PorousMedia Problem with Temperature Distribution |
July 18, 2008, 06:48 |
I am trying to simulate the st
Pawan
Rep Power: 17 |
I am trying to simulate the steady turbulent fluid flow through Porous region in a converging-diverging pipe. The porous media extend from the end of diverging section to start of converging section as showing in image .
I am using rhoImplicitPorousSimpleFoam Turbulence Model k-Epsilon model is used Boundary condition Inlet: mass flow Inlet = 0.417 kg/s Total Temperature = 811K Outlet: Pressure Outlet = 15000 Pa (gauge pressure) Wall: Insulated ThermoPhysical properties are same in both fluent and openfoam. mixture air 1 28.966 1006.43 0 1.789e-05 0.74417 Porous Region coeff i j k d =4.67e+07 4.67e+09 4.67e+09 f = 10 1000 1000 Problem(doubt) Under steady state , fluent show a temperature range of 809-811K , while in openfoam this range extend form 791-811 K . as showning fig and AS wall is insulated , and there is no such energy loss, such large temperature drop should not be there logically. However Other variable as pressure, velocity show the trend and range same as in fluent . Can anyone explain this behavior or point out where am i wrong in setting case ? |
May 10, 2010, 06:12 |
The same like me
Rep Power: 16 |
Hi!
How have you solved the problem? I have the same problem with porous media. My pressure and velocities are very similar to the results of fluent, but my temperature field is looking different. Greets Chris |
August 2, 2015, 23:08 |
Ipos
Rep Power: 11 |
Hi
I used OpenFoam and I have a problem same as you. Could you describe to me pls. Thx |
Cryosurgery - temperature distribution problem | Tal | FLUENT | 3 | October 18, 2010 15:58 |
Temperature distribution in a solid | michael_krobath | OpenFOAM Running, Solving & CFD | 3 | August 29, 2007 07:12 |
temperature distribution in a plate with 2 metals | Amir Khodabandeh | FLUENT | 1 | March 16, 2007 02:51 |
Temperature local distribution on the boundary | Matteo | Siemens | 0 | January 10, 2007 07:18 |
Linear Temperature Distribution | Kathir | FLUENT | 0 | July 16, 2004 09:33 |
