June 7, 2007, 16:01 |
Hello Hrv,
thanks for your
#21 |
Hello Hrv,
thanks for your reply, I initialize Uz with 0. My U for initializing and inlet is (29.21 0 0). If I run potentialFoam first I get a velocity in z-direction in the range of -10^-17 to 10^-17, but I think it is just the normal noise. 10^-17 might be 0 for OpenFOAM. The results for Ux and Uy look great from potentialFoam. So you think, because of this z-velocity, all my results are pointless? That would be bad, because I need this data for my diploma work. RW |
June 11, 2007, 05:49 |
Hello again,
I made a mesh
#22 |
Hello again,
I made a mesh with blockMesh. After running the case, I still got the same velocity in z-direction. As I didnt know how to solve the problem anyway, because all possible options I could think of had a tryout, I started to calculate the pitzdaily-case from the simpleFoam-tutorial with second order. After computing this case, I got a velocity in z-direction too, so might this be a bug? My schemes-setup (pitzDaily): div(phi,U) Gauss GammaV 0.2; div(phi,k) Gauss Gamma 0.2; div(phi,epsilon) Gauss Gamma 0.2; div(phi,R) Gauss Gamma 0.2; div(R) Gauss linear; div(phi,nuTilda) Gauss Gamma 0.2; div((nuEff*dev(grad(U).T()))) Gauss linear; After 500 iterations I had a velocity about 0.29 m/s, not much, but there shouldnt be a Uz-velocity, because the boundary condition of front- and backplane is "empty". The look of this z-velocity areas in paraFoam look exactly like in my airfoil-cases. Any ideas? RW |
May 27, 2008, 05:59 |
Had a similar problem (mesh im
#23 |
Stefan Radl
Rep Power: 18 |
Had a similar problem (mesh import from Cubit): it turned out that my cell faces in the "empty" patch were not perfectly perpendicular to the z-direction.
So one has to be careful when meshing stuff! Is there any effort in OF to circumvent this problem and allow more "dirty" meshes to be processes in 2D? br Stefan Radl |
Steady pipe flow mean velocity higher than inlet velocity | anita | OpenFOAM Running, Solving & CFD | 7 | September 25, 2012 06:35 |
Velocity profile as an velocity intlet condition | kees | FLUENT | 3 | April 16, 2008 19:35 |
velocity profile as an velocity inlet condition | KEES | Main CFD Forum | 0 | April 15, 2008 12:26 |
Head loss function of velocity^2 or velocity^1? | jrg | Main CFD Forum | 1 | November 19, 2007 14:09 |
how to plot RMS velocity (fluctuating velocity) | nash | Main CFD Forum | 0 | October 18, 2006 17:37 |
