Shock tube Problem
Old   August 22, 2007, 06:46
Default I am getting error message whi
kalaiselvan
21kalee is on a distinguished road
I am getting error message while running the already defined tutorial case file in sonicFoam. This happens for the case file "shockTube".
The following error message is shown:
Foam::error::printStack(Foam:stream&)
Foam::sigFpe::sigFpeHandler(int)
[0xffffe420]
Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&)
void Foam::divide<double,>(Foam::GeometricField<double, >&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&)
Foam::tmp<foam::geometricfield<double,> > Foam::operator/<double,>(Foam::tmp<foam::geometricfield<double, > > const&, Foam::tmp<foam::geometricfield<double,> > const&)
sonicFoam [0x805b611]
__libc_start_main
__gxx_personality_v0
Can anyone sort out the problem and explain me the same. I am a beginner
21kalee is offline   Reply With Quote
Old   August 22, 2007, 06:51
Default Somewhere for some reason your
Hrvoje Jasak
Somewhere for some reason your code is dividing by zero. Is your initial pressure or temperature field zero by any chance? Did you run initialisation for the case?
Hrv
Hrvoje Jasak
Old   June 12, 2008, 07:57
Default You should run setShock first
ash
Arun Shourie
ash is on a distinguished road
You should run setShock first to get the values of p,U and T updated....
then try for running the case file. It will definitely work
ash is offline   Reply With Quote
Shock Tube problem mouna lamnaouer FLUENT 1 September 22, 2011 13:47
Sod Shock Tube problem cfd Main CFD Forum 4 July 7, 2009 14:24
SOD shock tube problem Luuk Main CFD Forum 3 September 6, 2005 06:08
Shock tube problem AB Siemens 1 November 9, 2004 01:25
Shock tube problem ger Main CFD Forum 1 September 24, 2003 08:41
