FoamLog for my case
Old   June 14, 2006, 00:04
Default Hi friends, I am trying to
Guoxiang
liugx212 is on a distinguished road
Hi friends,
I am trying to get the plot of the case. After I used "foamJob buoyantFoam . hotRoom" and got computing result, but when I used the foamLog to plot, I was told as follows error, Could any friend do me a help?
Thanks a lot.
Error:
[liu@liu buoyantFoam]$ foamLog . hotRoom logFile
foamLog: Cannot read log logFile
or
liugx212 is offline   Reply With Quote
Old   June 14, 2006, 02:16
Default Did you create the log file in
Hrvoje Jasak
Did you create the log file in the first place: this is the stuff that the solver writes on the screen (stored in a file). You should do somehing like
icoFoam <root> <case> | tee log
or similar: that will leave you a log file.
Hrv
Hrvoje Jasak
Old   June 14, 2006, 10:29
Default Hi Hrvoje Jasak, Many thank
Guoxiang
Hi Hrvoje Jasak,
Many thanks for your advice. I got some files in logs directory. But I also want to get the plot figure as your given on http://www.cfd-online.com/OpenFOAM_D...ages/1/17.html
Could you please give more advice?
Thanks again.
Old   June 14, 2006, 10:37
Default Aha. Go to the logs directory
Hrvoje Jasak
Aha. Go to the logs directory and type
xmgrace Ux_0 Uy_0 p_0 k_0 epsilon_0
If you haven't got xmgrace, please install it - it will be one of the rpm packages or downloaded free off the web. You can then play with the legend and axes to get the picture you want.
Enjoy,
Hrv
Hrvoje Jasak
Old   June 27, 2006, 23:42
Default Hi Hrvoje Jasak, Thanks so
Guoxiang
Hi Hrvoje Jasak,
Thanks so much. But I still have a question. I have some components such as p (pressure), rho (density) and T (temperature) etc which were defined in createFields file. But after running: icoFoam <root> <case> | tee log &
foamLog . hotRoom log. I only get some files as Ux_0 Uy_0 p_0 k_0 etc. Actually, I want to get the values for each components because I want to plot them with time. Could you please give some advice?
Thanks in advance.
Old   June 28, 2006, 12:03
Default Hi friends, Could you pleas
Guoxiang
Hi friends,
Could you please give advice how to plot multi-component?
Thanks so much.
Old   June 18, 2008, 09:16
Default Hi everybody, Sorry for dig
feng wang
fw407 is on a distinguished road
Hi everybody,
Sorry for digging out this old thread. I am also trying to make OF to plot the residual history for my case. As a test, I try to plot the residuarl history for plateHole. Afte having created the "logs" file, I cd into the "logs" directory and type
snail@snail-laptop:~/OpenFOAM/snail-1.3/run/tutorials/stressedFoam/plateHole/logs$ xmgrace UxFinalRes_0
I always get something like "xmgrace: Symbol `_XmStrings' has different size in shared object, consider re-linking" in the terminal, and there is not graph drawn in the grace. Does anybody know how to fix it?
(PS: I am using Ubuntu 7.10)
Thanks in advance!
feng
fw407 is offline   Reply With Quote
Old   June 18, 2008, 09:27
Default Looks like a mismatch in the m
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Looks like a mismatch in the motif versions.
If you try a plain "xmgrace" (without any arguments) and see the same error, you can be sure that it has nothing to do with OpenFOAM.
Take a look through Ubuntu or other Linux forums to see why the library and executable aren't matching.
olesen is offline   Reply With Quote
Default It seems that your xmgrace sof
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
It seems that your xmgrace software is not properly installed. Can you ran it at all?
Dragos
dmoroian is offline   Reply With Quote
Old   June 18, 2008, 14:12
Default Hi Mark, Dragos, Thanks for
feng wang
Hi Mark, Dragos,
Thanks for your quick reply!
I try a plain "xmgrace" and see the same error. There are some errors about compatibility in the process of installation,maybe "xmgrace" is not compatible with ubuntu 7.10.
Is there an alternative method of plotting the graph in OF?
feng
Using foamLog liamm OpenFOAM Running, Solving & CFD 17 September 10, 2020 05:00
Help! Should I use LES in this case. Thanks. Feng FLUENT 4 April 25, 2008 18:04
Cloning a case or creating a new case for 16 processes mellanoxuser OpenFOAM Running, Solving & CFD 0 February 8, 2008 17:52
Problems with foamLog and interFoam OF 14 sinusmontis OpenFOAM Bugs 2 June 1, 2007 09:57
Problem seeing new case in case browser alan_fergus OpenFOAM Pre-Processing 9 June 22, 2006 04:46
