#41 |
Valter Dal Bo
Rep Power: 17 ![]() |
Hi all !
While trying to compile liftDrag, all is fine until step 7. There I get the following: /usr/bin/ld: warning: libincompressibleTransportModels.so, needed by /swcae/OpenFOAM/OpenFOAM-1.4/lib/linux64Gcc4DPOpt/libincompressiblePostProcessin g.so, not found (try using -rpath or -rpath-link) And then from there on a load of warnings all the way until I get the final: collect2: ld returned 1 exit status make: *** [/swcae/OpenFOAM/OpenFOAM-1.4/applications/bin/linux64Gcc4DPOpt/liftDrag] Error 1 and no executable gets created. I setup the LD_RUN_PATH variable to point to /swcae/OpenFOAM/OpenFOAM-1.4/lib/linux64Gcc4DPOpt where the lib is located but that didn't work either. Any clue on how to solve the problem ? Ta ! |
#42 |
mayank gupta
hi all,
I am using OpenFOAM-1.4.1 on a macintosh. I do not have any previous experince on OpenFOAM and hence no previous version. I am supposed to do the lift and drag force analysis on a airfoil and would need these directories I assume as I can not track them anywhere in my software. Could some one please post a zipped file for this thanx |
#43 |
mayank gupta
hi,
I have a query. I do not have the following directory on my system src/postprocessing even if i somehow manage to get the directories for the forces. where should i compile them then |
#44 |
Srinath Madhavan (a.k.a pUl|)
Rep Power: 21 ![]() |
Please try to upgrade to OpenFOAM 1.5 and try to follow the instructions in this[1] thread. It might help.
References: [1] http://www.cfd-online.com/OpenFOAM_D...tml?1216728172 |
OpenFOAM13 for Mac OSX Darwin 104 | hjasak | OpenFOAM Installation | 70 | September 24, 2010 05:06 |
Help%7e%7einstall openfoam13 on fc5%7e%7e | aderliner | OpenFOAM Installation | 2 | September 11, 2006 07:24 |
Must I unzip the OpenFOAM12linuxGcc4Opt file before I installcompile OpenFOAM12 | andycong | OpenFOAM Installation | 3 | March 9, 2006 07:57 |
1 fetal error in OpenFOAM12 installation | andycong | OpenFOAM Installation | 3 | February 26, 2006 03:09 |
OpenFoam12 on a linux cluster | tsjb00 | OpenFOAM Installation | 5 | September 10, 2005 19:44 |
