January 26, 2007, 18:25 |
My OF version is build all wit
#21 |
Jens Klostermann
Rep Power: 17 |
My OF version is build all with cell decomposition.
Thanks to Zjelko the couplingProperties problem is solved. But there is another strange thing, I can only use GaussSeidel as solver for U, since this is the only solver for symmetric and assymetric matrizes. Otherwise if I use ICCG or AMG it asks for BICCG or BDCG and vice versa. How does this come? Jens |
January 26, 2007, 18:43 |
It's not that bad: have anothe
#22 |
Hrvoje Jasak
Rep Power: 33 |
It's not that bad: have another look.
There are two fvSolution dictionaries in the case: one in system/fvSolution and another in system/solid/fvSolution so you can control the dictionaries separately. The one in "solid" is (of course) for a solid and all should be well. If you are not picking up the proper solver, it is possible that your solid U field (requiring a symmetric solver) is hooked onto the wrong mesh, but I doubt it. Hope this helps, Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
January 26, 2007, 19:26 |
Thanks Hrv,
next question:
#23 |
Jens Klostermann
Rep Power: 17 |
Thanks Hrv,
next question: Can I run the icoFsiFoam in parallel? Jens |
January 27, 2007, 06:29 |
I recompiled everything and no
#24 |
Guus Kupers
Rep Power: 17 |
I recompiled everything and now it works. Thanks Hrv!!
January 27, 2007, 09:26 |
Well done Guus! Looking forwar
#25 |
Frank Bos
Rep Power: 18 |
Well done Guus! Looking forward to your first fsi results! Maybe you can post some of your results here to share your experiences:-)
Regards, Frank
Frank Bos |
February 6, 2007, 10:55 |
Hi everybody,
I'm still wor
#26 |
Vincent RIVOLA
Rep Power: 18 |
Hi everybody,
I'm still working on the development of my fluid structure interaction code. At this time, I'm begining the coupling with the open source code Impact. Thus, I have a question which might look obvious for some of you, but I don't know how to do it. So far, I've been using a constant vectorField defined by: vectorField fluidPatchPointsDispl = vectorField(224, vector(0,1e-02,0)); However I would like to be able to define this vectorField by reading a file which I'd put in a correct directory, like when we define the velocity field for instance, using a dictionary. Which would be the code to define such a vectorField? Thanks in advance, Regards, Vincent |
February 6, 2007, 13:04 |
Hi Vincent,
Could you pleas
#27 |
Daniel Einstein
Rep Power: 17 |
Hi Vincent,
Could you please give me a link for "Impact"? Dan |
February 6, 2007, 13:18 |
Hi Dan,
here it is:
http:/
#28 |
Vincent RIVOLA
Rep Power: 18 |
February 7, 2007, 12:15 |
Forget the story of vec
#29 |
Vincent RIVOLA
Rep Power: 18 |
Forget the story of vectorField. I found a way to do what I wanted. Now, I have another problem. I would like to find a way to know the coordinates of the points which are on a boundary and their ordering inside a field. For example, if I have a velocity field with four points, OpenFOAM can easily write the values. But I would like to know to which point of the mesh belongs the first value, to wich point belongs the second value.... Is there a way to do that? The idea would be a function mesh.boundaryfield()[boundary1] which would return the coordinates of the points on the boundary1. But I haven't been able to find it in the code. Does such a thing allready exist? Thanks for your help, Vincent |
February 26, 2007, 10:16 |
Hi everybody,
This is the e
#30 |
Vincent RIVOLA
Rep Power: 18 |
Hi everybody,
This is the end of my internship and I have finished my thesis report. So I give the url if some people are interested in the work that I have done on FSI on balloons and also the converter GridPro2FOAM which is largely explained in the report. The beginning of the report won't be very interesting for many of you since it is just OpenFOAM tutorials, but the second part of the report is more on FSI and also the beginning of coupling between OF and Impact. Unfortunately, it's only the beginning since I spent a lot of time on the discovery and testing of OpenFOAM capacities. As you can imagine, six months of internship is really short! Anyway, if you have any questions or comments, don't hesitate. The report can be downloaded there: Thesis report Best regards, Vincent |
February 28, 2007, 03:48 |
Hi everybody,
As explained
#31 |
Vincent RIVOLA
Rep Power: 18 |
Hi everybody,
As explained sooner in this topic, I have to find the points which own to a specific boundary. I found a way to do it in 2D doing: mesh.boundaryMesh()[internalPatchID].boundaryPoints() However, this is not working in 3D and, even if I have an idea, I don't really understand why it is not working. So, does someone have an idea of how to fix it? Thanks in advance, Vincent |
March 1, 2007, 03:34 |
Hi Frank,
Thanks for your h
#32 |
Vincent RIVOLA
Rep Power: 18 |
Hi Frank,
Thanks for your hint. Finnaly I don't do exactly the same way but the localPoints() fonction helped me. For information my code is now: vectorList boundarypoint(n); forAll (mesh1.boundaryMesh()[internalPatchID].localPoints(), j) { boundarypoint[j] = mesh1.boundaryMesh()[internalPatchID].localPoints()[j]; } And this is working pefectly fine which is great since I can now deform my balloon shape in 3D. By the way, do you plan to update your website soon? I would be really interested in the results that you obtain on moving meshes. Best regards, Vincent |
April 23, 2007, 23:46 |
Hi Dear Foamers,
where can
#33 |
Daniel WEI (老魏)
Rep Power: 21 |
Hi Dear Foamers,
where can i get icoFsiFoam? I searched everywhere and cannt find it. is it replaced with another solver now(version 1.4)? And could anyone tell me what's the difference between icoFsiFoam and icoStructFoam? Thanks in advance Daniel
~ Daniel WEI ------------- Boeing Research & Technology - China Beijing, China |
April 25, 2007, 07:00 |
Hi Daniel,
I think the icoFsi
#34 |
Dragos
Rep Power: 20 |
Hi Daniel,
I think the icoFsiFoam solver comes only with the development version 1.3 from prof. Jasak. Try there! Dragos |
April 25, 2007, 07:48 |
Hi all,
I think that there'
#35 |
Guus Kupers
Rep Power: 17 |
Hi all,
I think that there's not a big difference between the two solvers. There are some differences involving mesh motion and coupling. And indeed icoFsiFoam is not (yet) available for OF-14. Guus |
April 25, 2007, 08:26 |
Hi Dragos and Guus,
Thanks
#36 |
Daniel WEI (老魏)
Rep Power: 21 |
Hi Dragos and Guus,
Thanks for your reply, Much appreciated When will it be available?(why not make it available) ...I will try to work on it for my thesis. now, I have a copy of icoStructFoam and turbForceFoam, but i'm very new to Foam and i dont know is it impossible to combine LES (oodles) with such and such to solve FSI. Any suggestion? Daniel
June 2, 2008, 21:47 |
Hi, everybody,
I am just ge
#37 |
jin xu
Rep Power: 17 |
Hi, everybody,
I am just gettine started with linux and OpenFoam. , also trying to run icoFsiFoam. After spending several days studying the solver and piecing togther the messages posted before, I think I have made some progress, but I still run into the same problems posted "By Guus Kupers on Monday, January 15, 2007 - 01:31 am". --> FOAM FATAL ERROR : Attempt to cast type fixedValue to type fixedValue From function refCast<to>(From&) in file /home/snail/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/typeInfo.H at line 103. I realize that I should rebuild the executable of tetPolyPatchCellDecomp and tetPolyPatchFaceCellDecomp. then I type: snail@snail-laptop:~/OpenFOAM/OpenFOAM-1.3/src/tetDecompositionFiniteElement/tetPolyMeshCellDecomp /tetPolyPatches/tetPolyPatch$ gcc tetPolyPatchCellDecomp.C and I end up with errors: snail@snail-laptop:~/OpenFOAM/OpenFOAM-1.3/src/tetDecompositionFiniteElement/tetPolyMeshCellDecomp /tetPolyPatches/tetPolyPatch$ gcc tetPolyPatchCellDecomp.C In file included from tetPolyPatchCellDecomp.C:27: tetPolyPatchCellDecomp.H:39:23: error: labelList.H: No such file or directory tetPolyPatchCellDecomp.H:40:25: error: vectorField.H: No such file or directory tetPolyPatchCellDecomp.H:41:25: error: triFaceList.H: No such file or directory tetPolyPatchCellDecomp.H:76: error: expected identifier before string constant tetPolyPatchCellDecomp.H:76: error: expected ',' or '...' before string constant tetPolyPatchCellDecomp.H:76: error: ISO C++ forbids declaration of 'TypeName' with no type tetPolyPatchCellDecomp.H:99: error: ISO C++ forbids declaration of 'word' with no type tetPolyPatchCellDecomp.H:99: error: 'word' declared as a 'virtual' field tetPolyPatchCellDecomp.H:99: error: expected ';' before '&' token tetPolyPatchCellDecomp.H:102: error: 'label' does not name a type tetPolyPatchCellDecomp.H:105: error: 'label' does not name a type tetPolyPatchCellDecomp.H:108: error: 'label' does not name a type tetPolyPatchCellDecomp.H:117: error: ISO C++ forbids declaration of 'labelList' with no type tetPolyPatchCellDecomp.H:117: error: 'labelList' declared as a 'virtual' field tetPolyPatchCellDecomp.H:117: error: expected ';' before '&' token tetPolyPatchCellDecomp.H:120: error: ISO C++ forbids declaration of 'vectorField' with no type tetPolyPatchCellDecomp.H:120: error: 'vectorField' declared as a 'virtual' field tetPolyPatchCellDecomp.H:120: error: expected ';' before '&' token tetPolyPatchCellDecomp.H:123: error: ISO C++ forbids declaration of 'vectorField' with no type tetPolyPatchCellDecomp.H:123: error: 'vectorField' declared as a 'virtual' field tetPolyPatchCellDecomp.H:123: error: expected ';' before '&' token tetPolyPatchCellDecomp.H:127: error: 'triFaceList' does not name a type tetPolyPatchCellDecomp.H:130: error: 'faceList' does not name a type tetPolyPatchCellDecomp.C:36: error: expected identifier before numeric constant tetPolyPatchCellDecomp.C:36: error: expected ',' or '...' before numeric constant tetPolyPatchCellDecomp.C:36: error: expected constructor, destructor, or type conversion before ';' token As I am also a beginner of linux, I am not sure my way of rebuliding the executable is correct, Could anyone give me some hints? Thanks in advance! jin |
June 3, 2008, 11:03 |
hello again,
I think I solv
#38 |
jin xu
Rep Power: 17 |
hello again,
I think I solved this problem using "./Allmake"(I should have seen it). jin |
September 14, 2016, 13:38 |
#39 | |
Viraj Belekar
Rep Power: 10 |
Hello, I am trying to use icoFsiFoam for blood flow in an artery. As I give the command, the simulation stops immediately without any error message at the following step: Create time Create dynamic mesh for time = 0 Selecting dynamicFvMesh dynamicMotionSolverFvMesh Selecting motion solver: laplace Selecting motion diffusivity: quadratic Reading transportProperties Reading field p Reading field U Reading/calculating face flux field phi Reading field U Reading mechanical properties Normalising E : E/rho Calculating Lame's coefficients Can anyone help? |
fluid structure interaction | taru agrawal | FLUENT | 4 | September 10, 2007 04:12 |
FLUID STRUCTURE INTERACTION | Javier | Main CFD Forum | 5 | October 11, 2004 05:22 |
Fluid-Structure Interaction for VOF | Zi-Wei Chiou | Main CFD Forum | 4 | November 27, 2001 10:26 |
Fluid Structure Interaction | Delly | Main CFD Forum | 2 | November 26, 2001 13:01 |
Fluid-Structure Interaction | Gabor BALINT | Main CFD Forum | 5 | October 12, 1999 05:54 |
