Morphology Divergence of a boundary patch field
Like Tree1Likes
Old   June 2, 2015, 10:29
Fei Fan
Fanfei is on a distinguished road
Originally Posted by ngj View Post
Well, the procedure is to consider one face at the time until you have reached a state, where all faces are less than the sliding angle. Therefore, I do not see any problems in which value to assign to a given point.
Kind regards,
Niels
Hi Niels:
I have a problem in my sand slide model.i use hl_corrected[facePoints_labels[pointi]] to corrected the displacemnet of points of face, which need to corrected. After the hl_corrected is computed, the value of PointDisplacement[facePoints_labels[pointi]] is calculated. and then the information of mesh is update.
I output the value of PointDisplacement[facePoints_labels[pointi]], it's ok. However, the mesh don't update. what's wrong with it?
******************code**************************** ********
forAll(facePoints_labels,points)
PointDisplacement[facePoints_labels[pointi]].y() +=hl_corrected[facePoints_labels[pointi]];
mesh.update();
Best regards
Fan fei
Fanfei is offline   Reply With Quote
Old   June 2, 2015, 12:48
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hallo Fan Fei,
I am sorry, but your question is too detailed for me to be able to help. Since you already have moving meshes, I assume that you merely have a bug in your sand sliding model.
If you need help for developing and debugging your code, I suggest that you send me a private message, where you describe your needs.
Good luck,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   June 3, 2015, 10:46
Fei Fan
Hallo Fan Fei,
Good luck,
Niels
Hi Niels:
I have send a email to your niels.jacobsen@deltares.nl. can you find it?
kind regards
fan fei
Given field does not correspond to patch david OpenFOAM Bugs 2 January 29, 2009 14:24
Gamma field on boundary patch tom OpenFOAM Post-Processing 0 March 23, 2008 07:56
Boundary condition vector field gradient from two sides of patch face quba OpenFOAM 0 December 12, 2007 06:26
Projection of field onto patch tehache OpenFOAM Running, Solving & CFD 0 May 7, 2007 03:24
velocity field divergence? gh FLUENT 0 July 6, 2005 12:10
