July 1, 2008, 08:01 |
I'm working on a modifi
Juho Peltola
Rep Power: 17 |
I'm working on a modified version of the twoPhaseEulerFoam and I would like to make the number of PISO loops (or iterations within the timestep) adaptive. ie. the solver would vary the number of loops based on the convergence. How could I access the initial residual or the number of iterations of the pressure solver? I see that the lduMatrix.H includes a member function initialResidual() which I tried to use to access the residual with a command pEqn.initialResidual() This however resulted in an error message by the compiler: "Foam::fvScalarMatrix has no member named 'initialResidual'" This obviously isn't the right way to do it and no such functions can be found in the scalarMatrix.H Any help or tips would be appreciated! |
July 1, 2008, 08:23 |
You could try something like t
Mark Olesen
Rep Power: 40 |
You could try something like this:
// retain the residual from the first iteration if (nonOrth == 0) { eqnResidual = pEqn.solve().initialResidual(); maxResidual = max(eqnResidual, maxResidual); } Where maxResidual has been initialized elsewhere ... |
July 1, 2008, 08:35 |
Hi Juho!
Every call to solv
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi Juho!
Every call to solve returns such an object: http://foam.sourceforge.net/doc/Doxygen/html/classFoam_1_1lduMatrix_1_1solverPer formance.html This object contains all the information that you need Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
July 1, 2008, 08:49 |
Thank you very much! Just what
Juho Peltola
Rep Power: 17 |
Thank you very much! Just what I needed!
accessing solver data with UDF macros | Dushan | FLUENT | 1 | April 22, 2017 22:05 |
Residuals in CFX-Solver | Andy | CFX | 3 | July 18, 2012 17:40 |
Accessing Solver Variable for UDF | CFDtoy | FLUENT | 0 | May 9, 2006 20:29 |
Accessing Solver data for UDF | CFDtoy | FLUENT | 7 | April 13, 2006 17:52 |
Accessing a specific solver data | Paul | FLUENT | 0 | November 19, 2003 15:51 |
