ReactingFoam Laminar flame simulation transport properties
Old   June 30, 2008, 17:49
Default Hi all, I am an OpenFOAM ne
Gaurav Bansal
gbansal is on a distinguished road
Hi all,
I am an OpenFOAM newbie, and would be thankful if someone can answer my queries. I am simulating a laminar diffusion flame with two inlets and one outlet. One inlet has fuel coming in and other has air coming in. I could not find what transport properties is the code using ? i.e. where are the values of thermal diffusivity (heat conductivity) and mass diffusivity coded in ? Is it possible to use non-constant temperature dependent properties and how ? I could only find that we can use sutherland transport for viscosity and janafTHERMO for cp, but what about others ? Can we read in a CHEMKIN based tran.dat file ?
If anyone has a case setup for laminar premixed or non-premixed flame with non-constant transport properties, I would be really thankful if you can share it with me.
Thanks,
Gaurav
gbansal is offline   Reply With Quote
Old   July 1, 2008, 12:54
Default Bansal, The code in which t
E. David Huckaby
david_h is on a distinguished road
Bansal,
The code in which the transport properties are calculated resides in $FOAM_SRC/thermophysicalModels/species/transport.
The viscosity is only a function temperature, however the Prandtl number has a dependence on the gas constant and specific heat and thus changes with composition in addition to the temperature.
The species diffusivity is calculated assuming a unity Schmidt number, (YEqn.H).
Also note that differential diffusion has been neglected from the energy equation,(../XiFoam/hEqn.H)
Based on my reading of the code, neither a chemkin like transport model nor any composition based viscosity model is available for reactingFoam.
hope this helps
Dave
david_h is offline   Reply With Quote
Old   November 3, 2010, 21:23
sahm's Avatar
Seyyed Ali H.M.
sahm is on a distinguished road
Two, questions
Is there any way that I can use constant flow properties like constant viscosity and constant alpha for a reactingFoam case?
How can I add a model that reads Transport files instead of using only sutherland model?
SAHM
sahm is offline   Reply With Quote
Old   November 23, 2012, 17:03
Mhsn
mhsn is on a distinguished road
Originally Posted by sahm View Post
Two, questions
Hi Sahm, your question is mine too. did you figure anything out?
mhsn is offline   Reply With Quote
ReactingFoam specie transport equation alberto OpenFOAM Running, Solving & CFD 3 December 4, 2010 13:03
Please explain the implementation of species transport Eqn in reactingFoam kallipygian OpenFOAM Running, Solving & CFD 0 October 13, 2008 08:29
Laminar diffusion flames and reactingFoam Transport properties jgaricano OpenFOAM Running, Solving & CFD 0 June 4, 2008 17:58
Crosswind flame with reactingFoam torvic OpenFOAM Running, Solving & CFD 1 September 10, 2007 18:48
Laminar Flame danilo OpenFOAM Running, Solving & CFD 3 April 17, 2007 14:12
