DICPCG max iteration limit
Old   May 29, 2008, 00:16
Default For some very fine mesh proble
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
For some very fine mesh problems I need to increase the maximum iteration limit from 1001 to say, 1500.
Can someone tell me where I can find this 1001 iteration limit so that I can change it to suit my needs. Specifically which source or header file?
Thanks!
msrinath80 is offline   Reply With Quote
Old   May 29, 2008, 03:03
Default All the solver controls live i
Andrew King
andersking is on a distinguished road
All the solver controls live in
system/fvSolution
Cheers,
Andrew
Dr Andrew King
Fluid Dynamics Research Group
Curtin University
andersking is offline   Reply With Quote
Old   May 29, 2008, 03:08
Default Hi Srinath, Try here: Open
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Hi Srinath,
Try here:
OpenFOAM/lnInclude/lduMatrixSolver.C: maxIter_(1000)
I hope is helpful,
Dragos
dmoroian is offline   Reply With Quote
Old   May 29, 2008, 03:22
Default Hi Dragos, Srinath, The max
Andrew King
Hi Dragos, Srinath,
The maxIter value in the source should be overwritten with the one read from the fvSolution file, as far as I am aware. These must be specified in OF-1.4.1 (at least I've had a lot of errors when they weren't). This goes for minIter too.
No recompilation needed.
Cheers
Andrew
Dr Andrew King
Curtin University
Old   May 29, 2008, 03:56
Default ...http://www.cfd-online.com/O
dmoroian's Avatar
Dragos
... Of course, you're right Andrew!
This happens when I try to be too "smart" !
Old   May 29, 2008, 18:24
Default The solvers section from fvSol
The solvers section from fvSolution in the cavity case of OF 1.4.1 contains the following:
solvers
p PCG
preconditioner DIC;
tolerance 1e-06;
relTol 0;
U PBiCG
preconditioner DILU;
tolerance 1e-05;
relTol 0;
Where is the maxiterations to be specified and what is the keyword and format?
Old   May 29, 2008, 22:03
Default Hi Srinath, just add maxI
Andrew King
Hi Srinath,
just add
maxIter 1000;
minIter 0;
after the relTol line in both solvers, (before the };)
Of course, change 1000 to be whatever new maximum you would like.
Cheers
Andrew
Dr Andrew King
Curtin University
Old   May 31, 2008, 05:23
Default Thanks Andrew!
Thanks Andrew!
how to increase "Newton Pressure Iteration Limit" kus CFX 9 April 21, 2013 02:54
Solver BICCG DILUPBiCG DICPCG mamaly60 OpenFOAM Running, Solving & CFD 2 October 31, 2007 08:03
DICPCG solver in interFoam m9819348 OpenFOAM Running, Solving & CFD 1 September 20, 2007 14:10
limit of the CFX Eric CFX 7 December 4, 2006 13:42
Limit of CFD mourad Abdelmalek Siemens 2 October 23, 2000 09:27
