How does one convert a scalarField into a volScalarField
Like Tree2Likes
Old   June 3, 2008, 06:59
Default Hi Su, well i have cyclic con
  #21
davey david
suredross is on a distinguished road
Hi Su,
well i have cyclic conditions for the inlet/outlet,symmetry plane bottom and three electrode patches with psi = 1/-1,alternating and fixed walls having a zero gradient.
how do i get to compile the code to suit my case?do i simply omit the temporal terms?
thanks in advance
davey
suredross is offline   Reply With Quote
Old   June 3, 2008, 21:44
Default Hi davey you got a uniform
  #22
su_junwei's Avatar
su junwei
su_junwei is on a distinguished road
Send a message via MSN to su_junwei
Hi davey
you got a uniform field with laplaceFoam solver?
Su Junwei
su_junwei is offline   Reply With Quote
Old   June 5, 2008, 06:26
Default Hi Su, yes,i do have a unifor
  #23
davey david
Hi Su,
yes,i do have a uniform field but i used the icofoam solver and commented out all the pressure and velocity terms ,whiles adding my laplace equation to it.seems to be working fine.will keep you posted on any mishaps which might crop up.
thanks
davey
Old   August 4, 2016, 10:43
elham usefi
elham usefi is on a distinguished road
Originally Posted by su_junwei View Post
Hi Heng
It doesn't seem that ScalarField can write itself into a file.
To make a object auto writing, one have to register it using regIOobject.
try dimensionedField or use the internalField() of volScalarField
volScalarField temp
IOobject
"temp",
mesh.time().timeName(),
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE
mesh
dimensionedScalar("zero", dimensionSet(0,0,0,0,0,0,0), 0.0),
zeroGradientFvPatchField<scalar>::typeName
scalarField &sf=temp.internalField();
sf=....
Su Junwei
Hi su_junwei
I have a question! what does exactly the last zero in
refers to?
elham usefi is offline   Reply With Quote
How to sum up scalarField wese OpenFOAM Running, Solving & CFD 2 August 19, 2019 18:30
How to set up an AUTO_WRITE scalarField xiao OpenFOAM Running, Solving & CFD 9 July 22, 2010 04:23
max for scalarField maka OpenFOAM Bugs 9 February 19, 2009 10:43
ScalarField division maka OpenFOAM Pre-Processing 2 August 27, 2007 06:10
[CGNS] Computing a cellcentered scalarField from a vertexcentered scalarField mbeaudoin OpenFOAM Meshing & Mesh Conversion 10 February 22, 2007 08:43
