July 14, 2008, 19:37 |
Hi
I ran a case with kEpsi
mohd mojab
Rep Power: 17 |
Hi
I ran a case with kEpsilon model and set the wall for "k" and "epsilon" as a fixedValue for B.C. and OF gave me this error for "k" and "epsilon", Create mesh for time = 70 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model kEpsilon Starting time loop Time = 70.001 Courant Number mean: 0.00103968 max: 0.0494671 DILUPBiCG: Solving for Ux, Initial residual = 5.85686e-05, Final residual = 4.6585e-10, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.000515567, Final residual = 3.09483e-09, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 0.00109401, Final residual = 7.4057e-09, No Iterations 1 DICPCG: Solving for p, Initial residual = 0.942377, Final residual = 9.56964e-07, No Iterations 273 time step continuity errors : sum local = 2.11503e-12, global = 2.74312e-14, cumulative = 2.74312e-14 DICPCG: Solving for p, Initial residual = 0.000860842, Final residual = 9.75e-07, No Iterations 164 time step continuity errors : sum local = 4.12992e-12, global = -7.69118e-14, cumulative = -4.94806e-14 --> FOAM FATAL ERROR : fixedValue is the wrong epsilon patchField type for wall-functions on patch wall should be zeroGradient From function wall-function evaluation in file /home/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude/checkPatchFieldTypes.H at line 13. FOAM exiting I changed them to "zeroGradient" for wall boundary, after some calculation in the first time step it gave this error. Create mesh for time = 70 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model kEpsilon Starting time loop Time = 70.001 Courant Number mean: 0.00103968 max: 0.0494671 DILUPBiCG: Solving for Ux, Initial residual = 5.85686e-05, Final residual = 4.6585e-10, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.000515567, Final residual = 3.09483e-09, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 0.00109401, Final residual = 7.4057e-09, No Iterations 1 DICPCG: Solving for p, Initial residual = 0.942377, Final residual = 9.56964e-07, No Iterations 273 time step continuity errors : sum local = 2.11503e-12, global = 2.74312e-14, cumulative = 2.74312e-14 DICPCG: Solving for p, Initial residual = 0.000860842, Final residual = 9.75e-07, No Iterations 164 time step continuity errors : sum local = 4.12992e-12, global = -7.69118e-14, cumulative = -4.94806e-14 #0 Foam::error::printStack(Foam:stream&) in "/usr/local/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/usr/local/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #2 __restore_rt in "/lib64/tls/libc.so.6" #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/usr/local/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #4 void Foam::divide<foam::fvpatchfield,>(Foam::GeometricF ield<double,>&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&) in "/usr/local/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libincompressibleTurbule nceModels.so" #5 Foam::tmp<foam::geometricfield<double,> > Foam::operator/<foam::fvpatchfield,>(Foam::tmp<foam::geometricfie ld<double,> > const&, Foam::GeometricField<double,> const&) in "/usr/local/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libincompressibleTurbule nceModels.so" #6 Foam::turbulenceModels::kEpsilon::correct() in "/usr/local/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libincompressibleTurbule nceModels.so" #7 main in "/usr/local/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/turbFoam" #8 __libc_start_main in "/lib64/tls/libc.so.6" #9 Foam::regIOobject::readIfModified() in "/usr/local/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/turbFoam" Floating exception would you help me what happened here? Thank you mou |
July 15, 2008, 04:18 |
Floating Point Exceptio
Andrew King
Rep Power: 17 |
Floating Point Exception means that some of you numbers are unbounded - Inf (infinity) or NaN (not a number). Sometimes this can be overcome by executing unset FOAM_SIGFPE and running your simulation again (this basically stops checking for out of bounds errors). Most of the time this won't fix the problem, however, it is more likely to be a problem with boundary conditions or the mesh. Cheers Andrew
Dr Andrew King Fluid Dynamics Research Group Curtin University |
July 15, 2008, 05:00 |
Hi Mou
From your error-mess
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Mou
From your error-messages, especially #3 and #6, tells me that you are dividing by 0 in your turbulence model. Do you on any of your boundaries, inlet, outlet, etc, set either k or epsilon to 0 in stead of 1e-11? My experience is that these properties cannot be zero, as you are dividing with them. I also believe that it would be necessary to put k!=0 in the interior, but you probably already have that. Best regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
July 16, 2008, 19:25 |
hi Niels
as you mentioned,
mohd mojab
Rep Power: 17 |
hi Niels
as you mentioned, I set 0 for the k and it was the problem. Thank you mou |
Understanding k from kepsilon | markh83 | OpenFOAM Post-Processing | 3 | December 5, 2008 04:42 |
Add new RASModel kEpsilon modification | ivanwhlau | OpenFOAM Running, Solving & CFD | 3 | August 21, 2008 05:36 |
About kEpsilon turbulence model | osimonsimon | OpenFOAM Running, Solving & CFD | 10 | April 24, 2008 03:52 |
Kepsilon BC and intialization | podallaire | OpenFOAM Running, Solving & CFD | 0 | October 17, 2007 21:29 |
KEpsilon and KOmega | larry | OpenFOAM Running, Solving & CFD | 3 | June 29, 2006 02:38 |
