Stdbad_cast error
Like Tree2Likes
Old   March 8, 2005, 14:52
Default Hi all, I've set up a diese
Ervin Adorean
adorean is on a distinguished road
Hi all,
I've set up a dieselFoam case with an axi-symmetric mesh. When I try running it, get the following error:
Exec : dieselFoam /home/ervin/OpenFOAM/ervin-1.0.2/run/tutorials/dieselFoam spray
Date : Mar 08 2005
Time : 19:46:25
Host : isi014.mot.upv.es
PID : 11157
Root : /home/ervin/OpenFOAM/ervin-1.0.2/run/tutorials/dieselFoam
Case : spray
Nprocs : 1
Create database
Create mesh for time = 0
Reading thermophysicalProperties
Selecting thermodynamics package hMixtureThermo<dieselmixture<sutherlandtransport<s peciethermo<janafthermo<perfec tgas>>>>>
Reading field U
Creating turbulence model.
Selecting turbulence model RNGkEpsilon
Creating field DpDt
Constructing chemical mechanism
terminate called after throwing an instance of 'std::bad_cast'
what(): St8bad_cast
Can you please tell me how to correct it?
Thanks!
Ervin
adorean is offline   Reply With Quote
Old   March 9, 2005, 08:51
Default Hi, Try this in constant/th
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
Try this in constant/thermophysicalProperties
thermoType hMixtureThermo<reactingmixture>;
N
niklas is offline   Reply With Quote
Old   March 9, 2005, 08:54
Default ...ok the mail and www version
niklas's Avatar
Niklas Nordin
...ok the mail and www version of the reply are not the same so have a look at the www version.
N
Old   March 9, 2005, 11:10
Default Hi Niklas, Now it says:
Ervin Adorean
Hi Niklas,
Now it says:
--> FOAM FATAL IO ERROR : keyword CHEMKINFile is undefined in dictionary "/home/ervin/OpenFOAM/ervin-1.0.2/run/tutorials/dieselFoam/spray/constant/thermo physicalProperties"
file: /home/ervin/OpenFOAM/ervin-1.0.2/run/tutorials/dieselFoam/spray/constant/thermop hysicalProperties from line 28 to line 44.
Function: dictionary::lookupEntry(const word& keyword) const
in file: db/dictionary/dictionary.C at line: 148.
FOAM exiting
I actually want to simulate a non-reactive, non-evaporating spray. Why does it ask me for a CHEMKINFile?
Thanks!
Ervin
Old   March 9, 2005, 13:54
Default Hi, It needs the chemkin fi
niklas's Avatar
Niklas Nordin
It needs the chemkin file because from that it reads which species to use in the simulation
and it also needs the thermo data even though it is a non-evaporating, non-reactive spray.
is it without heat-transfer also?
...only then is the chemkin stuff 'useless'
bear in mind that the spray library has been developed towards a multi-component, real chemistry approach.
if you want to track particles using an incompressible approach you can easily rename dieselSpray and remove everything related to
mass/heat transfer.
N
Old   March 10, 2005, 08:54
Default Hi, For a non-evaporating,
Ervin Adorean
For a non-evaporating, non-reactive, with heat transfer, spray case got the following error message:
--> FOAM FATAL IO ERROR : keyword liquidFuelComponents is undefined in dictionary "/home/ervin/OpenFOAM/ervin-1.0.2/run/tutorials/dieselFoam/spray/constant/thermo physicalProperties"
What parameter is liquidFuelComponents and how should I add it to "thermophysicalProperties"? (with what values?)
Thanks
Ervin
Old   March 10, 2005, 09:08
Default Hi, liquidFuelComponents ar
niklas's Avatar
Niklas Nordin
liquidFuelComponents are the components that you want to use for the liquid fuel and for those components
you must also define the thermal/physical properties. (cp, surface tension, viscosity...etc)
If you want the default properties you would add this to you dictionary.
nameOfFuel
nameOfFuel nameOfFuel defaultCoeffs;
so....
lets assume your fuel is nHeptane. You would then add this.
C7H16
C7H16 C7H16 defaultCoeffs;
Note that the naming convention follow the chemkin format.
and if you want to use a liquid that consists of three components you could use
C10H22
C7H16
aC10H11
and add the thermal/physical specifications for those components.
Next error message you will get will probably be related to the injector, since you must also
define each molar concentration X.
so for a single component you'd have to add
X
1
to your injectorProperties.
easy peasy
N
Old   March 16, 2005, 08:05
Default Hi, If I use C7H16 I get th
Ervin Adorean
If I use C7H16 I get this error:
Create time
Selecting thermodynamics package hMixtureThermo<reactingmixture>
Selecting chemistryReader chemkinReader
Reading field U
Creating field DpDt
Selecting ODE solver SIBS
chemistryModel::chemistryModel: Number of species = 5 and reactions = 1
Reading environmentalProperties
Reading combustion properties
Constructing Spray
Selecting injectorType unitInjector
Selecting atomizationModel blobsSheetAtomization
Selecting dragModel standardDragModel
Selecting evaporationModel off
Selecting heatTransferModel RanzMarshall
Selecting wallModel reflect
Selecting breakupModel ReitzKHRT
Selecting collisionModel trajectory
Selecting dispersionModel off
Selecting injectorModel constInjector
Average Velocity for injector 0: 357.207 m/s, injection pressure = 591.789 bar
Constructing two dimensional spray injection.Calculated angle of wedge is 4.99791 deg.
Max Courant Number = 0
Starting time loop
deltaT = 1e-05
Time = 1e-05
Evolving Spray
Segmentation fault
Can you please tell me what coul this error mean?
Thanks!
Ervin
Old   March 16, 2005, 08:34
Default Hi, you need to define the
niklas's Avatar
Niklas Nordin
you need to define the properties of C12H26 in thermo.dat
As far as what the constants mean the forward reaction rate is given by the Arrhenius expression
kf = A*(T^n)*exp(-Ea/(R*T)),
where the 3 values are A n Ea,
the reactionrate is then calculate using the molar concentration of the species and the FORD values
w = - kf * c_fuel^FORD_fuel * c_ox^FORD_ox
but since you dont have evapotation you might as well turn off the chemistry, by setting
chemistry off
in chemistryProperties.
The segmentation fault error doesnt tell me anything about whats causing it.
analyze the core-dump with gdb, if you dont know how to do that you can find it somewhere here on the forum.
N
Old   March 16, 2005, 08:39
Default > analyze the core-dump with g
Michael Conry
conry is on a distinguished road
Also, for anyone unfamiliar with gdb, there
is a graphical frontend "ddd" that offers a
slightly easier introduction to GNU debugging.
This is especially useful for those who would
use gdb only occasionally.
Michael
conry is offline   Reply With Quote
Old   March 16, 2005, 08:57
Default Hi Sorry I noticed that I forg
  #11
niklas's Avatar
Niklas Nordin
Hi Sorry I noticed that I forgot one question:
>What are all the numbers in:
fuel C7H16 1 100.203 280 5000 1000 17.47 0.0421342 -1.6429e-05 2.99636e-09 -2.06488e-13 -31665.8 -64.7621 11.1532 -0.00949415 0.000195571 -2.49753e-07 9.84873e-11 -26753.1 -15.9228 1.67212e-06 170.672;?
These are the coefficients for the NASA polynomials, but you should replace 'fuel' by the name of the actual name the fuel.
All liquid components must have an associated gas component with the same name.
N
Old   March 16, 2005, 09:04
Default Me again, try to turn off t
  #12
niklas's Avatar
Niklas Nordin
Me again,
try to turn off the collision model.
N
Old   March 16, 2005, 09:13
Default Just found the 'bug'. in tr
  #13
niklas's Avatar
Niklas Nordin
in trajectoryModel.C add the if statement to the beginning.
void trajectoryCollisionModel::collideParcels(const scalar dt) const
if (spray_.size() < 2)
return;
spray::iterator secondParcel = spray_.begin();
... etc.
N
Old   March 22, 2005, 12:58
Default Hi, The 'chemistry off' swi
  #14
Ervin Adorean
The 'chemistry off' switch in chemistryProperties file doesn't work.
What else should be modified to turn off chemistry?
Thanks!
Ervin
Old   March 23, 2005, 08:03
Default Hi, nothing... and it works
  #15
niklas's Avatar
Niklas Nordin
nothing... and it works fine for me.
Note though that is writes the 'Solving Chemistry' even
though it doesn't actually solve it.
N
Old   April 1, 2005, 05:09
Default Hello, I've run the 'aachen
  #16
Ervin Adorean
I've run the 'aachenBomb' case and an axisymmetric case of diesel injection without evaporation, and have a few questions:
1) In both cases, the spray looks very narrow when represented with spherical glyphs, for example, in paraFoam. The spray doesn't "open". At least in a 2/3 of it's penetration length. Can this be corrected? Or how should I postprocess it to look more "realistic"?
2) The Schmidt number is calculated or should it be imposed? Can the Sc number be imposed? Where exactly? In "turbulenceProperties"?
3) The "nParcels" represents what? In the "aachenBomb" case, in "injectorProperties" has a value of 5000. At the end of the injection there are 17065 parcels in the system, at time 0.00125 s.
4) Can 'chem.inp.full' be used, with 56 species and 290 reactions instead of chem.inp, with 5 species and 1 reaction?
Thank you!
Ervin
Old   April 1, 2005, 05:27
Default Hi, 1. This is a typical '
  #17
niklas's Avatar
Niklas Nordin
1. This is a typical 'problem' when using too small initial droplet size, or breakup is too fast.
Remember that for 2D there is a strong flow direction towards the axis and small droplets is carried back to the symmetry axis by the gas.
2. The Schmidt number is 1.0. If you want to change it look into the file YEqn.H and
modify the line
fvm::laplacian(turbulence->muEff(), Yi)
to for instance
fvm::laplacian(turbulence->muEff()/Sc, Yi)
where Sc is a suitable scalar
3. the nParcels represents the total number of parcels to inject for that injector. My guess is that you are using the KHRT breakup model. Remember that drops can then break-up and form new child parcels, so if you dont have evaporation the number of parcels will definitely be higher than 5000.
4. of course, either change the input in thermodynamicalProperties to point the that file or rename it to chem.inp
Old   April 1, 2005, 06:19
Default Hi Niklas, Thank you for yo
  #18
Ervin Adorean
Hi Niklas,
Thank you for your swift answers.
In the following, I'm refering to the axisymmetric case.
Yes, I'm using the Reitz KHRT breakup model.
The 'dropletNozzleDiameterRatio' is 1.0, this means that I can't increase the droplet initial size, if I'm right.
So, for slowing down the breakup rate, should I change (increase) B1? Or, what else?
Which atomization model is more suitable for this case?
Is there a limit to 'nParcels'? Or some guidelines for it's value for 3D and for axi-symmetric cases?
Thanks,
Ervin
Old   April 1, 2005, 08:59
Default Hi, The dropletNozzleDiamet
  #19
niklas's Avatar
Niklas Nordin
The dropletNozzleDiameterRatio can have any value, although physically it doesnt make sense to use a larger value than 1.
For a wider angle you can always increase the sprayConeAngle. It is not uncommon to use a larger value than the measured one since the gas flow always will reduce it.
For atomization model I have no right answer.
Experience is the key when modeling sprays.
I normally ignore atomization and go straight for the Rosin-Rammler pdf for initial drop size.
After a while you can pretty much 'guess' what it should be.
If you want to increase the angle you can always turn on the turbulent dispersion.
There is no limit for nParcels, in general the more parcels the better statistics of the liquid, but at around 5000, for this 2D case, it only increase the computational time.
For guidelines on the number of parcels you can take the total injected volume and divide it with what you think is a characteristic droplet diameter. This will give you the total number of 'drops' in the spray and if you set nParcels to a higher value than this each parcel will represent fractions of droplets instead of parcels of droplets.
For instance in your case,
if you assume characteristic droplet size equal to nozzle diameter the number of drops will be approx. 2500, but if you reduce the characteristic
size by a 10th the number of droplets go up to 2.5 millions.... this is of course for 3D calc.
Also, I'm wondering why you want to use the full chemical mechanism when you dont have any evaporation. Where does the fuel come from?
It sounds like a bad idea to me.
N
Old   April 1, 2005, 09:17
Default Hi, Can you please tell me
  #20
Ervin Adorean
Can you please tell me how and where can I turn on the turbulent dispersion?
I've asked the question about the full chemical mechanism, having a different case in mind, a 3D sector of a 'real' Diesel engine, with evaporation.
Thanks
Ervin
Error: Floating point error: invalid number fpingqian FLUENT 4 February 8, 2012 02:20
Errors when Compiling UDF: error C2040/error C2099 Julian K. FLUENT 1 December 21, 2008 01:23
"Error: Floating point error: invalid number" MI Kim FLUENT 2 January 4, 2007 11:00
Fatal error error writing to tmp No space left on device maka OpenFOAM Installation 2 April 3, 2006 09:48
Error: Internal error at line 743 in file 'amgif.c H.S.Fang FLUENT 2 January 7, 2002 02:57
