Problem with fluidized bed simulation using TwoPhaseEulerFoam
Old   June 11, 2008, 06:08
Default Dear FOAMers, I try to get
Matthias Schreiber
matthias_schreiber is on a distinguished road
Dear FOAMers,
I try to get familiar with the twoPhaseEulerFoam-Solver in order to do bubbling fluidized bed simulations in the future. Therefore I started with the tutorial "bed2", but ran into various problems:
a) After some timesteps alpha becomes larger than the setting for alpha_max, finally leading to a blown-up alpha-equation.
Last output:
DILUPBiCG: Solving for alpha, Initial residual = 0.00204016, Final residual = 6.59748e-11, No Iterations 4
Dispersed phase volume fraction = 0.275033 Min(alpha) = -3.08343e-18 Max(alpha) = 0.854645
DILUPBiCG: Solving for alpha, Initial residual = 9.44561e-05, Final residual = 3.20813e-12, No Iterations 4
Dispersed phase volume fraction = 0.275033 Min(alpha) = -3.08222e-18 Max(alpha) = 0.854609
GAMG: Solving for p, Initial residual = 0.00263152, Final residual = 6.91613e-09, No Iterations 27
time step continuity errors : sum local = 2.04471e-09, global = 2.39621e-10, cumulative = 3.95656e-07
DILUPBiCG: Solving for alpha, Initial residual = 0.00101853, Final residual = 5.98548e-11, No Iterations 4
Dispersed phase volume fraction = 0.275033 Min(alpha) = -3.08317e-18 Max(alpha) = 0.854606
DILUPBiCG: Solving for alpha, Initial residual = 8.03968e-05, Final residual = 3.01421e-11, No Iterations 167
Dispersed phase volume fraction = -5.04093 Min(alpha) = -25360.6 Max(alpha) = 8585.28
1 additional process aborted (not shown)
b) The bed expansion is not uniform and looks like a funnel.
Picture:
c) There are "fallen vortices" of high theta values on the side walls of the freeboard.
Picture:
Does anybody has some hints or best-practice guidelines for this kind of simulation with OF?
Many Thanks in advance.
Matthias
matthias_schreiber is offline   Reply With Quote
Old   June 11, 2008, 12:28
Default Servus Matthias, there are
lord_kossity's Avatar
Andreas Dietz
lord_kossity is on a distinguished road
Servus Matthias,
there are several threads about twoPhaseEulerFoam.
http://www.cfd-online.com/OpenFOAM_D...es/1/6470.html
http://www.cfd-online.com/OpenFOAM_D...es/1/1019.html
First one is quite general about the parameters in this solver
Second one is more about the issue of convergence problems regarding overpacking.
Regards,
Andreas
lord_kossity is offline   Reply With Quote
Old   June 11, 2008, 12:44
Default Hello Andreas, before posti
Matthias Schreiber
Hello Andreas,
before posting I searched for related threads and also consulted the ones you mentioned already. Unfortunately I still have problems to set up a converging simulation.
Regards,
Matthias
Old   June 11, 2008, 13:49
Default Hello Matthias, tomorrow I
Andreas Dietz
Hello Matthias,
tomorrow I could send you one of my cases if you are then still intersted in them and provide me your email.
Old   June 12, 2008, 04:37
Default Hello Andreas, this would b
Matthias Schreiber
Hello Andreas,
this would be very nice. Please use this email address:
matthias.schreiber_at_tu-cottbus.de
Thanks a lot!
Matthias
Old   June 12, 2008, 07:49
Default Unfortunately Andreas' case wa
Matthias Schreiber
Unfortunately Andreas' case was a bubble column and no fluidzed bed simulation.
So, are there some FOAMers with experience in using kinetic theory for gas-solid fluidzed beds?
Regards,
Matthias
fluidized bed simulation hosseini CFX 1 July 28, 2010 15:45
Fluidized Bed Simulation Siaw Khur CFX 9 July 28, 2010 15:43
Fluidized bed simulation Siaw Khur CFX 3 July 28, 2010 15:42
Fluidized Bed Simulation dyxu OpenFOAM Running, Solving & CFD 1 August 4, 2007 22:50
