Doubt on yEqnH
Old   June 14, 2008, 20:09
Default The yEqn.H files goes like thi
ash
Arun Shourie
ash is on a distinguished road
The yEqn.H files goes like this....
start of the yEqn.H file
tmp<fv::convectionscheme<scalar> > mvConvection
fv::convectionScheme<scalar>::New
label inertIndex = -1;
volScalarField Yt = 0.0*Y[0];
for(label i=0; i<Y.size(); i++)
if (Y[i].name() != inertSpecie)
volScalarField& Yi = Y[i];
solve
fvm::ddt(rho, Yi)
+ mvConvection->fvmDiv(phi, Yi)
- fvm::laplacian(turbulence->muEff(), Yi)
kappa*chemistry.RR(i),
mesh.solver("Yi")
Yi.max(0.0);
Yt += Yi;
else
inertIndex = i;
Y[inertIndex] = scalar(1) - Yt;
Y[inertIndex].max(0.0);
End of file yEqn.H
My question is what is the mathematical equation or expression for the yEqn.....
Is it, as follows.... please correct me if wrong.
d(rho,Yi)/dt + d(rho*u*Yi)/dx + d2(mu*Yi)dx2 = ??? (obviously, have written for the x-component)
I could guess the left hand side of the equation.... But i couldn't understand the right hand side of the equation...
Or to put my question in the other way, what are the terms "kappa*chemistry.RR(i),
mesh.solver("Yi")"
Help needed. Explain in a way, such that, whomsoever is new to openfoam can and I am new to foam.....
ash is offline   Reply With Quote
Old   June 15, 2008, 01:11
Default Hi Which combustion solver
srinath
srinath is on a distinguished road
Hi
Which combustion solver are you referring to?reactingFoam?
In icoFoam, u have a similar expression, in the PISO loop
Ueqn.H()-- gives the non-diagonal + source terms of the matrix, but doesn't invlove the grad p term.
Here is a good reference for PISO in icoFoam, which u may find useful.
http://www.tfd.chalmers.se/~hani/kur...7/rhiechow.pdf
Do you have a reference for reactingFoam, trying to figure out the algo without a reference is very hard.
Cheers
Srinath
srinath is offline   Reply With Quote
Old   June 15, 2008, 06:32
Default I dont have any reference as s
ash
Arun Shourie
I dont have any reference as such for the solver reactingFoam... someone please
Old   June 15, 2008, 15:36
Default Since this equation is species
KaLee_Kun
kaleekun is on a distinguished road
Since this equation is species conservation equation, the right hand side must be the source term, that is, rate of production or consumption of the species. I have looked up for the fucnction chemistry.RR ----> it was stated as the chemical source term.
But I am not sure about the variable 'kappa' and the function, mesh.solver("Yi")
I guess someone should help him further
kaleekun is offline   Reply With Quote
Old   June 15, 2008, 16:31
Default As you can see the (laminar) c
Ville Tossavainen
villet is on a distinguished road
As you can see the (laminar) chemical source term is multiplied by "kappa". This is a correction for turbulent reactive flows.
Next check out "chemistry.H" file and you can see how "kappa" is calculated. If the turbulence correction is not taken into account, "kappa" is set to "1.0".
I don't have a reference for the Chalmers PaSR model, but maybe there's someone else who can help you.
villet is offline   Reply With Quote
Old   August 17, 2010, 14:33
sahm's Avatar
Seyyed Ali H.M.
sahm is on a distinguished road
HI everyone,
I have a question . In the Yeqn equation, for diffusion of Yi, the coefficient used is Mu, why is that Mu? Why it's not D ( binary mass diffusion coefficient) ?
Can anybody give a reference for this?
SAHM
sahm is offline   Reply With Quote
Doubt Rishikesh FLUENT 0 February 24, 2009 04:32
doubt in B.C student Main CFD Forum 5 November 23, 2008 03:40
Doubt New User FLUENT 2 July 12, 2008 00:50
A doubt Alberto Passalacqua (Alberto) OpenFOAM Pre-Processing 5 November 28, 2006 10:22
a doubt G.Balakrishnan FLUENT 0 November 27, 2000 02:48
