TimeVaryingMappedFixedValue
Old   May 29, 2008, 05:39
Default Hi, everyone, I want to use
Vivien
sunnysun is on a distinguished road
Hi, everyone,
I want to use timeVaryingMappedFixedValue for my inlet velocities and I set different velocity values for each time step for my simulation (in this case, deltaT = 0.0002 s).
I created the directories in constant/boundaryData/inlet/:
constant/boundaryData/inlet/points
constant/boundaryData/inlet/0/U
constant/boundaryData/inlet/0.0002/U
constant/boundaryData/inlet/0.0004/U
constant/boundaryData/inlet/0.0006/U
However, when I run the case(using icoFoam and the time step is set to be 0.0004), I got the following errors:
Create time
Create mesh for time = 0
Reading transportProperties
Reading field p
Reading field U
Starting time loop
Time = 0.0004
Courant Number mean: 0 max: 0.362781
10061
0
0.0002
0.0004
0.0006
0.0008
0.001
0.0012
0.0014
0.0016
3.2
In directory "constant/boundaryData/inlet"
on patch inlet of field U in file "/vol/isdata8/FIXI-Flow/QiSUN/openfoamtest/Second/ExpeCylinder1uP9/0/U"
From function findTime
in file fields/fvPatchFields/derived/timeVaryingMappedFixedValue/timeVaryingMappedFixedV alueFvPatchField.C at line 470.
FOAM exiting
Could anyone help me ?
Thank you very much in advance!!
sunny
sunnysun is offline   Reply With Quote
Old   May 29, 2008, 19:19
Default Switch on the debug flag for t
Mattijs Janssens
mattijs is on a distinguished road
Switch on the debug flag for the b.c: Set timeVaryingMappedFixedValue to 1 in your ~/OpenFOAM-1.4.1/controlDict.
Have a look at the source ($FOAM_SRC/finiteVolume/lnInclude/timeVaryingMappedFixedValueFvPatchField.C) to see what is happening.
mattijs is offline   Reply With Quote
Old   May 30, 2008, 04:44
Default Hi,Mattijs, Thanks for the
Vivien
Hi,Mattijs,
Thanks for the reply!
I am really new to this, so...can you explain a bit more how to do this?? Thanks!!
Vivien
Old   May 30, 2008, 07:46
Default There are several controlDict
John Deas
johndeas is on a distinguished road
There are several controlDict in OpenFOAM.
One is located by default in $HOME/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1
It contains commonly used by all solvers. You have various sections in it, the one of interrest for you would be "DebugSwitches". Set it to 1 for timeVaryingMappedFixedValue. This will force timeVaryingMappedFixedValue to be more verbose in its output, and will help debug.
Then, you have a specific controlDict in every case you run, which is only use by the case it belongs to, and contain other infos, but no debugSwitches.
johndeas is offline   Reply With Quote
Old   June 2, 2008, 12:01
Default Hi, John and Mattijs, I cha
Vivien
I changed the DebugSwitches in controlDict and save the changes. But When I run the case, I did not get any more information, ie, the error is exactly the same as I posted before...
Any ideas?
Thanks!!
vivien
Old   June 2, 2008, 15:30
Default The controlDict file is first
Mattijs Janssens
The controlDict file is first looked for in
~/.OpenFOAM-1.4.1/controlDict
and then in
~/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1
Old   June 3, 2008, 06:35
Default Hi, Mattijs, do you mean th
Vivien
Hi, Mattijs,
do you mean there are two controlDict I need to edit?
I only find one in ~/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/controlDict and I change the DebugSwitches for timeVaringMappedFixedValue to 1, but I did not see much information after I run the solver.
Thanks!
Vivien
Old   June 3, 2008, 19:35
Default Have a look at the sources: $F
Mattijs Janssens
Have a look at the sources: $FOAM_SRC/finiteVolume/lnInclude/timeVaryingMappedFixedValueFvPatchField.H
It is the 'TypeName' macro which specifies the name. This is the exact name you should use in the controlDict. In your post you mention 'timeVaringMappedFixedValue' instead of 'timeVaryingMappedFixedValue'.
Old   June 4, 2008, 10:40
Default Hi, Mattijs, This is not t
Vivien
Hi, Mattijs,
This is not the problem...
I made a simpler case that there are only 5 time step in constant->boundaryData->inlet(which are 0 0.0002 0.0004 0.0006 0.0008), the geometry is a cylinder and contain 100 points at inlet. After I run icoFoam, I got the following errors and seems the order of files are sorted:
Create time
Reading field p
Reading field U
timeVaryingMappedFixedValue : construct from dictionary
timeVaryingMappedFixedValueFvPatchField : Read 100 sample points from "/openfoamtest/NewCase/constant/boundaryData/inlet/points"
timeVaryingMappedFixedValueFvPatchField : Used points (0.00138321 0.00138321 0) (0.00154865 0.00111043 0) (0.00167642 0.000812023 0) to define coordinate system with normal (0 0 -1)
readSamplePoints : Dumping triangulated surface to triangulation.stl
readSamplePoints : Dumping face centres to "/openfoamtest/NewCase/localFaceCentres.obj"
timeVaryingMappedFixedValueFvPatchField : In directory "/openfoamtest/NewCase/constant/boundaryData/inlet" found times
5
0.0008
0
0.0002
0.0004
0.0006
--> FOAM FATAL ERROR : Cannot find starting sampling values for current time 0
Have sampling values for times
5
0.0008
0
0.0002
0.0004
0.0006
on patch inlet of field U in file "/openfoamtest/NewCase/0/U"
FOAM exiting
Do you know why this is hapening?
Many thanks!!
Vivien
Old   June 4, 2008, 17:36
Default Could you try with this findTi
Mattijs Janssens
Could you try with this findTimes.C (src/OpenFOAM/db/Time/findTimes.C)?
(It was using this routine to detect the time directories inside constant/boundaryData. There was an assumption in it that the time directories would always have a 'constant')
You'll have to rebuild the OpenFOAM library (wmake libso $FOAM_SRC/OpenFOAM)
John Deas, this should also fix your problem - couldn't repeat it on your case since it depends on the original file order.
findTimes.C
Old   June 5, 2008, 04:56
Default Hi, Mattijs, It is working
  #11
Vivien
Hi, Mattijs,
It is working now, thank you very much!
Vivien
Old   June 5, 2008, 06:52
Default Thanks Mattijs, now I am stuck
  #12
John Deas
Thanks Mattijs, now I am stuck with creating the timeVaryingMappedFixedValue on another thread, but will test it as soon as possible !
Old   October 30, 2013, 16:22
Manjura Maula Md. Nayamatullah
mmmn036 is on a distinguished road
I was trying to use timeVaryingMappedFixedValue bc to get U, k , nuSgs fields value from precursor run to my inlet to have turbulence.
I used sample utility to get the field data at precursor run. I added 11 time directory (0,1,2,3.....10) at constant/boundaryData/inlet. Simulation timestep is 0.001.
It works fine until the simulation blows out at 2.158 s because of courant no. reaches a huge value.
I am adding the log file here.
Anyone faces that kind of problem? Any help will be appreciated.
Thanks
MMMN
mmmn036 is offline   Reply With Quote
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 07:55
TimeVaryingMappedFixedValue field creation johndeas OpenFOAM Running, Solving & CFD 24 June 14, 2021 15:56
TimeVaryingMappedFixedValue best practice to extract subset points and fields podallaire OpenFOAM Running, Solving & CFD 6 May 21, 2014 11:25
Possible bug with timeVaryingMappedFixedValue jerome OpenFOAM Bugs 2 October 9, 2007 10:38
