzDaily example case I have created the grid in Gambit and export into Fluent, the mesh is for 2d example , so the mesh have only one cel in the z direction as in the pitzDaily example case, Apparently I was able to import correctly the grid and I set all values using as a model the pitzDaily example case i got the following error in the log.Xoodles file: This mesh contains patches of type empty but is not 1D or 2D by virtue of the fact that the number of faces of this empty patch is not divisible by the number of cells. well I assume, although the mesh is 2D with only 1 cell in the z direction, Open Foam believes is 3d , how can I correct this I visualize it and I see exactly what I want, my grid with one single cell in Z direction (is the depth of this single cell important in 2d cases? for example in pitzDaily is 0.1 ) second I try to run the case using the script Allrun in Xoodles, I only commented out the line that says "runApplication blockMesh $case" thanks in advance |
March 16, 2007, 07:00 |
http://www.cfd-online.com/Ope
O R
Rep Power: 17 |
March 16, 2007, 07:03 |
the correct one
O R
Rep Power: 17 |
the correct one
May 19, 2008, 10:43 |
hello
I run the tutorial pitz
a_tavasoly
Rep Power: 17 |
hello
I run the tutorial pitzDaily3D in Xoodles solver with its defult setting. but my result is not appropriate.my bmean and Tmean conture after 0.1 sec is not same with result of Weller and Tabor.what my mistake? what time is need to becom steady state? Thanks a lot. |
May 19, 2008, 11:33 |
In runnig pitzDaily3D with def
a_tavasoly
Rep Power: 17 |
In runnig pitzDaily3D with defult as said in privious message my tempreture decrease after ignition and by itrating it slightly become low. it is around 295k.
anybody can help me? |
combustion model in premixed combustion chamber | wuyu | FLUENT | 9 | February 16, 2018 11:40 |
Hydrogen Air combustion in a combustion chamber | popi | CFX | 7 | July 11, 2007 19:40 |
Sawdust Combustion-Non-premixed Combustion Model | Jessy | FLUENT | 1 | June 19, 2007 11:59 |
combustion in internal combustion engine | George | Main CFD Forum | 0 | September 7, 2006 15:41 |
combustion | prasat | Main CFD Forum | 1 | June 16, 2003 14:17 |
